02-09-2014, 12:58 PM
1960 33' Custom
Athens
, Georgia
Tow Big
GVWR. I was wondering how the varying state and provincial laws were enforced with regard to long trips. I know if you have a commercial vehicle registration here you are more likely to get stopped and vetted but I looked at a link posted elsewhere on the forum and it got me thinking that a lot of small TV and big trailers are fine in some areas and not in others.
Here's the link I mentioned. Trailer Brakes | AAA/CAA Digest of Motor Laws
For example where I live this is an extract ….The weight of a trailer and its load or a combination of trailers and their loads must not exceed the following; in the case of a ball hitch, the GVWR of the towing vehicle…. so what happens if you're stopped towing a mid sized newish trailer with a sedan do you get a ticket or do they require you to get a properly sized TV?
My TV is 2007 Tundra 4x4 dbl cab Limted, TRD regular box, big V8 and it's tow rating is something like 10,900 but it's GVWR is more like 6,900 IIRC. That's quite a difference and guess it would be easy to get caught short in Saskatchewan.
Interestingly in Ontario, Can-Am's province, the rule is performance based and not on weight at all..
02-09-2014, 01:31 PM
Mantua
, Ohio
I gave never heard of an rv being stopped and weighed, but I guess it could happen if the combo looked dangerous. Now in the event of an accident, who knows. Jim
02-09-2014, 11:53 PM
Vancouver
, British Columbia
The regulation appears to state that the trailer GVW limit is that the trailer can not be more than two times the GVW of the tow vehicle, if a weight distributing hitch is used.
At first glance, you would have a trailer limit of 13,800 lb. That is if you go by the GVWR, and I used your figure of 6900 lbs. However, the Saskatchewan regulations differentiate between GVW (actual) and GVWR (manufacturer's plate) and say that the trailer weight limit (not GVWR) can be no more than twice the vehicle GVW (defined as vehicle plus load, which would include your tongue weight for example). I still don't think you would be caught short.
The full text of the Saskatchewan regulations is here:
http://www.qp.gov.sk.ca/documents/En...ns/V2-1R10.pdf
Some other interesting rules in the fine print. If towing with a car then a WDH is required for any trailer over 1600 kg (approx. 3500 lbs). That would appear to give sedans the same headroom as your truck, depending on their actual vehicle weight.
As an interesting side note, in 88 pages of definitions and regulations, the phrase "tow rating" does not show up even once in a search. To put that in context, the regulations do specify hitch ball diameter, hitch protrusion from the rear bumper, safety chain link dimensions, brake lining thickness, and many other details. But no mention of tow ratings.
The regulations also state that they apply to vehicles registered pursuant to the Saskatchewan Vehicle Administration Act. That suggests to me that vehicles registered and legal elsewhere are not covered by the regulations, but I would defer to legal experts on that. I would presume that my BC registered trailer could pass through as long as I complied with traffic regulations and any specific road weight limits. The BC Motor Vehicle Act allows vehicles registered and legal elsewhere to be used in BC without being subject to the motor vehicle act for a period of six months if the operator has not established residency.
Jeff
02-10-2014, 05:29 AM
1984 34' International
Toronto
, Ontario
This has always been my understanding for Ontario as well.
02-10-2014, 05:47 AM
2013 30' Classic
Greenwood
, Mississippi
Are the regulations enforced anywhere on privately owned vehicles?
Here the regulations are only enforced on commercial motor vehicles.
That having been said, moat tow vehicle/travel trailer combinations are under the CGVWR, albeit just barely-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
02-10-2014, 07:30 AM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
While the truck door label says GVW of 9,600 pounds, the tires and axles are rated 11,510 pounds. The tires and and axles are what DOT looks at for an inspection. I don't worry if I am under 10,500 pounds on the truck. If the trailer were fully loaded, we could push the combination weight of 20,000 pounds.
02-10-2014, 07:53 AM
Central
, Mississippi
Both my Father and if I recall correctly my neighbor have been stopped and measured for possibly being oversized. My dad was just under the max width for the trailer (he built it so he KNEW it was legal). If I recall the details correctly, my neighbor had a quad cab, long bed truck towing a long bumper pull camper and was a few inches short of the max length.
Both cases were several years ago.
02-10-2014, 08:43 PM
2013 30' Classic
Greenwood
, Mississippi
So-
If you are not obviously too wide or too long you won't have any problems-
TAC #MS-10
Airforums #70955
02-11-2014, 03:49 AM
2014 31' Classic
Apache Junction
I figure that the 31' Classic model 30 with a ProPride hitch and the 20' Dodge will be close to 53' long with a combination weight around 18,000 pounds.
02-11-2014, 04:24 AM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
I don't know about other areas...
In the US you have 50+ different jurisdictions. In my state of NC they are not typically going to pull an RV rig over. Here it seems with the lighter trucks (under 26,000 GVW) they are more worried about the taxes , they make sure your license plates are for the correct weight of truck. My idiot company has been caught several times. The plate is supposed to cover the combined weight of the trailer and the truck. For several years I ran 20,000# plates on my F350 because I pulled a goose neck equipment trailer. I was only stopped once and was within the limits of the plates and the truck at that time. Now I only run 10,000# plates on it, saves me over $300 a year in fees.
There was a big enforcement push a few years ago where they were stopping obvious large vehicles (F250. F350, Excursion, etc) that were displaying passenger car/light truck plates. Those are only good up to 5,999#. My F350 weighs in at 7,000#+ empty. The base plate at the time was ~$55usd the weighted plates started at around $200. Follow the money trail...
Aaron
WBCCI #XXXX AIR #2495
02-11-2014, 05:39 AM
2013 30' Classic
Greenwood
, Mississippi
Regardless, travel trailers are privately owned are not DOT regulated.
It is totally different world.
Put some signs on it, use it in s business, put a DOT number on the door, and everything changes.
My company has been running either car or personal pickup tags for over 30 years until now. A couple of DOT violations is an expensive education.
Over the past year I have been replacing license plates with the proper weight tags on our fleet of 300 as they expire.
We have vehicles tagged from 10,000# to 26,000# depending on GVW and CGVW and whether it will tow a trailer.
That is another sticky area. If the tow vehicle has a state issued 16,000# or 26,000# tag, the trailer must have a state issued "semi" tag. If the tow vehicle has a county issued private pickup tag, the trailer must have a county issued private trailer tag. By this law, I can't tow my Airstream with a work truck with DOT numbers on the door and a can't tow a car trailer or cargo trailer with "semi" plate behind my personal pickup. That's just dumb , but it 's the law.
Also, drivers of commercial motor vehicles must use log books and are limited to 11 hours driving time. RV drivers are under no regulation even though their vehicles are just as long and heavy- and the drivers of RVs have had no special training-
TAC #MS-10
Airforums #70955
02-11-2014, 06:36 AM
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown
, Tennessee
Originally Posted by m.hony
So-
From a practical standpoint, I have towed several hundred thousand miles delivering travel trailers. Signs, ICC # etc and hundreds of thousands more privately.
In that time I have never been stopped and on the occasions I did go through a weigh station when running commercially the usual reaction was "why are you in here bothering us?"
I am aware of stories from other drivers but my experience in 49 states and most of Canada has been trouble free.
The odds are that you will never encounter a problem
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
02-11-2014, 01:05 PM
2013 30' Classic
Greenwood
, Mississippi
I have experienced that as well.
I go through the weigh station in every state at least once to see their reaction. They may wave me on or tell me not to come through there anymore. That is better than bypassing the scale and having a DOT man in a car chase you down and write you a ticket.
I tell my drivers when in doubt drive through. The person in the booth will tell you if it is necessary to cross scales in that particular state.
In 750,000+ miles I have never been pulled over or inspected.
Some of our drivers have, though.
TAC #MS-10
Airforums #70955
02-11-2014, 02:41 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
We have had driver's in half ton pickups chased down by zealous (bored?) enforcement officers. Happened several times in Kentucky, Alabama, Florida and Ohio for some reason. The heavier trucks get stopped on a regular basis. We have only had one where we really got hit hard, but they deserved it.
They had pulled an old F450 off the back lot, inspections weren't current (tags apparently were) they were under GCVW but over on the rear axle weight. To add insult to injury they had way too much LP and flammable stuff on board and were not placarded. Ooops. The fact that the truck left the shop violates company policy, but when certain parties make decisions...
Aaron
02-11-2014, 03:03 PM
Wise Elder
2010 30' Classic
South of the river
Originally Posted by truckasaurus
The first thing to realize is the AAA list, as well as others I have found, is badly out of date. In general there has been a trend toward increasing length and width limits and also decreasing the threshold at which brakes are required. The Minnesota section, by way of example, is several years out of date.
The second thing to realize is, as others have posted, RVs are generally not expected to comply with laws and regulations adopted for the trucking industry.
In my experience there are a number of things to watch where you can indeed get stopped:
1) You must have lights that work properly
2) You must have current registration
3) There are many jurisdictions that disallow doubles and these rules are enforced
4) They will stop you for a violation of maximum length limits, which is really only a problem for some unusual older trailers e.g. the longer Spartans
5) You must have safety chains, and they will stop you if they are dragging and sending sparks flying
6) Routes in the mountains that have posted length width and height limits are enforced
02-11-2014, 07:48 PM
2013 30' Classic
Greenwood
, Mississippi
That has happened to our drivers in AL and FL.
TAC #MS-10
Airforums #70955
02-17-2014, 09:12 AM
Vintage Kin
Fort Worth
You might walk it off with a tape. I'm close to the TX limit of 65' with my similar truck and 35' Silver Streak. The Hensley Arrow hitch adds some length to the A-frame, but it is the TV front bumper forward-most point and the TT rear bumper length when hitched that is well above the "oh, my TT is about 35' in length" measurement plus adding the truck OAL.
02-17-2014, 09:45 AM
Vintage Kin
Fort Worth
As to the OP's concerns I find them of no consequence. It is partly psychological -- a new awareness of "being" other than a car while running the roads -- the previously invisible made visible -- and second, that private citizens operating RV's are themselves pretty much invisible to LEO's unless something is amiss.
There is always the incentive in a profit-making venture to stretch rules past their breaking point. For vehicles in intra and inter-state commerce this comes down to the size and weight of a load: what it will pay. Unless monitored this confers an unfair advantage to the rule breakers as well as size/weight configurations that hasten wear/tear on infrastucture and pose a hazard to others.
Just stay within axle/tire/wheel ratings and length/width provisions, generally, and get on down the road.
