Old 01-14-2008, 06:03 PM   #1
Profile:  1979 31' Sovereign
Baton Rouge , Louisiana
Images: 42
Tow 1985 Limited 31' with Dodge 1500?
Guys,
I need some help and some information. My Father is looking at a 1985 31 foot Airstream Limited. His tow vehicle is a 1996 Dodge 1500 2wd, 3.55 rear axle, 5.9L gas engine and full tow package with oil and trans cooler. I don't know the weight on the Limited and I can't find a weight chart anywhere (all the links I found here don't work). The truck is VERY conservatively rated at 7,600lb towing weight and it will have an aftermarket exhaust, air intake and chip on it to help out. Buying a new truck is not an option right now. What I need to know is can this truck pull this trailer and what is the weight of the trailer? I know a 3/4 ton would be better, I pull my Airstream with a Dodge Cummins...so we can skip the inevitable comments about the superiority of the 3/4 ton and diesel I already agree with you on that! My father will be traveling in the mountains as well as the flat lands, so really good info is a must. Thanks in advance guys!!
-Don
cobra93 is offline   Reply With Quote
Old 01-14-2008, 06:07 PM   #2
wkerfoot's Avatar
Profile:  1979 23' Safari
1954 29' Liner
Orange , California
Originally Posted by cobra93
Guys,
-Don
Don,
Is this what you are looking for? http://www.airstream.com/docs/weights-1.pdf
Dry weight 5600 lbs.
Bill
Just my personal opinion
1973 Dodge W200 PowerWagon, 1977 Lincoln Continental
wkerfoot is online now   Reply With Quote
Old 01-14-2008, 07:12 PM   #3
Images: 42
Tow weights
Bill,
Thanks a lot for that chart!! I couldn't find it anywhere.
Just curious...you listed 5600lbs for the 85' 31 foot limited. The chart said 6,200lbs. Did I read it wrong? My Dad is interested in the unit but if the weight is truly 6,200lbs then after you add the weight of the appliances and 500lbs of personal stuff then the 1,000lb headroom limit for the truck is gone. If it's 5,600lbs then it might be doable.
-Don
Old 01-14-2008, 07:24 PM   #4
wkerfoot's Avatar
1954 29' Liner
Orange , California
Bill,
-Don
Don,
Sorry, I missed the Limited part, you are correct. There should be a plate on the front of the trailer which shows the GVW, that is really the number you want to concentrate on not the dry weight. Your father may be OK with the 1500, just don't get in a hurry and pull to the slow lane going uphill.
Bill
Old 01-14-2008, 07:43 PM   #5
SafariSS's Avatar
Profile:  2005 30' Safari
Houston Texas , Texas
Uhh....
I can tell you the 3.55 rear end is an issue. I had a similar rear end in a 1500 suburban and its like riding a 10 speed bike in 9th gear uphill pulling any wieght.
SafariSS is offline   Reply With Quote
Old 01-14-2008, 08:08 PM   #6
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Somewhere , Over the Rainbow
And the rear axle bearings in those are iffy. A friend had a 2000 Ram 1500 with a 5.9, and 3.55 gears, pulling a 6000 pound travel trailer. I had to go rescue him and his trailer when the rear end came apart on him while towing.
(No Longer at Inland RV)
Old 01-14-2008, 08:20 PM   #7
wkerfoot's Avatar
1954 29' Liner
Orange , California
Terry,
Is this still a problem with the 1500 rear axle? If so, what exactly came apart?
Bill
Old 01-14-2008, 08:22 PM   #8
Well-Preserved
Originally Posted by wkerfoot
Terry,
Bill
I'm not sure if it's still a problem, but the 2000 1500 had the same setup as my Dakota.
The pinion bearings came apart.
Old 01-14-2008, 08:56 PM   #9
Profile:  Currently Looking...
holland , Michigan
You know it might be worth the time to look at changing to a 373 or even better 410 gears if possible. Whatever the cost is will probably save on future repairs and make the whole experiene better. It makes a huge difference in the tow rating.
safari 28 is offline   Reply With Quote
Old 01-14-2008, 09:39 PM   #10
wbrownrr's Avatar
Profile:  2002 22' International CCD
San Luis Obispo , California
We tow our 2002 22' CCD (5,000 lbs GVWR) with a 1997 Dodge Ram 1500, 5.9 L. When we bought the truck it had the 3.55 rear end.... we have since swapped it out for a 4.10 and what a difference! The Dodge handles the trailer pretty well with the 4.10. I can't imagine towing anything over 5,000 lbs with the 3.55. This is my real life towing experience in the mountains of the west. Hope that is helpful.
Wayne
2002 22' CCD
1997 Dodge Ram 1500 5.9L
wbrownrr is offline   Reply With Quote
Old 01-15-2008, 08:36 AM   #11
Patriotic
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
I think I had the same problem with the rear-end on mine...its a 5.2 w/ the 3.55 rear. I was getting a clunking sound...suspected u-joints/driveshaft issue, and had the mechanic check it out...turns out that it was coming apart from the rear-end. now the question is: is the repair they did permanent, or is it likely to be a recurring problem?
I find it can be a bit of a dog on hills. You might have less trouble w/ the 5.9, although, I think that its only rated as having 20 more hp than the 5.2. Funny thing is that the power band on this motor is above 2500rpm. It'll maintain speed on a steep hill, if you start out @ 65mph. Hit the base of the hill at less than that, and you'll be doing 40 in 2nd gear shortly.
My trailer has a 5800lb gvw...probably weighs around 5000, most of the time.
changing out the rear end isn't practical on this truck, as its a 4x4.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 01-15-2008, 11:36 AM   #12
Well-Preserved
Chuck, it will probably recur, as the problem is in the strain of the gearing and the size of the bearings. Lower ratio will take some of the strain off the bearings, also replacing the dino gear lube with full synthetic gear lube will prolong things (synthetic doesn't break down like the dino oil).
Sometimes you can get new lower ratio ring and pinion for your existing axles.
RUMOR: Diesel in Dodge 1500 trucks crispyboy Tow Vehicles 6 07-13-2007 12:57 PM
Dodge RAM 1500 SLT 5.9 liter tow vehicle abridges01 Tow Vehicles 10 08-17-2006 08:25 AM
2004 Dodge 1500 wkerfoot Tow Vehicles 6 04-12-2006 10:00 AM
1985 34' Limited robandzoe 1984-1988 Limited 3 11-02-2004 08:37 AM
2002 Dodge 1500 QuadCab Melvin P. Thorpe Tow Vehicles 15 03-14-2003 01:34 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
