Originally Posted by Antique Pedaler
The conflicting stories you get from the various customer service reps is always interesting...same with the various dealerships.
I seem to be getting consistent responses from VW reps including the referral Class II trailers when I was asking if the Touareg had a Class IV hitch receiver.
Here is the latest response from VW Chat:
"Thank you for chatting with yesterday. I got that information you requested!
The hitch receiver for the 2013 Touareg is a class 3 and does not come standard on the vehicle. While this is a class 3 hitch, the maximum towing capacity is 7,716 pounds and the tongue weight is 616 pounds.
You will need to have your local VW Dealer install the hitch receiver. All of our vehicles that offer the ability to tow have the following to help assist on safely towing a trailer:
• Heavy duty radiator and battery
• A flasher system
• Heavy duty alternator
• Heavy duty suspension and brakes
• Engine oil cooler
• Transmission oil cooler
In order to ensure the Touareg you purchase has the ability to tow up to the maximum of 7,700 pounds, you will need to make sure it was ordered with the hitch from the factory and that you are using a trailer with brakes. If not, the maximum towable amount is 1,650 pounds.
Please know the maximum permissible trailer tongue weight exerted on the ball mount must not exceed 616 pounds. With the towing equipment properly installed, the weight of force pressing down on the tongue will not lift the front wheels. If the tongue weight is too low, the vehicle and the trailer will not handle as well.
Volkswagen strongly discourages the use of weight distribution hitches. An improperly adjusted weight distributing hitch system may reduce handling, stability, braking performance, and could result in an accident. We recommend to only use a weight-carrying trailer hitch designed and approved for the gross weight of the trailer you want to tow.
Some other helpful information about the Touareg is it was not designed to tow a Class II trailer. Please make sure the trailer you want to tow does not meet this classification. The ball mount you use on the Touareg must not exceed two inches (2”) and there are specific dimensions in which the height of the ball above the surface where it attaches and the pin-to-ball distance must be met. These dimensions are very important as a way to help determine the way the forces that arise during towing are applied properly to the receiver.
For even more in-depth information about the Touareg’s towing capabilities and guidelines, I encourage you to contact your local VW Dealer. I’m positive they will be more than willing to help you! To locate your nearest VW Dealer, please visit
Find a Dealer - volkswagen.com.
I also encourage you to take a test drive of the Touareg if you have not already done so. I’m sure you will love the driving and handling the vehicle has to offer.
I hope we can see you in a new Touareg soon!
Christy
VW Chat"
