Old 04-08-2012, 10:48 AM   #15
Chicago , Illinois
Dumb question, do you put the switch between pin3 on the vehicle harness and pin 86 on the relay? Or between pin2 on the vehicle and pin 30 on the relay?
johnneuraute is offline   Reply With Quote
Old 04-08-2012, 01:58 PM   #16
JFScheck's Avatar
Rockville , Maryland
Images: 33
Inline - between your instant 12 volt source (controlled by ignition key i what Zi used) and pin 30 of the relay.
The switch is not necessary, I thought it would be nice to deactivate the relay and brake controller when not in use...
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 02-16-2014, 10:47 PM   #17
Buck944's Avatar
1998 25' Safari
Mascouche , Quebec
New question to an old thread but...
Is it possible that the computer of the Touareg (2010 tdi) is not sending the brake pedal signal to the brake controllerif the vehicule is not working?
1998 Safari 25' SS
2015 Toyota Sequoia Limited
Buck944 is offline   Reply With Quote
Old 02-17-2014, 08:02 AM   #18
JFScheck's Avatar
Images: 33
Don't quite understand the question...
When the vehicle is powered off, the switched 12 volts de-energizes the brake controller and the relay thus zero power is available to the trailer brakes when the tow vehicle is turned off.
When the tow vehicle is powered on (regardless of the engine running or not - but the Ignition Switch is in the "On" position), the switch inline allows the powering of the relay and the brake controller, my ideal was to use the switch and turn off power to the relay and brake controller if I'm not towing...
Does this help?
**I Love U.S.A.**
Old 02-17-2014, 08:17 AM   #19
Buck944's Avatar
1998 25' Safari
Mascouche , Quebec
Yes and no!
I did exactly like you with the 12vdc relay, but there is no signal coming from the wire for the brake switch...
I understand that when the brake pedal is not depressed I should see 3-4 vdc and 12 vdc when depressed, but I always have zero volt...
The brake controller is on then part of my wiring look good, but there is no signal from the brake...
Is it possible that I need to have the engine running to have at least 3-4 vdc at that wire??
1998 Safari 25' SS
Old 02-18-2014, 07:50 PM   #20
Buck944's Avatar
1998 25' Safari
Mascouche , Quebec
Hi Jeff, I think that my idea was lost in the translation...
I did more check tonight, I removed my connector to see if the car connector had the 3 volt and 12 volt depending of the brake pedal position. No power there... I also checked if there was a fuse related to this signal, no answer there...
Next step is to get the electrical schmetics to see from where this signal is coming and investigate why it is not working...
1998 Safari 25' SS
Old 02-23-2014, 02:28 PM   #21
Buck944's Avatar
1998 25' Safari
Mascouche , Quebec
I finally buyed a brake switch that can be installed where it is on other model, close to the brake pedal. I wired a 12 volt wire there and then to my brake controller. Et voilà!
Let's try it now...
1998 Safari 25' SS
Old 03-02-2014, 08:25 PM   #22
Buck944's Avatar
1998 25' Safari
Mascouche , Quebec
First run!
Brake are working: Check!
Light are working: Check!
Name:	ImageUploadedByAirstream Forums1393817051.487007.jpg
1998 Safari 25' SS
Old 03-04-2014, 07:05 PM   #23
JFScheck's Avatar
Images: 33
Congrats!!!
**I Love U.S.A.**
Old 06-04-2014, 08:35 AM   #24
JFScheck's Avatar
Images: 33
I have just recreated the links to the pictures in this thread, thus all images are now properly displaying.
jfs
**I Love U.S.A.**
brakes, cayenne, touareg
Ready to buy & install entire 63 AS Interior... Zstream General Interior Topics 2 06-14-2009 09:34 AM
Porsche Cayenne with Airstream & SOB cameront120 Tow Vehicles 7 06-23-2008 12:29 PM
2008 Cayenne Wayward Tow Vehicles 4 03-24-2008 10:35 AM
How to install a Prodigy brake controller Airstream 65 Brakes & Brake Controllers 1 04-07-2007 02:58 PM
Awning Purchase & Install tique79 Awnings 6 07-17-2006 12:46 PM
