Old 05-11-2015, 09:45 PM   #99
TCwheels's Avatar
2011 20' Flying Cloud
Traverse City , Michigan
Originally Posted by richw46 View Post
While they are the same company, there is a difference in assembly and parts, among other things. For example, there is a given time to do your individual assembly step. For Toyota the time is much shorted than for the Lexus. When you have more time to do your job, you can do a better job, especially when the next person down the line is critiquing your work.
In parts there is not necessarily a difference in quality but perhaps a difference in the defect rate. For a Toyota (just throwing out some numbers here) one defect in 100 may be acceptable while for a Lexus the defect rate may be one in 500. The manufacturer will pay more for the part with a lower defect rate but the reliability will be higher (and the vehicle cost).
I think the quality for all cars has improved significantly because of reports like these. The consumer has really benefited from the competition.
You are the right track, just lower the percentages a little. The automotives and their supplies track and report part defects in many ways. One common metric is "PPM" or parts per million (defective). Toyota and Lexus are typically purchasing components with documented PPMs of less than 10.
WBCCI #7246 Michigan Unit,Texas Hill Country Unit (associate member), AIR #91367
"Don't let perfect be the enemy of better."
TCwheels is offline   Reply With Quote
Old 05-11-2015, 10:53 PM   #100
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
If we ever live closer to a Lexus dealer, maybe we'll buy a Lexus.
Maybe we should buy a Lexus anyway and get it serviced at the Toyota place.
I really don't think there's a nickel's worth of difference between a Lexus 3.5liter V6 and a Toyota 3.5 liter V6.
I also don't think there's much difference in the power window/door lock/mirror switches, wiper/washer switches, cruise control switches, steering wheel controls, stereos, gear shift levers, and random switches for other things like traction control or moonroof.
The tires are probably the same. Brakes and transmissions are the same or similar.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 05-12-2015, 06:19 AM   #101
Hans627's Avatar
2009 25' FB International
Hanover , Pennsylvania
I spent most of my working career in the auto industry as a supplier to all the major manufacturers. By far Toyota and Honda were the best to deal with. While being very demanding they took the collaborative approach to problem solving (and let me tell you there are always problems to be solved). The big 3 would take the combative approach. I used to like to say the Japanese were interested in fixing the problem but their US counterparts were more interested in fixing the blame.
At least that's the way it used to be and I think it has changed somewhat as the quality of the big 3 has improved significantly. But the Japanese are still ahead. I just read an article listing the cars most likely to exceed 200,000 miles. There were 10, not surprisingly 5 made by Honda and 5 made by Toyota.
Old 05-12-2015, 05:37 PM   #102
2007 22' International CCD
Every vehicle I've been able to run past 200,000 has been a Toyota.
Volvo claims it, but I had 5 in the family at one time, and nothing but trouble...went back to Toyota.
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 05-12-2015, 06:24 PM   #103
m.hony's Avatar
2013 30' Classic
I ran a 1987 Mazda B2000 pickup well past 200,000 miles. I have never had the opportunity to wear out another one. Have 2 Toyotas and a Nissan now. From my experience, Toyota is better, even though I drive the Nissan every day.
TAC #MS-10
Airforums #70955
Old 05-12-2015, 06:32 PM   #104
Mont Vernon , New Hampshire
1998 Jeep Wrangler has been extremely reliable. When it does have a failure(rarely), it is very inexpensive to repair.
bugsbunny is offline   Reply With Quote
Old 05-12-2015, 06:39 PM   #105
m.hony's Avatar
2013 30' Classic
We just had a random gremlin in a 2001 Jeep Wrangler- intermittent no start-
Replaced battery cables because they appeared to be chewed on by some animal- still intermittent no start-
Replaced battery- still intermittent no start-
Replaced ignition switch- now it starts-
TAC #MS-10
Airforums #70955
Old 05-12-2015, 06:40 PM   #106
m.hony's Avatar
2013 30' Classic
Forgot-
Replaced starter- still intermittent no start-
TAC #MS-10
Airforums #70955
Old 05-12-2015, 06:42 PM   #107
Gainesville , Florida
Gremlin in a jeep. Takes me back to the AMC days! Jim
avionstream is online now   Reply With Quote
Old 05-12-2015, 08:41 PM   #108
m.hony's Avatar
2013 30' Classic
If we had noticed the switch sooner-
Eventually, after replacing a lot of other stuff, we noticed that the switch would start the engine if barely engaged, but if the switch was fully engaged- no start- bad switch-
TAC #MS-10
Airforums #70955
Old 05-12-2015, 11:27 PM   #109
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I don't ever want a vehicle with 200,000 miles on it; It may still be running, but the rest of the vehicle will be a miserable piece of junk. And those who brag that their Diesels will last for 350,000 to 500,000 miles are a glutton for punishment. Now if you are dirt poor and can only afford to own one vehicle for fifty years, then that's a different story.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 05-13-2015, 12:01 AM   #110
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
There are a few older Mercedes still operational by their original owners with over 500,000 miles on the vehicle. Proper service will keep the vehicle alive. And yes, parts get replaced.
Old 05-13-2015, 12:31 AM   #111
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Top 10 Most Reliable Vehicles
Our Tahoe just turned 210,000,,,
It is still in very good shape. Last month we just got back from a 3,000 mile round trip with it towing the old streamer... Everything works but the drivers side heated seat.....,
For what they want for new vehicles that are suitable for towing, I am not going there, on principle.
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
Old 05-13-2015, 07:05 AM   #112
m.hony's Avatar
2013 30' Classic
Not necessarily so- we have had many vehicles with 200,000-400,000 miles that were in really good shape. The only indication of high miles is the odometer, but they still ride and drive as new. My boss has a 1953 Chevy 3100 pickup restored in the 90's that still drives as new.
TAC #MS-10
Airforums #70955
Which airstream is most reliable era for older and resto? LAWFISH Buyer Guidelines 5 07-03-2011 02:26 PM
Looking for a good reliable tank rinser ronstory Waste Systems, Tanks & Totes 3 01-11-2009 02:39 PM
Price and Year of a reliable Tow Truck maggieairstream Tow Vehicles 22 02-26-2008 09:50 PM
Dealers:Reliable West Coast Dealers carhart Community Polls 4 08-13-2006 12:21 PM
Top Ten tow vehicles ?? darkStar Tow Vehicles 34 10-19-2005 10:20 PM
