Old 08-15-2007, 09:41 PM   #15
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by gowyn
Looks like I may have found a truck for my 07 27FBSE.
Would a Ford 2005 F350 diesel auto, crewcab 4x4 short box with air bags be too much?
Any cons of running a one ton over a 3/4?
thanks
Hi, are you talking about air bags added to the stock springs or an air bag suspension system? It has been stated by some members, that if your truck is too stiff you need to use weaker or lower rated spring bars on your hitch. If you don't load your truck too much, [light load in the bed] I would have one or two of the rear leaf springs removed on each side to soften the ride.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-15-2007, 10:13 PM   #16
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Originally Posted by ptrvr
Brian, looks like your rig in the background. Must have been celebrating a birthday!!!
Greg
That is our Lucy in her own personal campground in Daddy's yard. We have complete hook-ups there. We're set up for 30 amp electric, water, sewer, and cable TV. Patrick had the bambi at the campground at NAS/JAX about two miles away. Unfortunately, we were all in Jacksonville for a family funeral. SuEllyn's sister-in-law had passed away after a long battle with cancer.
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Old 08-16-2007, 05:53 AM   #17
gowyn's Avatar
2007 27' Safari FB SE
London , ontario
they looked like helper bags, on top of the springs.
gowyn is offline   Reply With Quote
Old 08-16-2007, 07:16 AM   #18
Airstreamer67's Avatar
I selected the solution suggested by DavidZ71 Craig: the Air Safe Air Hitch.
I bought a Class V Air Safe hitch a couple of years ago, and it works as advertised. After connecting my trailer with the air hitch, I can push down on the trailer's A-frame and watch it go up-and-down on the air bag while the truck moves very little. The trailer hitch is now riding on a layer of air instead of directly to the frame of my F250. This insulates my trailer from the harsh suspension of the tow vehicle, allowing the trailer to handle the bumps and grinds of the road without high-shock hindrance from the truck.
It's not a cheap solution, but the rivets and welds will thank you each and every mile. It cost me about $1000 for this fix, but I plan to keep this hitch forever because it can be used on future trailers as well.
Airstreamer67 is offline   Reply With Quote
Old 08-16-2007, 08:16 AM   #19
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Originally Posted by overlander63
If the F350 has stiffer springs, it could cause issues down the road with your trailer. What is the towing capacity of the 350, vs. the 250?
BTW, the 250 diesel should be more than capable of towing the 27.
I'm with Terry on this one. a 350 is a great truck, no question, but it's a bit stiff for a 27' Airstream. If you must go with a 350 for that rig, then I would suggest looking at an air hitch setup that softens the blows to the trailer.
If you had a 30' slide or a 34' slide, I'd be less concerned about the 350 (1 ton) since the hitch weights would be large enought that the 350 stiffness might not be an issue. Of course a 3/4 ton in whatever drivetrain config would do anything nearly everything we've talked about.
Old 08-16-2007, 08:43 AM   #20
2005 30' Classic
Images: 12
Pardon me for asking, but do you have a need for that much truck, besides pulling your Airstream? If so, I could understand your desire to use a 350 to pull the Airstream, but if not, given the initial cost of the TV, and the price of fuel, why would you want something that much more than what is needed?
If you want to go all the way with the TV, why not go all the way with the TT (get a bigger Airstream)? Both have an associated increase in cost; come on now, wouldn't you like to have a bigger Airstream?
GetOutDoors is offline   Reply With Quote
Old 08-16-2007, 10:03 AM   #21
altamont's Avatar
Tracy , California
Our 2008 F250 has given us perfect service with our 27 FB SE for almost 8000 miles of towing this year. Never a concern about overloading, sway or power. I am not too happy about the harshness of the ride with no load, so going to a F350 would seem like overkill (I am looking to replace the tires with less harsh Michelins). We do carry about 400 pounds of stuff in the back of the truck for our trips and we do have the crew cab.
altamont is offline   Reply With Quote
Old 08-19-2007, 06:49 PM   #22
gowyn's Avatar
London , ontario
you're evil...haha
we just moved up from a 19' Bambi to the 27.
Old 08-19-2007, 07:15 PM   #23
Tramp Streamer
ArtStream's Avatar
1995 28' Excella
Artist , at Large
Images: 65
I had separation issues when I purchased my rig.
Once repaired, I added the ClassV AirSafe hitch along with Centermatic wheel balancers.
I do keep the rear TV tires at around 65lbs.
Put 40,ooo miles in the separation repair without the slightest hint of a occurrence.
The rolling garage, E350 7.3TD
15"Box. MC , kayak, and other junk inside.
Photo taken yesterday, near Arches National Park
ArtStream is offline   Reply With Quote
Old 08-19-2007, 08:34 PM   #24
2005 30' Classic
Images: 12
Talking
you're evil...haha
Nope, just temping. Somebody's got to do it!!
Truck Weigh Stations, Safety Lanes & Mandatory PullOvers hex Towing, Tow Vehicles & Hitches 2 11-23-2002 10:29 PM
Diesel truck owners FrankR Off Topic Forum 3 11-23-2002 05:35 AM
RV (Truck) Stops 74Argosy24MH Link Archive 5 10-28-2002 05:24 AM
Ouch! What happens when an Argosy MH meets the back of a dump truck 66TradeWind Airstream Motorhome Forums 13 08-12-2002 02:49 AM
Mags Or New Rims?? Charcigar Wheels, Hubs & Bearings 10 08-01-2002 05:09 PM
