Old 05-23-2015, 03:14 PM   #1
2001 30' Excella
Full-time traveling , Hmmmm. what day of the week is it?
To cover or not to cover...that is the question
Ok, so I just purchased my 2014 Ram 2500 Diesel and a Honda Eu3000is generator.
I want to secure the Honda permanently in the bed of the truck, (it weighs 135 lbs) and need to evaluate the options for covering the bed.
Camper shell
Hard cover solid one piece
Hard cover two piece
Soft cover
Roll up
etc.
Any advice on how you deal with security, convenience, storage, and generator exhaust while keeping the generator in the bed?
I like the idea of the cabin height camper shell so I can store bikes, etc and keep them dry and out of sight. But then what do you do when the generator is running and the fumes?
I am also open to better all-around suggestions.
Thanks!
JBBeaubeaux is offline   Reply With Quote
Old 05-26-2015, 10:37 AM   #2
2001 30' Excella
I am not sure if I did something wrong on this post, since I have not received any replies.
Did I make a mistake?
Old 05-26-2015, 10:47 AM   #3
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
You didn't make mistakes on the post. Sometimes the posts fall very quickly in the queue and it just doesn't get read. Occasionally you have to give your own post a bump so that it will jump back up to the top of the queue and people will get the opportunity to read it. Your title is also a bit misleading in that you said "to cover or not cover". I'm not sure everybody's getting, from that title, what it is you are asking about. People will answer in time. Good luck.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 05-26-2015, 11:18 AM   #4
2001 30' Excella
Thanks for the tip
Old 05-27-2015, 11:19 AM   #5
SipStreamer
2010 20' Flying Cloud
Lakeside , Montana
gen security
I have the Honda 3000 in the back of my truck secured with a BIG chain and locks. However you cover, you'll need plenty of ventilation for the gen when she's running.
StreamDog is offline   Reply With Quote
Old 05-27-2015, 11:23 AM   #6
B00merang's Avatar
Hailey , Idaho
and maybe we're all still thinking and agonizing over alternatives to give you the best advice...we don't rush in with frivolent responses (like this one, for example)...
But since your first choice is a camper shell, and your exhaust concerns make sense, maybe you could rig up a small exhaust stack through the roof? Then bolt the generator to the truckbed for security. jon
B00merang is offline   Reply With Quote
Old 05-27-2015, 11:47 AM   #7
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Originally Posted by JBBeaubeaux View Post
Camper shell
Soft cover
Roll up
etc.
I'm in the same boat so not sure I can offer advice as much as to give this thread a bump and offer my current thoughts.
Right now I have an F-150 with a soft cover. I'm very likely getting a new truck and since I want to bring along bicycles and a generator (neither of which I currently bring) I am not going with a soft cover.
I would not get a one piece hard cover. I just see those as being too limited.
My current thought is to get a tri-fold hard tonneau and mount a few bicycle fork mounts to the cover itself in the 1/3rd of the cover nearest the cab. Then put the bikes right on the cover with the front wheels in the bed of the truck. The generator will be there as well. With the generator running I can fold the first 1/3 for ventilation. This would not work with a roll up cover.
The other option would be to rig up my own crossbar with fork mounts on it. I could obviously go with one of the manufactured "tower and rack" options but once you add the bicycle trays the costs add up quickly. This option could work with either a roll up or tri fold cover.
Not my photo but this looks like an elegant solution.
I'm not currently keen on the cap idea but I can see why people like that option. I just don't see how the bikes and everything would fit as nicely. If I went with a cap I'd consider mounting the bicycles on the roof?
Maybe with some solar panels? I know that's a whole 'nother discussion...
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 05-27-2015, 11:50 AM   #8
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
The jury is still out on whether to get a tonneau cover or a full camper shell. I like the style of the tonneau cover better, but the shell is more practical and affords more storage. If I get a shell, I don't want the cab high shell, but the high-rise shell so I can sorta pseudo walk around in it- albeit hunched over. Seems a bit easier to access stuff and can haul more stuff.
Flip side of that coin- tonneau cover is lighter and will eat up less available payload-
If you have a 2500 that is not as much a consideration, but I have a half ton-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 05-27-2015, 11:52 AM   #9
m.hony's Avatar
2013 30' Classic
Bikes standing upright in shell- kayaks mounted on roof carrier on top of shell-
With tonneau, bike front wheels removed and bikes lying on their sides under tonneau and kayaks on a roof rack on the truck cab-
Still leaning toward shell for more storage and keeping bikes out of weather-
TAC #MS-10
Airforums #70955
Old 05-27-2015, 11:57 AM   #10
patterson , Louisiana
Jim,
I have a Ford F 250 as my tow vehicle. I also have a Honda 3000 manual start genset. That is about the same as yours but the manual start and a good bit lighter!
My truck came with a removable liner, not my choice, but it works well. To prevent the genset and all other items from sliding around I installed outdoor carpeting using blind rivets around the edges. I set the genset against the front wall of the bed and used nylon straps to hold it in place, as it turns out they have been unnecessery. No kidding. I think that straps would be required if the genset was NOT against the back wall of the bed. It has been there for 5 seasons and over 45,ooo miles including a 6 month trip to Alaska.
For a bed cover I purchased an UNDERCOVER hard top. Now the Honda that I have just barely fits under it, but that is all that is needed so check closely before purchase.
Some brands of hard covers grant a bit more clearance.
I did not want the camper shell as I use the truck for my daily driver.
When using the genset I merely raise the topper, pull the genset toward the tailgate and crank it up. No fuss no muss. Oh, I keep the gas for it in the smaller containers, 2.5 gal. I think as they are much easier to handle. I also purchased replacement spouts to do away with the worthless ones that now come on gas containers. you know the new ones that cause one to spill every time.
CCC
Carmelo
Charles C Culotta, Jr.
SUPPORT OUR TROOPS
carmelo is offline   Reply With Quote
Old 05-27-2015, 12:10 PM   #11
Jim,
I hope that I am doing this picture thing correctly.
This should be a pic of the bed of the truck, the genset is under the white towel toward the back. All of this "stuff" stays in place without tie downs at all.
CCC
Name:	Pickup storage 2 (800x600).jpg
Carmelo
SUPPORT OUR TROOPS
Old 05-27-2015, 12:12 PM   #12
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
I have a cab high camper shell. I specifically ordered one that had windows that opened up on the side to access things.
If you get a camper shell that is higher than the cab then you have to stand on your tip toes or hang a string on the rear door to close it. My brother has this type on his Dodge truck - it is tall.
A tonneau cover seems very limited in some regards depending on what type you get. The camper shell just has more usable space and I have no trouble seeing the vehicles behind me.
If I had a generator I would place it towards the rear of the truck, open the tail gate and shoot the exhaust out the back. Keep airspace around the generator from the other stuff in the truck when it is running.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 05-27-2015, 12:38 PM   #13
Santa Clarita , California
Jim,
Here is another option (Pickup Pack from Highway Products) that I got from another forum on this site:
Pickup Packs by Highway Products Inc.
I have corresponded with Highway Products, and they are quite helpful so far.
Tod
Tod3 is offline   Reply With Quote
Old 05-27-2015, 12:41 PM   #14
m.hony's Avatar
2013 30' Classic
The string/rope/strap on the door is not a bad idea on the high rise shell. Box trucks/moving vans have this on the rear door.
Another option is to remove the tailgate and install a walk through door on the back of the pickup/shell.
TAC #MS-10
Airforums #70955
To cover or not to cover? steveirving Winterizing, Storage, Carports & Covers 9 07-28-2014 07:31 PM
to cover or not to cover tfetterer Winterizing, Storage, Carports & Covers 8 09-16-2008 12:14 PM
Cover or not to Cover? Sixty3TW4US Winterizing, Storage, Carports & Covers 7 09-16-2008 12:08 PM
To cover or not to cover vents? Director 1965 Overlander 4 10-28-2007 07:01 PM
To cover or not to cover goldenlily Winterizing, Storage, Carports & Covers 1 10-03-2005 11:48 AM
