Old 12-01-2006, 11:09 AM   #1
SilverCabin's Avatar
2014 27' Flying Cloud
Viera , Florida
Question Tires on the TV
My new TV came with P275/55 R20 Pirelli Scorpion ATR tires. The spare underneath however, is a P275/65 R18 (why would Ford do that?).
I love the look and ride of the R20's and they give me a little more ground clearance. I'm worried though how the ride and handling may change with the spare on. Also, do the 275/65 R18 tires provide more load capacity that the 275/55 R20 tires?
Would it be advisable to change the wheels and tires to all P275/65 R18's?
Randy and Pat Godfrey
Region 3 2nd VP, Florida Airstream Club (027)
WBCCI# 7591 - AIR# 17017
2014 27FB Flying Cloud - SilverCabin II
2018 F-150 Platinum - unnamed
A journey of a thousand miles begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 12-01-2006, 01:44 PM   #2
_
hi rgodfrey and welcome to the forums...
to save money thats why!
the spare wheel is less expensive than those 20 inch wheels.
your spare is 0.2 inches larger diameter than the other 4....
this should have zero impact mechanically IF the spare is needed for duty.
the spare has 1 inch higher sidewall...7 vs 6. but is basically the same overall size because of the 2 inch wheel difference.
approx 1/2 inch circumfrence difference
the higher sidewall could in theory, have an impact on high speed cornering, and steering.
but in real world use...nada.
you'll have to sort out the load ratings on your own. the info is on the side wall of both tires....and the pirelli web site.
for a small trailer and urban life in a mild climate, the 20s work.
the 20s need more attention to balance and alignment and wear issues and proper inflation.
with a bigger trailer or rougher roads, off roads, winter travel...the 18s would be a better choice.
for cross country trips or life full tiime on the road, i'd prefer a more widely available and less expensive tire/wheel combo than the 20s...
but they are sweet looking...
i wish ford offered a 'lincoln mark' version of the superduty!
cheers
2air'
Old 12-04-2006, 08:51 AM   #3
Viera , Florida
cheers
2air'
Thanks for the analysis. I knew there was a way to figure the sizes out. It's interesting that the 18s are larger in diameter than the 20s. If I changed to 18s do you think there is anything that should be done to any other systems, e.g., speedometer? Or, would I just be going a little faster than the readout says?
On the sidewalls it says the max load of the 20s is 2403 lbs @ 44 p.s.i. for the 18s its 2601 lbs @ 44.p.s.i. On the "B Pillar" sticker it says with the 20s I have a CCW of 1472 lbs @ 35 p.s.i., so that would probably increase by few hundred pounds if we had 18s on the ground.
For most of our use, it seems the 20s would be okay (600# tounge weight, 300# passengers yields 500# of extra cargo), so I don't think CCW is a problem. However, your comment on having a less expensive, more widely available combination is a good one. We are planning on pulling from Florida to Alaska and back in 2008.
Maybe I'll contact the dealer. Perhaps there is someone who bought a Mark LT with the 18" chrome wheels who would like to swap.
Old 12-04-2006, 09:26 AM   #4
_
you are welcome...
assuming the speedo is accurate (my ford isn't) with the 18s, 60mph would really be...
60.3mph, about 0.5 mph error.
for a trip to alaska i'd absolutely go with a more rugged common arrangement.
use the spare sizing/fitment (18s) or even 17s with a higher sidewall and narrower foot print...
'denelllen' here has your tv...he lost all the tires (4) on one side at one time, this summer to nails/screws.
pm him for info...he winters in gator land too...
i'm pretty sure the hardest replacements to find were the truck tires....
for comparison the f-250s come with 18s or 17s, 265 widtth, but 70 series sidewalls....
there are several 'tire size calcultors' on line to help sort this out..google it.
i use the 'miata' one because the graphic views help too.
tirerack.com or 1010tire.com are helpful sites too...
as for finding 18s, take a look on ebay or some of the 'ford' forums....
plenty of the 18s available...
you've got plenty of time to sort this all out...
have fun planning the alaska adventure...
2air'
i see you are going to the 'can openers' rally...
i'll be there as will denellen...we can talk tires then....
Old 12-04-2006, 09:29 AM   #5
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Tires on TV
Hi there Randy-
When we purchased our TV it didn't come with tires. There was a penguin on top of the teli but no tires.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 12-04-2006, 09:59 AM   #6
vonkamp's Avatar
Green Cove Springs , Florida
Okay- newby question here. What's a TV (other than the one I send too much time in front of)?
vonkamp is offline   Reply With Quote
Old 12-04-2006, 10:08 AM   #7
vonkamp's Avatar
I figured it out- Tow Vehicle. Yes??
Old 12-04-2006, 10:20 AM   #8
Viera , Florida
Yes, fellow newby. It took me by surprise when I first read it on another subject thread--couldn't see how what I was reading releated to the television .
Old 12-04-2006, 11:04 AM   #9
2005 22' Safari
1960 24' Tradewind
Does that mean there is a penguin on the Tahoe?
J. Rick Cipot
Sandi Gould
WBCCI #3411
AIR #17099
2004 22' Safari
1960 24' Tradewind
Old 12-04-2006, 11:34 AM   #10
vonkamp's Avatar
Now I'm thouroughly confused. So here's a picture of a rabbit with a pancake on it's head.
Old 12-04-2006, 11:48 AM   #11
2005 22' Safari
1960 24' Tradewind
Not a Rabbit
J. Rick Cipot
Sandi Gould
WBCCI #3411
AIR #17099
2004 22' Safari
1960 24' Tradewind
Old 12-04-2006, 11:56 AM   #12
_
ok now lets be careful tossing around that image.......
http://www.airforums.com/forums/193307-post9.html
by the way its a bunny...
also see posts 47/48 here...
http://www.airforums.com/forum...-21000-2.html?
not 2 mention you've completely hijacked this thread
for hijacking go here...
http://www.airforums.com/forum...ng-24723.html?
i see some real talent in this group....
cheers
2air'
Old 12-04-2006, 12:45 PM   #13
vonkamp's Avatar
My apologies, someone sent that to me about a year ago. I thought it was original but I guess not. My bad..
Old 12-04-2006, 12:50 PM   #14
Viera , Florida
I love you "right-brained" types, but I was really trying to be serious. Next time I'll spell out Tow Vehicle if it will avoid the silliness. Thanks 2air for trying to bring this back.
LT versus ST tires on a trailer 76Argosy Tires 18 08-29-2014 04:03 PM
need advice re. 1969 tires, brakes, etc. Dave Cole Tires 6 01-29-2007 06:04 AM
Goodyear G670 RV Tires??? TRAPEZE Airstream Motorhome Forums 16 11-27-2006 03:19 PM
61 Tradewind tires lee_jachter Tires 11 10-04-2002 12:00 PM
Best wheels & Tires... Andy R Wheels, Hubs & Bearings 4 04-15-2002 10:41 AM
