Old 11-01-2006, 02:54 PM   #1
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
Tire replacement on Expedition?
What do you suggest that I replace the Continental Contracs (265/70R17) with? I am accustomed to a squishy ride and sway seems to be no problem.
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 11-01-2006, 03:08 PM   #2
A salesman at Colony Tire recommended Mastercraft tires for my expedition. They have between 35 and 40,000 miles on them (most of the miles pulling the airstream) and have performed very well. Tred wear is very even and they should go at least another 15,000 miles. The ride is a little stiff but I think that is normal for the expedition.
Wayne
wayner1239 is offline   Reply With Quote
Old 11-01-2006, 03:41 PM   #3
Kistler's Avatar
2002 25' Classic
Thank you, Wayner.... I am not familiar with Mastercraft but will do a search around here (Tucson). I usually buy Michelins from Costco--that is--I have done that for other vehicles we have owned in the past.
The Continentals are okay. Most likely if the Expedition had come with stiffer sidewall tires I would have developed a liking for them BUT like I say I am now accustomed to the squishy ride.
I have now 24,000 miles on the Continentals and I believe they are about half gone. They seem quite "rounded"....could this be from the swing axle? or whatever you call Ford's attempt at innovation.
I don't corner fast but I do get the tires rotated every 6000 miles.
Kistler
Old 11-01-2006, 06:07 PM   #4
Kistler,
I don't have an answer to the "rounded" condition of the tires. One thing I don't like about Ford's innovation is the variable power steering. Other than that though I have been very pleased with the expedition.
I don't want to recommend the Mastercrafts over Michelins. If you don't mind paying a premium price for Michelins you should probably stick with them.
Wayne
Old 11-01-2006, 06:33 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The Michelins have a softer sidewall, and will tend to "bob and weave" more than most other tires. I am partial to Bridgestone tires, but it is probably more because of my ties with the company than them being a whole lot better than any other. The "rounding" is because of the new 4 wheel independent suspension. You should get the alignment checked when you get your new tires, no matter whose tires you wind up with. Most factory-set alignments are off a bit.
Old 11-01-2006, 10:29 PM   #6
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I just recently replaced my Continentals with Goodyear Eagles on my Navigator; Same size as yours. I preferr Michelins or Goodyears and nothing else. But in this size I didn't like the tread design on the Michelins.
Old 11-01-2006, 10:48 PM   #7
TIMEMACHINE's Avatar
Huntington Beach , California
Recommend Revos and Cross-Terrains
I had a Expedition and ran both Bridgestone REVOs and Michelin Cross- Terrains. I also have Cross-Terrains on my Lexus GX470. Both tires are great, the REVOs being a bit "softer" ride and a bit "stickier" while the Coss-Terrains have less side wall flex and will wear longer. These differences are small and such I would recommend either rating both as 9.5 out of 10, 10 being a free tire.
John
TIMEMACHINE is offline   Reply With Quote
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
spare tire? Chas Tires 14 07-04-2005 07:09 PM
Tire opinion Dbraw Tires 12 11-25-2002 07:39 AM
Tire code info FrankR Tires 1 05-20-2002 09:18 AM
