Old 06-10-2015, 04:19 PM   #1
2014 28' International
Frederick , Maryland
Tire pressure recommendation
I would appreciate any recommendations for the tire pressure on my tow vehicle. I have 2009 Suburban 2500 and a 2014 International Serenity 28 with a ProPride hitch. My normal tire pressure specification is 50 in the front and 60 in the back. The maximum PSI is 80.
AirReg is offline   Reply With Quote
Old 06-10-2015, 04:23 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I raise my normal tire pressures 3 or 4 lbs when towing. Seems to cut down on the sidewall deflection.
MICHAEL
Old 06-10-2015, 05:20 PM   #3
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Cipher up your total vehicle weight with occupants, cargo, and tongue weight. Find a load chart for your tires and pump them up to necessary pressure for the load. Go with some contingency, better safe than sorry. You've got a 3/4 ton truck chassis and have the luxury of adequate cargo capacity for a trailer that could hang 1100 pounds or more of tongue weight on it.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 06-11-2015, 05:22 AM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I put my tires at the max sidewall pressure. It makes it more stable (less sidewall flex/tracking) when towing and running solo. It does ride a bit rougher... but, constant changing of pressure in all tires is just too much hassle... as I tow as far as I run solo...
Now, if you only tow sporadically, then only max the pressure when towing.
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-11-2015, 09:12 AM   #5
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
A 120V compressor with a tank makes it easy before setting out. I only have ten tires to check, and you, twelve.
But max pressure on TV tires means max according to drivers door placard.
Old 06-11-2015, 09:29 AM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Agreed! My tires meet manufac specs.. Better tires do not compensate for overloaded frame, suspension or axle capacity.
So, if someone installs tires which can inflate to 100PSI, mount them on wheels which are designed and built for 50PSI, mount on a truck that has been overloaded beyond axle design limits, that is not wise and may even be foolish...
Old 06-11-2015, 09:33 AM   #7
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
With heavy load in the van along with almost 1,300 lbs of hitch weight from my Classic I use GM's recommendations for my 3/4 ton van. Those are 55 psi front and 80 psi rear when you are carrying maximum load. Your door sticker should have the recommendations if you are carrying a heavy load.
Jack
Jack Canavera
STL Mo.
AIR #56
Tire pressure monitor recommendation? jhfarrar Tires 118 10-09-2014 08:40 AM
Tire Pressure Gauge Recommendation Jodason Sprinter and B-van Forum 9 08-18-2013 04:11 PM
TV Tire Recommendation tslanier Tires 13 02-02-2010 03:45 PM
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 14 07-06-2008 08:34 AM
Canadian Tire's $129 Tire Pressure Monitoring System SilverCottage Tires 9 10-30-2007 07:55 PM
