Old 10-06-2017, 03:48 PM   #1
alymorales's Avatar
2005 25' International CCD
Mission Hills , Kansas
Tire pressure
I have a new Ford F-150 pickup truck. 2017. It has Pirelli tires. I've always owned michelin's. Any recommendations on a safe tire pressure for Towing?
alymorales is offline   Reply With Quote
Old 10-06-2017, 04:27 PM   #2
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
I don't have a Ford, but here is how I approached it on my 2017 truck. The manual states that the recommended tire pressures (33 Front/35 Rear) are the minimum pressures required to handle the maximum rated loads. The tires state on the sidewall that the maximum cold pressure is 44. Since I am under the maximum axle loads when towing, I run 35 in the front and 38 in the rear. That has worked great so far, and we did a 2 month, 8300 mile trip this summer. The truck handles well and the tires aren't showing much wear.
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is offline   Reply With Quote
Old 10-06-2017, 04:34 PM   #3
Mike from Canmore
Mike G's Avatar
2018 27' Flying Cloud
Calgary , Alberta
I would stay between the pressure recommended on the placard on the driver's door jam and the maximum listed on the tires. My Yukon recommends 35# for my Bridgestones, and the maximum is 44#. I run them around 38# while towing.
Mike G is offline   Reply With Quote
Old 10-06-2017, 05:25 PM   #4
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Tavares , Florida
I tow a 25FB International. I have a RAM TV with Michelin tires. The max. pressure is 44 psi cold. When towing I keep them at about 40 to 42 psi cold. Works well for me.
Old 10-07-2017, 06:19 AM   #5
alymorales's Avatar
Thank you!
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 19 07-03-2019 09:19 AM
Tire pressure and tire temperature questions Stewball On The Road... 20 01-17-2017 05:52 AM
Water Pressure: Shore pressure high, All pressure in trailer low.... bhooves Sinks, Showers & Toilets 9 10-16-2016 03:22 PM
Canadian Tire's $129 Tire Pressure Monitoring System SilverCottage Tires 9 10-30-2007 07:55 PM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
