Old 09-16-2015, 04:56 PM   #43
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I guess the difference with my Tundra is mostly flat land towing.
I guess it depends on where you are and where you are going.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-18-2015, 08:50 PM   #44
olympia , Washington
sub'd.
Xicaque is offline   Reply With Quote
Old 09-19-2015, 06:32 AM   #45
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
there tanks are nice indeed but for a grand or more, I would rather put a 36 gallon aux tank in the bed and pipe or pump to main tank. the tank runs $250 and pump is $125. that give me, after the hutch mod on ford tank, almost 31 gal on board, plus another 36 in tank is a bit better than the 61 Gal tank for 1300 buck and i have $1000 for fuel.. at local price if 2.39 gal that 239 gallons.. to ride on...
37 Gallon Vertical Transfer Tank | Agri Supply
Originally Posted by switz View Post
Check out Titan diesel fuel tanks:
https://titanfueltanks.com
I installed the 56 gallon tank in the same space to replace the stock tank under out 2012 Dodge 2500HD short bed. Similar tanks are available for Chevy/GMC and Ford.
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Old 09-19-2015, 07:24 AM   #46
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Only issues with the in-bed tanks are the loss of storage in the truck bed and additional fuel lines and valves to leak. One also has to use the in-bed fuel often to preclude issues in the fuel.
Those reasons are why I went with the Titan under body replacement of the stock fuel tank. My truck has the short bed for better maneuverability when towing and bed space was an issue. The entire fuel sup[ply is freshened after every fill up.
Old 09-19-2015, 12:59 PM   #47
Manheim , Pennsylvania
Well, problem solved. We are getting this truck. It's a 2012 F250 Lariat with a power stroke diesel.
Jukeboxfun is offline   Reply With Quote
Old 09-19-2015, 01:11 PM   #48
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Absolutely beautiful truck!
You are going to LOVE it!
(Funny..... when I went to your Photobucket, I saw a couple of pics that I had originally posted and you enhanced for me.....)
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 09-27-2015, 03:10 PM   #49
Here is a good photo of our new TV hooked up. The 2012 F250 diesel super duty with 90,000 miles on her should alleviate my worries about truck payload and towing capability. Thanks for all the input!
Old 09-27-2015, 03:37 PM   #50
PaulnGina's Avatar
Good Ol' , USA
Beautiful PowerStroke...... Beautiful Airstream!
You're gonna love the heck out of that truck!
1987 Avion 34W
Old 09-27-2015, 06:01 PM   #51
2016 30' International
Scottsdale , Arizona
Nice set up, Jukeboxfun! I'm sure it will serve you very well and give you a nice reserve of cargo capacity, as well as pulling, hill descent control, and braking capacity. The tail won't be wagging the dog, which is a reassuring, comfortable place to be. Congrats on your new set up!
DHart is offline   Reply With Quote
Old 09-28-2015, 03:07 PM   #52
carl2591's Avatar
2005 31' Classic
"said with Jaws music in background.."
"boys... were going need a bigger airstream""
that 6.7 is not ever breathing hard with that little AS back there.. My BIL has a 37+?ft 5iver he pulls and it (6.7L PS) breaks a sweat every so often.... but not much..
nice rig.. what are mpgs, loaded and unloaded
get a flat cover or go with a nice camper type cover and you will love it more.
[QUOTE=Jukeboxfun;1689674]Here is a good photo of our new TV hooked up. The 2012 F250 diesel super duty with 90,000 miles on her should alleviate my worries about truck payload and towing capability. Thanks for all the input!
Carl, Raleigh NC
Old 09-28-2015, 03:15 PM   #53
carl2591's Avatar
2005 31' Classic
If you have leaks from the bed tank you did not do a good job of installing it. also you mainly use it when traveling long distances to get to the cheap fuel. The difference between state can be 20-50 cents a gallon.. on a 35 gallons that only like $14 but when you do that 10 time you pay for the extra tank quicker.
these tanks are only like 9-11 inches deep so the bed space is still there.
not sure why ford does not offer a larger tank, yes i do they are cheap.. and not many people actually complain/buy on the tank size.. if they did more GMC's would be sold on that fact alone.
Carl, Raleigh NC
Old 09-29-2015, 07:51 AM   #54
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
We are spending 6 weeks traveling through the Midwest, and we haven't seen much difference in fuel prices 2.37 to 2.54, at Dearborn near the interstate it was 2.70. With the 36 gallon tank we fill most every day , I am not going to be hauling a bunch of unnessary fuel around....
Old 09-29-2015, 09:54 AM   #55
Rivet Loser
Punch's Avatar
La Ronge , Saskatchewan
Considering that you could pull the Airstream with a Mazda Miata, I doubt that you'll have any towing problems with the Ford. Unless you forget that the trailer is behind you that is!
A very pretty outfit indeed.
1989 345LE
Punch is offline   Reply With Quote
How many airstreamers thinking of getting a new Bowlus trailer scamp Off Topic Forum 48 07-22-2017 09:53 AM
Different Truck...same hitch bertheep Hitches, Couplers & Balls 7 09-25-2013 02:19 PM
New Member - Thinking of getting a classic Don Landis Classic Motorhomes 3 03-14-2009 08:07 PM
Different Looks on Different Computers COArgosy78 Forum Admin, News and Member Account Info 3 09-20-2003 02:38 PM
