Old 05-20-2009, 05:37 PM   #1
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
The Right Kind of Connection...
Soon we are going to get a truck at the end of this month and we are adjusting the truck to the Airstream.....On the Airstream, we have a six-hole plug. On the truck there is a plug also but we have not looked closely at it yet but will soon. For some time I have figured all those trailer plugs are the same...are they? What can anyone say to pitch in.
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 05-20-2009, 07:09 PM   #2
cameront120's Avatar
1972 25' Tradewind
The Airstream should have a seven hole plug. Did you count the hole in the middle? Some vehicles are set up with a 4-pin plug.
North Vancouver, BC
Old 05-20-2009, 07:10 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
The trailer connectors come in two basic varieties. Today, the one most commonly used is the 7-pole blade-type connector. When your coach was new, it very well may have had a 7-pole pin type connector -- these were common at the time and are said to be less prone to corossion problems. My rule of thumb has always been to have a new end for both the trailer and tow vehicle when changing to a new tow vehicle -- doing so insures that you will have everything you need when making the connections the first time.
Good luck with your project!
Kevin
P.S.: If you haven't towed this coach yet, be prepared for the possibility that it may not be wired to the modern standard as Airstream utilized their own schematic until not to very long ago. Some owners convert their coaches while others convert the tow vehicle -- by converting the coach, you simplify getting your coach safely to a campground if the tow vehicle is disabled and you must have a tow company tow the trailer to the nearest campground. When the alternator failed on my Cadillac, I was relieved that my Minuet was wired to the modern standard as the tow truck driver used his personal van to tow my trailer to the nearest campground.
Kevin D. Allen
AIR #827
Old 05-20-2009, 08:31 PM   #4
1970 27' Overlander
Alas. it truley is a seven hole...and we have towed this one from Amarillo to here in Altus, 200 miles away...The break lights worked and everything...now we still have to venture back to the truck lot and take the next look closer at what kind of plug it has, hope it matches...if not then do we go to an autozone or an RV center, there is an RV center outside of town and there is another in Elk City. Thanks, it really helps to have you guys (and Gals) back us up with your feed back. When we get to the point where we have the stablizer hitch we will be ready to make the maiden voyage.
Old 05-20-2009, 08:36 PM   #5
1972 25' Tradewind
Find out what the truck has and then, if necessary, you can get an adapter to get it to work for your 7-pin plug. Here are a bunch to illustrate what I mean:
Trailer & RV Wiring - Connector Adapters
North Vancouver, BC
Old 05-21-2009, 08:55 AM   #6
danalee's Avatar
1978 29' Ambassador
Walnut Cove , North Carolina
Images: 30
Congratulations on becoming independtly mobile. Be careful and have fun!
Dannie
The Silver Queen
danalee is offline   Reply With Quote
Old 05-21-2009, 12:50 PM   #7
1970 27' Overlander
The right kind of Connection
I shot up to the car lot and took these pictures ...here is the seven pin plug on the Airstream...and then the one thats on the truck now...from what I can see the one on the truck is a seven pin too, but its smaller and has round pins...whereas the Airstream has the six slots with the hole in the middle...I did bookmark the connection link and will go looking thru it too...Regardless, the one on the Airstream is in very good condition. By the way, what do you all think about the truck?
ID:	80635   Click image for larger version
ID:	80637   Click image for larger version
Old 05-21-2009, 12:53 PM   #8
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
The connector on the trailer is a 7-Blade type connector while the connector on the truck is a 7-Pin type connector -- they will not match up without changing one or the other or an adapter will be required.
Kevin
Kevin D. Allen
AIR #827
Old 05-21-2009, 01:40 PM   #9
slpiotro's Avatar
2007 23' Safari SE
Madison , Wisconsin
Send a message via ICQ to slpiotro
The adapter cords/adapter worked well for me. My issue was the LED lights on the 07 trailer working with the 7 blade on the tow vehicle, something about the computer not sensing the LED's because of draw. The adapter quickly solved the problem and all lights work all the time. I suspect that allows the alternative tow vehicle if needed, just by not having the adapter. Inexpensive fix, compared to the cost of rewiring the socket completely.
slpiotro is offline   Reply With Quote
Old 05-21-2009, 02:10 PM   #10
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Make sure the leads to the blades and pins are for the same things. I think the ground or 12v hot wire have changed positions in the past. Adapters may be for pin to blade, blade to pin, or for different positions of the leads, so check everything carefully to make sure you've got the right adapter. LED's may not work because some aftermarket ones have different polarity and the leads on the bulbs may have to be reversed, though I don't understand how a trailer plug adapter would do that, so this is news to me. I think Airstream owner's manuals tell you what each pin does, but I'd have to go out to the trailer to check. In my experience, wiring codes on vehicles are not always the same as the colors on the wires you have, or the colors on the wires are hard to interpret, so before you drive away, make sure everything works the way it's supposed to. If someone changed the plug on a used vehicle, make sure they didn't change the colors because they only had one or colors of auto wire.
Here's a website that explains more than you wanted to know, although I would do more research to make sure these guys have it right: Marksrv.com 7 way wiring diagram page
Gene
Old 05-21-2009, 04:36 PM   #11
1970 27' Overlander
Cameront120 if you get back to this thread, I am going to ask you if you can look into that site (and by looking at my photos) and see what kind of adapter we would need to order....Can you do that? I also called Andy at inland and am waiting to hear back from them.
Old 05-21-2009, 06:35 PM   #12
richinny's Avatar
2011 34' Classic
andy may tell you to convert to the round pin connector as they are self cleaning and much less prone to poor connections.
Ricky
Old 05-21-2009, 06:38 PM   #13
1972 25' Tradewind
I'm not sure what the appropriate adaptor would be. I don't see anything on that site for a 7-pin to 7-blade connection.
North Vancouver, BC
Old 05-21-2009, 07:04 PM   #14
1970 27' Overlander
Ok well next step I will ask the car dealer (a cowboy mechanic) about it in his knowledge. I am not looking forward to a major do over...and possibly this all will be easier than I think...and I will learn about something new...
Batteries - what kind? Devoman Batteries, Univolts, Converters & Inverters 61 09-07-2010 03:48 PM
What Kind and Where shermantic Awnings 2 01-06-2009 01:36 PM
What kind of uniqueness have you done? Alaska1966 Off Topic Forum 14 09-23-2007 09:28 PM
Airstream ad (kind of) trumpwer Off Topic Forum 3 09-24-2004 09:57 AM
Wi-Fi connection? Krazykraut Airstream Motorhome Forums 8 11-25-2002 11:46 AM
