Old 05-21-2009, 07:38 PM   #15
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
The Right Kind of Connection...
Greetings redhawkerII!
Originally Posted by redhawkerII View Post
Ok well next step I will ask the car dealer (a cowboy mechanic) about it in his knowledge. I am not looking forward to a major do over...and possibly this all will be easier than I think...and I will learn about something new...
Believe me, this is not a difficult job if I can handle it -- I am not a do-it-yourselfer, but have replaced the ends on both the tow vehicle and trailer -- it is not a terribly complex job. When working with the tow vehicle end, you will need a test light and probe. On the trailer side a pair of test wires with alligator clips as well as a small 12-volt battery for circuit investigation. The first time through, it took me about three hours -- now, I have it down to less than 90-minutes.
Good luck with your project!
Kevin
P.S.: Looking at the photos, I think that I would consider replacing both ends with new matched equipment. It appears that both ends have a fair amount of visible corossion. The connectors aren't terribly expensive in either blade or pin type.
Kevin D. Allen
AIR #827
Old 05-22-2009, 11:10 AM   #16
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
We (I remembered) have some friends down the street that we will consult with about this project...Butch, the fellow, is who was kind enough to come over and spend the afternoon hooking up our vent fan will probably go for this next project. So I will keep everybody posted and will look into the proper places for the correct parts for this....
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Batteries - what kind? Devoman Batteries, Univolts, Converters & Inverters 61 09-07-2010 03:48 PM
What Kind and Where shermantic Awnings 2 01-06-2009 01:36 PM
What kind of uniqueness have you done? Alaska1966 Off Topic Forum 14 09-23-2007 09:28 PM
Airstream ad (kind of) trumpwer Off Topic Forum 3 09-24-2004 09:57 AM
Wi-Fi connection? Krazykraut Airstream Motorhome Forums 8 11-25-2002 11:46 AM
