Old 09-09-2013, 04:53 AM   #1
Barefootdog's Avatar
2013 30' Flying Cloud
Tailgate Seal
We just bought a new F240 diesel and Flying Cloud 30 as we gear up to go full-time next year. We also installed a cap on the truck so we can store more stuff out of the weather. I've never had a pickup before and my brother in law was telling me I should install a seal around the tailgate otherwise dust and rain will draft into the bed of the pickup as we drive down the road. I'm wondering if anyone has experienced this problem and if you have installed a seal, which brand do you recommend? Thanks.
Barefootdog is offline   Reply With Quote
Old 09-09-2013, 05:09 AM   #2
JFScheck's Avatar
Rockville , Maryland
Images: 33
Did not have this issue with either my 1987 Toyota 4x4 with aluminum topper, 2011 F-350 with ARE Z-Series Topper or my current 2013 Ram 2500 with another ARE Z-Series topper...
I think you will be fine...
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 09-09-2013, 05:10 AM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Howdy!
Longtime truck owner here. I had a cap on truck, 1987 F150. Only slight moisture problem.
I also had sliding glass on truck and cap so I could get some AC into bed of truck. We built a suspended deck in truck bed, stowed gear beneath and air mattress on top. Travelled all over like that. Only water in bed once where things got damp. So I built another suspended floor on bottom and could slide it in/out for access.
If you seal, I would just put tape on inside seam of tailgate to see if that helps.
Any "dust" I saw was around lower seam and only if I had windows open allowing air movement inside.
First, take on really dusty road. Then garden hose the area by rear if cap. If cap is properly fitted, there should be little penetration.
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-09-2013, 05:41 AM   #4
LFC
Memphis , Tennessee
Cabelas sells a tailgate seal.....unless you want dust in your bed you'd best install one.
LFC is offline   Reply With Quote
Old 09-10-2013, 06:18 AM   #5
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
The seal is worth the small time and trouble. A cap increases the air pressure exerted on the rear of the truck, so to speak, and dust in the bed increases. May not matter where you live, but where I do the seal was a real help.
Old 09-10-2013, 08:08 AM   #6
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Older trucks may have had this issue but I don't think you need to worry about it with any late models. I have an '06 Dodge 3500 and I never see any significant amount of dust in the enclosed bed area. If you see a need then maybe you can think about it later.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 09-17-2013, 10:11 AM   #7
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
It isn't the year model so much as the local climate. Your truck is identical to mine so far as body gaps are concerned. And, as cleaning an 8' bed top to bottom and front to rear under a topper is no small job I highly recommend this cheap modification . . unless one enjoys this type of cleaning after a trip out West. Or after a drought. Etc.
Dust, heat and humidity (think condensation) make getting something from the bed a dirty job. Highway speed travel just worsens the problem: both the volume of dust, and the turbulence -- however low -- in the bed.
Old 09-17-2013, 02:44 PM   #8
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Pep Boys, and most any place that sells toppers, bedliners, etc. will have the seals. About $30. They are peel and stick and once in place really stay put. I have a seal on mine.
John W. Irwin
WBCCI #9632
Pahaska is online now   Reply With Quote
