Old 03-07-2004, 12:24 AM   #1
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Tailgate fell off my GM pick up!
My son is home from college on spring break this week and had a bad experience this evening. While driving my 2500hd he went over a bump, the tailgate latch apparently opened and the tailgate fell open. It broke the passenger side cable, fell off and was dragging on the road. It swung over to the driver's side and scrapped about 8" of paint off the side of the truck lower quarterpanel not to mention about 12" off one side of the tailgate.
I'm still seeing red! Do you think this would be covered under warranty or road hazzard or what? I've also heard there is a lawsuit against GM concerning the cables and after looking on that cable I can understand why. It sure was thin.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 03-07-2004, 12:47 AM   #2
qqq
qqq's Avatar
I found the tailgate cables on a y2k Silverado to be very tough!
They help carry the weight of my slide in camper (9.5 camper on shortbed truck...) never broke yet...
Hart
qqq is offline   Reply With Quote
Old 03-07-2004, 06:22 AM   #3
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
David, this has been an ongoing complaint with GM pickups on other forums. I was hauling some buckets of sand for our 30th class reunion and the fellow that was providing them, brought them over to the truck with a tractor w/front end loader. He lowered the bucket on the gate and broke both cables.
On The Diesel Place Forum on of the forum members is manufacturing the old style tailgate straps, from flat stock. You may have to do some poking around on that site to find it though.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 03-07-2004, 07:08 AM   #4
There is apparently a NTSB investigation into accidents relating to broken tailgate cables on GM trucks.
Meanwhile, I personally would expect full warrenty coverage on two counts: 1) The failure of the latch, and 2) failure of the cable.
Mark
Old 03-07-2004, 07:19 AM   #5
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
been there done that!
craig
had both of mine break when i was loading my bike!
upon close inspection i found the cables to be rusted under the vinyl covering.
when i purchased new ones, the replacement cables had silicone or something similar inserted in the end of the cable ferrules to prevent water entering the cable assemblys.
so they know there is a problem and have tried to fix it.
word to the wise, if there are any bulges in the vinyl coverings they are about to let go!
if anyone can find the retro fit straps let us know!
until i get something better the tailgate will come off before loading anything heavy!
john
you call them ferrets, i call them weasels.
Old 03-07-2004, 07:54 AM   #6
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
after some years of working for car dealerships, my opinion is warranty probably would not cover, however the dealer might help you under his allotment for "policy", where he can use his disgression to assist owners. Also if they aren't helpful, the area service rep from GM can do a similiar thing and use discretionary funds to cover some of the cost. Enough complaining to the right people done in the right way might bring a better conclusion.
Wish you luck with it.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 03-07-2004, 09:02 AM   #7
davidz71's Avatar
1986 25' Sovereign
johnhd
Is this what you mean? www.vrstraps.com
Craig
AIR #0078
3.73 rear end
Old 03-07-2004, 09:28 AM   #8
Tin Hut's Avatar
2005 28' International CCD
Pagosa Springs , Colorado
warranty
Last year the transmission on my '97 Suburban went out with only 46,000 miles (non-towing) on it. It had been serviced regularly and babied since we got it new. The dealer was unwilling to negotiate even though they agreed it was a "premature" failure. I contacted the General Motors service rep and documented by concern. They requested docs, receipts etc. and after 4 months and several very cooperative emails I received a check for 40% of the $2,225 cost to replace the tranny. I'd list all costs including repair/painting cost due to the damage and see what they can do for you. Good luck
"would you rather have a mansion full of money or a trailer full of love?"
Tin Hut is offline   Reply With Quote
Old 03-18-2004, 09:58 AM   #9
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Exclamation GM has recall on tailgate cables!
Recall on the tailgate cables as found via CNN today:
http://money.cnn.com/2004/03/18/pf/a...ex.htm?cnn=yes
Eric
Old 03-18-2004, 11:45 AM   #10
uncleneal's Avatar
I've already bought new cables to replace the broken ones on my 2001 Z-71, and had to have the 4th gear clutches replaced in the trans at about 48K. The dealer split the cost of the trans work with me. (Half of $800 - If it goes out again, I'm going to trade it or put a stick in it.) I wonder if GM is going to give refunds to those of us who have replaced the cables.
I noticed that the guy who makes the flat bar replacements makes you sign a statment of absolutely no warranty, no liability and no lawsuits.
Neal
uncleneal is offline   Reply With Quote
Old 03-18-2004, 11:53 AM   #11
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Re: been there done that!
Originally posted by john hd
craig
john
I can attest to this one! Scared the h*ll out of us! Nothing quite like a Harley teetering above you on an apparently broken tailgate to get the adrenaline goin', eh John!
I LIKE your tailgate-off plan! We'll PLAN on doing that this year in Davenport!
Roger
Old 03-18-2004, 07:28 PM   #12
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
roger
nothing makes it more fun than doing it in a downpour!
john
Old 03-18-2004, 07:54 PM   #13
pyanke's Avatar
1985 25' Sovereign
St Cloud , Minnesota
Recall
Gm has announced a recall for the tailgate cables. Owners will be notified. Seems they rust and the tailgate falls off.
Pete
WBCCI #7528
MN Unit
pyanke is offline   Reply With Quote
Old 03-18-2004, 08:07 PM   #14
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
quote from the cnn site
The company said if the cables are corroded, they may fracture when loads are applied to the tailgate. Any customer who has a cable break should notify their dealer immediately
guess i'll be calling my dealer
john
Equalizer and Tailgate clearance questions for new TV and trailer Westfalia Hitches, Couplers & Balls 15 05-31-2010 08:00 AM
Tailgate EasyLift BillTex Tow Vehicles 12 03-20-2010 09:07 PM
on my way to pick up my new AS remcolent Off Topic Forum 8 11-06-2006 07:41 PM
pick this ones for you... norbert Off Topic Forum 0 03-12-2004 09:15 AM
a ? for PICK sovereign Awnings 2 07-25-2002 07:13 PM
