Old 12-09-2014, 10:09 PM   #29
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I ordered a Tailgate Defender. To me, this seems to work better than the locks that go around the hinge.
Name:	Tailgate Defender.jpg
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 12-11-2014, 11:45 AM   #30
dznf0g's Avatar
Oswego , Illinois
Originally Posted by pappy19 View Post
Tailgate locks are the same mechanism as a door lock and takes about 5 seconds with a screwdriver to open up a tailgate lock. If you are really concerned about theft, tailgate of otherwise, the Jimmi-Jammer products are very cheap insurance.
Maybe.....but understand this is a drive by 10 second grab and run theft mode. If it's locked, they move on. We can tell this by parts sold on non-locking population vs. locking population.
Also the thief only gets the $$$ they are looking for by moving undamaged pieces which require no paint or sheet metal repair.
Relative to flea market, etc. hot pieces.....many manufacturers now put special VIN stickers on all body panels (and other pieces). When they are removed, it leaves tell tail remnants behind that can really only be removed by disturbing the paint surface. Not foolproof, but gives law enforcement, and you (if you are considering a used gate) a clue if it is hot. If it's got the label still, you can check if it's hot as well.
-Rich-
Old 12-11-2014, 02:56 PM   #31
mefly2's Avatar
2015 25' FB Eddie Bauer
Originally Posted by Jim & Susan View Post
Just out of curiosity, what kind of truck is this? I've never heard of a tailgate being stolen. And why would anybody do that? In other words, what makes them so valuable? Strangest thing I've heard in a while.
I searched for two (in my professional role in LE) that were stolen and only recovered one. The thieves ditched it fairly close by as they were apparently not ready to transport the weight without mechanical assistance. Estimates to replace were $900-1400 when I took the report... back up camera, mounting hardware, paint to match, etc
Old 12-11-2014, 03:15 PM   #32
2007 22' International CCD
Toyota Tacoma and Tundras are infamous for tailgate theft. It was attempted on my 08 shortly after I bought it. The shell kept the thief from easily making off with it. I installed an electric lock from Pop'n Lock plus a pivot protector. Still hap people attempting break and enter with damage. Quit driving it to work...
For some reason, nobody messed with the beater 02 Taco--which also had multiple locks on the tailgate. Probably because the PO had done a bad paint job on the tailgate. 😃
KE4GNK/AE
Old 12-15-2014, 09:49 PM   #33
Salem , Oregon
Images: 18
Hi, today in the mail I got my Tailgate Defender. I didn't want to remove my tailgate to do this simple job and I didn't want any scratches either. I started with a long handle 3/8" ratchet, a 24" long extension, and the proper Torx socket. This was so I could keep the Torx socket as in line as possible with the bolt. My ratchet popped, the bolt was still tight, and the ratchet had reversed it's self. Now it was time to try something else. [I'm not bringing out the air tools for one bolt] Next I used a 1/2" ratchet, an 1/2" to 3/8" reducer, A short 3/8" extension, and my Torx socket. Now it started to come out, but at a few turns, it was so tight still that I thought the Torx bolt was going to break before coming out. I cranked it back in and started it out again. Finally it came out. The only concern while going back together was to keep it centered so it wouldn't rub on anything or touch the inside of the tailgate when closed. The job is now done and this little piece of metal is thicker and stronger looking than it was in the pictures. I'm happy that I chose this option, but one of the reasons for this long story is to let you know that the little "L" shaped Torx tool that comes with this kit isn't going to work.
ID:	228693   Click image for larger version
ID:	228695   Click image for larger version
2005 Safari 25-B
Old 12-19-2014, 06:45 AM   #34
FLMarine's Avatar
2009 27' FB International
_ , Florida
I got a tailgate lock several years ago when I got a topper. I wanted to be able to lock the back so I got a tailgate lock online at genos garage for about $60. The lock replaced the entire tailgate handle and looked the same except for a keyhole. The same place I ordered it from no longer has the one I ordered, but now has one that you can wire into your keyless entry so it locks with your doors.
I didn't get it to prevent tailgate theft at the time, but now I keep it locked almost all the time. I'm sure a hard pry or something the thief's have will defeat it, but it will delay them so I suspect they will move on. It's worked so far in the 5 years or so I've had it on there.
FLMarine is offline   Reply With Quote
GPS Anti-theft device - A Nerd's Approach RKL1954 General Repair Forum 14 07-17-2015 10:37 AM
Deer alert devices Minnie's Mate Tow Vehicles 33 11-01-2008 01:27 AM
Anti-sway Devices MURPHY4385 Hitches, Couplers & Balls 7 05-21-2007 12:48 PM
Low Cost Effective Anti Theft For As!! KIMILI Insurance & Claims 12 11-13-2003 11:41 AM
