Old 03-25-2008, 12:46 PM   #15
Overlander & Sea's Avatar
Gulfport , Mississippi
Images: 30
Originally Posted by bobkelly
Be sure to check the backing capability of the hybrid. I understand the transmission does not have a reverse gear and that backing up is handled by the electric motors.
From GM, "The Two-mode Hybrid Transmission contains two 60kW electric motors, each capable of producing 272 lb-ft of torque.........All vehicle movement in reverse is performed by the electric motors in the transmission. In order to maintain the proper charge in the drive motor battery assembly, the engine will run when the vehicle is in reverse, however, there is no mechanical connetion between the engine and the drive wheels in this range."
Rick--Airstream of Mississippi www.foleyrvcenter.com
WBCCI #9275 TAC #MS-5 AIR #11800
Overlander & Sea is offline   Reply With Quote
Old 03-25-2008, 02:04 PM   #16
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Phew! Could you imagine having to push one of those backward! Glad they have a solution for backing up.
Family of Disney Fanatics
WBCCI# 4821
Old 03-25-2008, 02:35 PM   #17
Images: 30
But the other news is that the tailgate on the Tahoe Hybrid is made of aluminum! Maybe it could be polished to match the Airstream.
Old 03-26-2008, 08:39 PM   #18
bobkelly's Avatar
2003 22' International CCD
Whittier, California , Depoe Bay, Oregon
Subfan---I notice we are neighbors. I tow with 5.3L Tahoe's using 3.73 and 6.0 Yukon using 3.73 The change in performance in all senses of the word is very gradual as the trailer wt increases. A thousand lbs is no change, while 4-5 thousand is clearly noticeable but not uncomfortable while 7-10 thousand degrades the experience to the point where you wish your tow vehicle had more capability. Driving down Beach Blvd to the ocean is one thing. Up and down mountain roads at Eastern Sierra elevations (6-10,000 ft) is quite another.
2003 22ft CCD Int'l
2005 GMC Yukon Denali
WBCCI #2960
bobkelly is offline   Reply With Quote
Old 03-26-2008, 10:35 PM   #19
TahoeStream'n
subfan1's Avatar
2012 20' Flying Cloud
La Habra , California
Yeah we are close Bobkelly, thanks for the reply. How is the short wheelbase of the Tahoe affect the tow experience? Power with the 5.3 will be an issue but, we were looking at the Tahoe LTZ with the 6.2l and 6 speed auto.
We are also looking at a Sierra Maxvortec with tow package. 1/2 ton
We can't decide?
subfan1 is offline   Reply With Quote
Old 03-27-2008, 08:48 PM   #20
bobkelly's Avatar
The shorter wheel base of the Tahoe, 116 inches, is not a plus, but good enough for our 22ft 5000lb GVW trailer. My reference point is a one ton, FWD, crewcab, 8 ft bed, big block, silverado.
I'm glad to hear that the Tahoe has been given the 6.2l/6 speed.
2003 22ft CCD Int'l
WBCCI #2960
'61/'99 Hybrid GT1963 1997 -2001 Excella 9 07-12-2008 01:38 PM
Looking at Hybrid and Vintage Tow Vehicles rec Tow Vehicles 16 06-28-2007 09:20 AM
Hybrid Silverado truck MJBear Tow Vehicles 12 05-30-2007 07:34 AM
Towing an Airstream with a Highlander Hybrid ljmiii Tow Vehicles 57 03-22-2007 12:28 PM
GM hybrid pickup Silvertwinkie Our Community 9 07-25-2004 02:39 PM
