Old 09-23-2011, 07:11 AM   #15
2012 27' FB International
Boulder , Colorado
Originally Posted by Aviator View Post
The first three outings we made were with a Reese w/d setup. While i didn't have any controlability issues, I still got an uncomfortable amount of sway when passed on either side by 18 wheelers. The Ford system didn't dampen that at all. The P3 eliminates all of that. I have had the Ford system activate a couple of times when I have taken downhill curves too quickly even with the P3 attached. This was more of an instance of the trailer pushing the back of the truck in the curve. In that case it worked well together.
Bingo. Thank you sir, this is the feedback I was looking for. P3 it is.
motozen is offline   Reply With Quote
Old 09-23-2011, 07:17 AM   #16
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Originally Posted by ROBERT CROSS View Post
Sorry... I must have mis-read this post.
The P3 is a controller right?
You're right, I use a Prodigy P3 brake controller in my truck.
The OP is referring to a ProPride hitche. Usually people refer to the ProPride as PPP or 3P rather than P3, so it's just an ambiguous abbreviation altercation.
— David
Old 09-23-2011, 08:07 AM   #17
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Yep....my bad.
3P will definitely eliminate sway, P3 will definitely stop the AS.
Got It!
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
“It’s a crooked piece of time that we live in….”
John Prine
Old 09-23-2011, 08:34 AM   #18
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
MAXBRAKE would be a better choice than the P3. Much better.
Old 09-23-2011, 09:35 AM   #19
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Originally Posted by LaBigDogs View Post
Just back from a 3 week 2500 mile trip to Jackson Center OH.... 2011 F-150 EcoBoost 4X4 Platinum added RoadMaster springs ... Pulling a 2011 25FB ... hitched it up and went.... steady and flawless.... Ford would take care of the sway... but none.... Thats is why I purchased the Airstream.... low center of gravity, aerodynamic and ez 2 tow......
Looks in your photo there is no weight distribution/sway control hitch. Unusual with this size trailer. Did the steering feel okay, headlight alignment, any push when trucks passed, side winds?
Old 09-24-2011, 07:23 AM   #20
Boulder , Colorado
Sorry for the confusion...newby mistake...will use 3P from now on.
Old 09-24-2011, 07:38 AM   #21
dznf0g's Avatar
Oswego , Illinois
moto,
From what I understand all the systems being offered are reactive, they only start to work after the sway has started. Using the TV braking system to bring it under control.
Even the most basic of sway control hitches have a pro-active element, friction being the least of these.
Bob is correct. I can only speak to the GM system, but the electronic sway control utilizes the steering angle sensor and yaw sensors to detect when there is an even slight deviation between direction of travel and steering angle. The system can then apply brakes one wheel at a time as necessary to bring you back in line....and react a lot faster than the driver can. It is also tied into stability control and ABS, so it is a little more complex than this simple explanation.
BUT, the point is , it is a reactive system. I would advise a good WD, sway control hitch setup. They are preventative. The systems will work in concert.
Old 09-24-2011, 06:52 PM   #22
Western slope , Colorado
Ok, sorry....P3...3P...3PO (star wars)....get them all mixed up???
"If you come to a fork in the road, take it."
Yogi Berra
Streamside is offline   Reply With Quote
1972 Airstream Ambassador 29 Ft. Rear Bath Model with Reece Hitch and Sway bars eBay Watch Airstreams on eBay 1 09-26-2011 08:59 AM
Sway Control kimelaine Electrical - Systems, Generators, Batteries & Solar 4 08-22-2011 11:39 AM
Sway control Stumpjumper Hitches, Couplers & Balls 27 05-24-2011 02:20 PM
Hitch sway or weight or both!!!! Luc_DK Hitches, Couplers & Balls 5 03-29-2011 08:22 AM
67 Caravel Help: to sway or not to sway vonzellen Hitches, Couplers & Balls 15 01-26-2011 05:07 PM
