Old 12-10-2003, 08:34 AM   #1
dmreilly10000
dmreilly10000's Avatar
Profile:  1953 25' Cruiser
Brandon (near reservoir) , Mississippi
Images: 14
Surburban 1/2 ton as a Tow Vehicle
I have a chance to buy a 1999 1/2 ton Suburban, 5.7 liter, for $12,700 (loan value) from a friend of mine. It has 32,000 miles and is in like new condition.
The only problem is that I have a 34' Excella.
If I stayed out of the mountains, could this be used as a tow vehicle?
Has anyone towed a tri-axle 34' Excela with a half ton Suburban? If so, how did it work and did you make any modifications to the truck?
Thanks in advance
dmreilly10000 is offline   Reply With Quote
Old 12-10-2003, 10:18 AM   #2
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 104
Greetings!
You would be approaching 200% of the rated tow capacity for the C/K 1500 Suburban for 1999 - - it was either 6,000 or 6,500 pounds - - I know that it was just barely sufficient for my '64 Overlander which is why I ordered the K2500 (with 10,000 pound trailer tow package). It would be ill-advised to consider such a light-duty tow vehicle for a 34-foot Airstream (IMHO).
Kevin
Kevin D. Allen
AIR #827
overlander64 is online now   Reply With Quote
Old 12-10-2003, 10:19 AM   #3
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
I may not be qualified to give you advice, because I don't tow a 34ft trailer, but I do use the same tow vehicle you are considering.
My advice would be NO. I believe that the tongue weight and gross weight is too much for the 1/2 ton Suburban. It is rated to 6500lb max, and less if it is 4WD. If there is no factory tow package, then it is even less than that.
I get along very well with my Tradewind and the Suburban, but that's a far stretch for the 34 footers weight and tongue weight. The 1/2 ton Suburban brakes and transmission are marginal at best, and you would be asking for trouble and undue repairs, in my opinion. The 1/2 ton Suburban as you described it does make a fine and economical daily driver, though. I have seen better than 18mpg hwy, and 14-15 city. Towing drops it to 12mpg.
I believe the 34ft trailer would fully use the capacity of a 3/4 ton Suburban with 4:11 gears and the 454.
Good Luck!
Uwe
Old 12-10-2003, 10:45 AM   #4
dmreilly10000
Images: 14
Thanks for the advice. Since posting this, I have done some further research and have come to the same conclusion.
Too bad, it is a beautiful truck.
