08-30-2016, 06:15 AM
#21
Mantua
, Ohio
Facts? Documentation?
09-04-2016, 06:57 AM
#22
Loretto
, Ontario
Originally Posted by Toutsi 1957
The Ecoboost are good on paper but these are car engines. I have met a lot of people on campground using Ecoboost and those making a lot of miles while towing are replacing the turbos regularly or go back to V8. In Canada Ford is now selling the Ecoboost 3.5 at lower price than the V8, with same equipement, because people needing working or fleet vehicle no longer buy the truck with the Ecoboost. They do not have the required reliability.
In Canada the base engine is a 3.5L V6 non turbo the 5L is a $1800 option and the 3.5L Ecoboost is $2500. The Ecoboost was designed specifically for the F150. I know several people with this engine as well as a Ford mechanic and have heard nothing about turbo problems or reliability issues.
09-15-2016, 09:02 AM
#23
Saint CHarles
, Missouri
Toutsi 1957
I have the same question. Are you speaking from personal experience, if not, how did you come up with comment on the ecoboost vs the v8?
10-01-2016, 06:18 AM
#24
2017 28' International
Virginia Beach
, Virginia
Any suggestions on keeping the silicone boot to the turbo intercooler attached. It blew off while towing.
10-01-2016, 08:44 AM
#25
Rivets?
1992 29' Excella
2010 22' Interstate
Van By The River
, Georgia
I was confused by the title of this thread and expected to see information related to the Ford Super Duty truck. Now that I see the discussion I'd like to suggest a web site for the OP to check regarding truck tests - gasoline, diesel, 1/2 ton, 3/4 ton and much more.
Take a look at The Fast Lane Truck. The site can be a bit overwhelming at first because they test all sorts of trucks. Look around a bit and I think you'll find some useful information.
http://www.tfltruck.com/
Lucius and Danielle
1992 29' Excella Classic / 2010 Interstate
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
10-04-2016, 08:07 AM
#26
1994 30' Excella
alexandria
, Kentucky
I would try cleaning the surfaces with a solvent to remove any dirt or grease.
It may be possible to use a bit of Permatex Aviation Form A Gasket.
https://www.permatex.com/products/ga...ealant-liquid/
Check the clamps you are using. Are they worn out?
Hensley Arrow hitch with adjustable stinger
WBCCI # 3072
10-04-2016, 11:18 AM
#27
2007 30' Classic S/O
Somewhere
, South Carolina
Check service manual for correct tightening torque and possibly an incorrect type of hose clamp. On my Cummins these have coil springs to maintain tension.
10-04-2016, 12:46 PM
#28
Oswego
Those are called "constant torque hose clamps" if you are shopping for them.
-Rich-
10-04-2016, 05:51 PM
#29
Somewhere
, South Carolina
Yeah, those thingy's. Not to be confused with the Leaks-A-Lot version.
