Old 05-11-2009, 09:02 AM   #1
Davis's Avatar
1996 34' Excella
Americus , Georgia
Suburban tire info ?
I have a 2004 Suburban 1500 with P265/70R/17 tires and they are needing to be replaced. I have contemplated putting on a LT type tire with a load range E for when I occaisionally tow the trailer. Will the factory tire pressure monitor system be affected since you can run higher air pressures ? Also will the factory aluminum wheels be affected by running a LT tire ? Thanks for any advice. Davis
1991 Airstream Excella 1000 34ft (SOLD)
1994 Chevrolet Crew Cab dually 2WD 6.5td
2005 Chevrolet Suburban LT 1500 2WD 5.3
WBCCI # 10219 Georgia Unit
AIR # 5131
Davis is offline   Reply With Quote
Old 05-11-2009, 09:58 AM   #2
bobkelly's Avatar
2003 22' International CCD
Whittier, California , Depoe Bay, Oregon
I don't have the specifics on max pressure for your wheels in front of me, but someone will chime in soon that does. Ditto the pressure sensors. They should work just fine up to their limit. I use LT tires on my 1/2ton Yukon but I run at reduced pressures compared to the max rating on the tire casing.
2003 22ft CCD Int'l
2005 GMC Yukon Denali
WBCCI #2960
bobkelly is offline   Reply With Quote
Old 05-11-2009, 01:36 PM   #3
Davis's Avatar
1996 34' Excella
Americus , Georgia
Thanks for the reply. Do you know what the high limit pressure is ? Also have you had any sway problems when you run at the reduced pressures ?
AIR # 5131
Old 05-12-2009, 07:31 AM   #4
Davis's Avatar
1996 34' Excella
Americus , Georgia
Has anyone else upgraded their tires to a LT type on a GMC/Chevrolet suv or pickup with the factory alum. wheels ? If so what is your experience ?
AIR # 5131
Old 05-12-2009, 08:46 AM   #5
bobkelly's Avatar
I haven't experienced sway with either the original equipment tires or the LT replacements. The originals I ran at 35 psi, their max rated pressure and the LTs at 45-50 psi. The LTs feel better than the originals in everyday operation. Be sure to see the thread by RDM16CCD about the relationship between the number of plys and blow out resistance.
2003 22ft CCD Int'l
WBCCI #2960
Old 05-12-2009, 10:55 AM   #6
HowieE's Avatar
Princeton , New Jersey
Images: 12
There is no reason to increase the tire pressure because you are using E rated tires. In fact that is WRONG. Tire pressure is set by the weight on the axle not what is printed on the tire of the door post.
I run E rated Michelins on my 2500 Sub and my Excursion at 50 lbs. Please refer to the inflation chart for the correct pressure. Charts are the same for all tires of the same type and size by Federal Reg.
http://www.goodyear.com/truck/pdf/da...dInflation.pdf
2004 Excursion 4x4
Old 05-15-2009, 08:16 PM   #7
Davis's Avatar
1996 34' Excella
Americus , Georgia
I took the burb in for a checkup and had new Michelin LTX A/S LR E tires put on and so far they are smooth. I have bought michelins before but it has been a while and these are the most expensive tires I have ever purchased but I hope they will last a long time. The dealer installed them and said there would be no problem with the tire pressure monitor system or the wheels. Can`t wait to see how they perform on the highway and with the trailer.
AIR # 5131
Need info on 2500 Suburban w/8.1 eng. Davis Tow Vehicles 22 12-12-2007 08:32 PM
Low tire warning info???? Orland Dewey General Motorhome Topics 0 11-04-2004 09:18 PM
2004 Suburban/Chevy truck wiring info Silvertwinkie Electrical - Systems, Generators, Batteries & Solar 6 10-09-2004 11:50 AM
Info Request from Suburban Owners MileHigh On The Road... 32 01-28-2004 06:16 PM
Tire code info FrankR Tires 1 05-20-2002 09:18 AM
