04-26-2010, 08:31 PM
2007 25' International CCD
Sugar Grove
, Ohio
Suburban info, please..........
I have been studying which TV would be the best replacement for pulling our 25' International (2007). An '06 Silverado 2500 HD with a small diesel seemed to be the favorite of most but we've decided we're not pick-up folks so continued our search. A 2500 Suburban seemed to keep coming out at the top of the list, but I've discovered they are rare birds. One dealer I talked with today told me he hadn't sold a 3/4 ton Suburban in more than ten years. My question to the knowledgeable out there.... Will a 1500 Suburban with a 5.3 L gas engine pull my 25' International over the mountains??? My 5.6L Armada has the power to do it, but doesn't have the brakes, the tranny cooler or the wheelbase to be a comfortable TV. Is a 1500 Suburban (2007 or '08) powerful enough for the Smokies and the Rockies??? We are minimalist as far as additional weight is concerned - only two of us - no animals, etc... Appreciate ANY/ALL responses. Thanks.
04-26-2010, 08:44 PM
1978 28' Ambassador
Kenton
, Ohio
Have you looked at the new VW Touareg Diesel? Not the older 10 cylinder but the new 6? It looks pretty nice, good mileage and plenty of torque. It might be worth a look. There has got to be a 3/4 ton Suburban around Columbus somewhere.
"Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid." -- Frank Zappa
04-26-2010, 08:54 PM
1978 31' Sovereign
Cookeville
, Tennessee
We pull our 31' Sovereign with a 2004 Z71 Suburban 1500 w/transmission cooler. Pulls without much trouble.
04-26-2010, 09:20 PM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
We have a 2005 25FB, named Lucy, That we have pulled over 50,000 miles with our two 2500 Suburbans. Lucy weighs in at 7400# ready to camp. The 2500 suburbans do really well with Lucy in all circumstances.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
04-26-2010, 09:44 PM
Aluminut
2004 25' Safari
The 1500 will do it, but I too have a 3/4 ton. I am fairly skeptical of what the dealer told you. The 3/4 ton is not as rare as you've been led to believe. Sure there are more 1500s than 2500s, but that's the beauty of going to a dealer, they have access to the nationwide inventory. My guess is you may have come across a lazy dealer who simply wanted to sell you what either they had in stock or could get a bit more easily.
The lines between 1/2 ton and 3/4 ton have blurred a bit since I got my 2500, but I will tell you first hand towing a 25er w/ a 2500 is a wonderful combo that you won't be disappointed with.
04-27-2010, 01:43 AM
NE
, Indiana
You can go to Autotrader.com. (or use the link below) Enter the years of Suburbans/Yukon XL 3/4 tons you would like to look for, but you will have to put 3/4 ton in the additional items area. The following link is for a 200 mile radius of your home zip. 28 listings for new and used units.
Find Your Car: Listings Near Sugar Grove, OH 43155 - AutoTrader.com
Hi Yo Silver, Away II?
looking for our next AS
TAC IN-3
AIR 7185
04-27-2010, 03:54 AM
1996 34' Excella
Americus
, Georgia
Keep looking there are 2500 suburbans and yukon xl`s out there new and used. I would agree that the dealer you visited only wanted to sell what they had in stock. The 2500`s are great all around tow vehicles. I have both and have towed my 34ft trailer with both and the 5.3L will tow it ok but does not have the braking of the 2500 and the 6.0L has more low end torque from a dead stop. I only use my suburban w/5.3 to tow close to home which is mostly flat land. Good luck shopping.
1991 Airstream Excella 1000 34ft (SOLD)
1994 Chevrolet Crew Cab dually 2WD 6.5td
2005 Chevrolet Suburban LT 1500 2WD 5.3
WBCCI # 10219 Georgia Unit
AIR # 5131
04-27-2010, 04:45 AM
St. Catharines
, South Western Ontario
Your Airstream has it's own brakes.
For a couple hundred dollars you can upgrade to a larger tranny cooler.
The wheelbase concern is a non issue with a Propride or Hensley
Apply these thoughts to what you have and you may have well balanced combination considering overall performance, comfort, and dollar savings.
Don't forget to get the whole works set up and adjusted properly.
04-27-2010, 05:05 AM
Sugar Grove
, Ohio
Thanks to all that have responded. We are somewhat trapped in the midwest at present. We want to go east, west, and south but have lots of mountains to traverse and we want to cross them without worrying about them - as we do now. And we've gone to Virginia, W. Virginia and Pennsylvania and have found we have some braking, tranny cooling problems and I don't like it! From the sounds of things, we will continue looking for the 2500 Suburban. Again, thanks to all that have taken the time to send comments.
04-27-2010, 06:01 AM
1978 28' Ambassador
Kenton
, Ohio
We towed our 28' with a 1992 1/2 ton Suburban (350 engine) for years before the transmission went bad (around 140,000 miles). Replaced it with a 1999 3/4 ton Suburban with a 454 engine (and better transmission). Tows like a dream but we get 10-12 mpg whether we tow or not. Hope the newer 3/4 ton Suburbans get better fuel mileage.
04-27-2010, 07:53 AM
1968 17' Caravel
2005 30' Safari
Somewhere
, roaming America
Pilgrim, if you want a new tow vehicle, ignore this. But if you care to keep your Armada and save a lot of money, let me chime in with Road Ruler.
We used the Armada to tow our Safari 30 for three years full-time and were very satisfied with it. It's true that the wheel base is relatively short for a 27 foot trailer, and it's also true that a Hensley/Pro-Pride resolved that issue completely for us. Those hitches may be expensive, but they're nothing compared to the depreciation hit you'll take on your Armada if you sell/trade it.
If you have the "Big Tow" package on the Armada then you have a transmission cooler, but even with that the Armada/Titan are known for the transmission heating up when running under heavy load at low revs. The solution is amazingly simple: shift down 1 gear. In seconds you will see the transmission temperature plummet. That's because the transmission fluid pump is tied to engine RPM. Lower gear=higher RPM = faster cooling.
I have heard from a few people (some on this forum) who panicked and traded in their Armada/Titan when all they needed to do was push a little lever once in a while. That's an expensive choice.
As for braking issues, the Armada has huge and powerful brakes. If you are having "braking problems" you need to look at your trailer brake setup. We had two complete trailer brake failures when towing (one on the descending side of a bridge on a rainy day) and the Armada's brakes proved easily capable of stopping both vehicles safely. I often find that people reporting "braking problems" are riding the brakes on a downhill when they should be shifting down, have worn trailer brakes or out-of-adjustment brake shoes, or their brake controller is set improperly.
On the other hand, if you really want a Suburban and are just looking for justifications, who am I to tell you not to? Do what you like -- it's your money and you're the one driving it. But remember that the "braking problem" will still be there even with the biggest 'burb you can find -- even if the new vehicle masks the problem. You need to resolve that issue regardless.
04-27-2010, 08:10 AM
asbury park
, New Jersey
we just bought a '84 diesel suburban to tow our 21ft globetrotter. a bit of overkill, but it gets 25mpg w/o trailer. and there's actually more room in the 'burban than the GT!
04-27-2010, 08:13 AM
1978 28' Ambassador
Kenton
, Ohio
Rich,
What kind of fuel mileage did you get with your Armada...towing and non-towing?
Tom
04-27-2010, 08:21 AM
Santa Rosa Beach
Even though I am a Suburban aficionado, I tend to agree with Rich. You already own the Armada. The ProPride or Hensley would take care of any issues having to do with a short wheelbase. A transmission fluid cooler (or 2 for that matter) should be able to handle the strain on the transmission. All of the Armada's other components are more than adequate.
Give it a try. If the Armada still doesn't do it for you, The Hensley or ProPride will work great with that new Suburban, so you will not be out that investment.
Brian
04-27-2010, 08:31 AM
1968 17' Caravel
2005 30' Safari
Somewhere
, roaming America
Originally Posted by tlavergne
Rich,
Non-towing, 17-18 MPG highway, 15 around town
Towing, 10-10.5 MPG
It was pretty consistent on fuel, except of course in high wind conditions.
04-27-2010, 09:50 AM
Wise Elder
2010 30' Classic
South of the river
The last time I looked, there were half a dozen 2000-2009 burbs for sale by dealers in the Minneapolis area in the K2500 configuration, including a couple with big block engines. Color choices are the main problem. A disproportionate number of them are black or white.
04-27-2010, 09:58 AM
Sugar Grove
, Ohio
Tom,
With our Armada, we usually run just over 20 m.p.g. without the AS and 12 - 12.5 towing. One day we needed the 4 wheel drive to climb out of the campground and I forgot to take it out of 4 wheel drive once we got on the hwy. We drove all day in 4 x 4 running at 9 m.p.g. Lesson learned that day!! I've been very happy with the fuel mileage - remember, we boated for three years and would run 24-25 gallons per hour through the boat - so whatever we get towing is an improvement.
I look forward to trying the downshifting one gear when the temp. starts to climb. I will have the brakes checked to see everything is done correctly and we'll go from there. If a Hensley is in our future, that's a lot less expensive than a new 'Burb. We'll see what we can learn this summer using the suggestions contained in all the responses. THANKS TO ALL for CHIMING IN!!!
04-27-2010, 10:11 AM
St. Catharines
You are in Ohio, not that far from Ontario. Why not take your rig up to Can Am and have them have a look at your set up. Chances are all you may need is some minor adjustments or some tweaking. I have talked to so many folks who have done this and were amazed at how much better their rigs felt and performed.
04-27-2010, 10:18 AM
_
pilgrim
good advice so far, so here's something completely different...
while it is important to make sure the trayla brakes are properly dialed...
there is a LONG history of n/A stopping problems for the 04/05 years.
reportedly WARPED rotors, premature wear (rotors and pads), pad deposits ON the rotors and caliper inadequacies...
supposedly the issues were sporadic and driver/vehicle specific...
but in late 05? there was a TSB from nissan and a fix of some sort.
it wasn't a full on recall but no doubt a company response to widespread issues or IMAGINED issues.
has your suv been through this tsb shakedown?
what SPECIFIC problems have u experienced in regard to slowing/stopping?
____________
u mention a sil'ado with a "small diesel" ...
no such beast, unless it's after market.
3/4 ton burb is a significant upgrade over 1/2 tunner, with many beefier bits...
____________
having used a haha for years, snag a USED one if ya like crappy orange paint...
or go for the new improved PP, either will manage the wheel base issue and firm up the towing...
but IF the handling is squirrely, first thing to check is TV tire inflation pressures...
run them at the MAX sidewall psi for better stability while towing.
does the nis'an have 20 inchers or 18s?
____________
there are LOTS of tv options for a modern 25 footer and many that are better than the burb or a'mada...
cheers
2air'
04-28-2010, 01:31 PM
Sugar Grove
, Ohio
My specific braking problem has been the need to nearly "stand up" on the brakes to get the feeling they are actually slowing us down. They have always done so, but the feeling is they are barely grabbing and working - they feel like there is something between the brake and the brake pad that is keeping them from stopping the vehicle. It is a scary feeling - especially when the unexpected vehicle pulls in front of me and stops immediately for a traffic light or other traffic situation.
The handling of the rig is not squirrily at all. I've been very happy with how well they work together. I've never had a sway problem or a lack of power problem. I always check the tires for proper inflation before heading out.
The Armada has 18 inchers and YES, I have considered changing the trailer hitch. For some reason I am on the PP mailing list - I get their info regularly. This seems to be the summer we decide if 'streaming is what we want to do. This is our third summer - will we continue? We have long weekend trips planned, a longer trip (or two) through the state of Michigan and into Canada and our long trip will be to visit Charlottsville, Richmond, Williamsburg and Washington D.C. We'll know by the end of this summer if we will continue traveling by AS or return to airplane travel, sleeping in strange beds and eating that crappy restaurant food. Again, THANKS for all the input - we'll continue with the Armada for this summer and fall and then make some decisions.
