12-07-2011, 07:00 PM
2012 25' Flying Cloud
Eureka
Suburban: Clearance for Tailgate w/Airstream?
I have a 2007 Suburban half ton with the automatic rear hatch. I can't open this when hitched to my current 18' TT. But, we are picking up a new 25' FC this Friday. I am wondering if the gate will open with the new Airstream?
12-07-2011, 07:04 PM
Oswego
I think you will be able to. I can with my 30' Classic.
-Rich-
12-07-2011, 09:14 PM
2019 23' International
La Habra
We have a Tahoe, 2008, and when we had the 19 bambi we could open the hatch. On another note regarding your hitch question in your other thread, because the tow hitch is mounted in the bumper rather than below the bumper you will need a drop shank to assure the rig is leveled. Hopefully your dealer knows about this issue with our GMT 900 SUVs.
12-07-2011, 09:54 PM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
We tow Lucy ('05 25FB) with two different Suburbans, an '04 and a n '05. We have always been able to fully open the rear gate. We do tow with a Hensley which gives us some extra clearance between Lucy and the Subs.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
12-07-2011, 10:05 PM
Eureka
Ok - good news then. I would be a bit disappointed if I can't open the gate while hitched.
I do have a dropped stem for the receiver.
12-08-2011, 04:55 AM
2011 30' Flying Cloud
Arvada
In case, with a 2008 Suburban, I could not open the hatch with our Blue Ox hitch, but can now with the Hensley. It lengthens things about a foot - enough for the clearance. I'm with you, what a difference it makes to be able to easily access the back when hooked up.
12-08-2011, 09:08 PM
2011 28' International
Chatham
, Ontario
The tailgate on my Sienna is so big that I'd need to move the hitch back about two feet to accommodate it. Given that the aim of the game is to get the the trailer as close to the back axle of the TV as possible, I will be sticking with my non-opening tailgate....
12-09-2011, 12:28 PM
2012 25' FB Eddie Bauer
Eugene
, Oregon
It's going to depend on your hitch. I have 25" Eddie Bauer and I'm using an Equalizer hitch and the tail-gate on my '10 Suburban hits the tongue jack controls. It seems, from reading the comments above, that with a Hensley (or, presumably a ProPride) you should be able to get it open.
12-10-2011, 06:58 AM
Eureka
Argh! It doesn't clear!
12-10-2011, 07:58 AM
Oswego
What hitch and shank?
This is a Reese dual cam with a 9"drop Equal-i-zer shank. Clears fine. Yukon XL in pic is same, dimensionally as a Sub.)
Note: must be pretty much in a straight ahead stance though. If in a turn....will not clear.
-Rich-
12-10-2011, 08:23 AM
2019 27' Flying Cloud
Albuquerque
, New Mexico
Wrong Hitch?
From your posts, I have inferred that you may not be using a weight distribution hitch. ALmost any weight distribution hitch has a long shank that provides enough horizontal distance between TV and TT to allow lift gate clearance.
Please tell us which hitch you are using. Otherwise, we are all just speculating in the dark (illegal in some states).
Ken L 2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow Four Corners Unit WBCCI #5783
12-11-2011, 07:19 AM
Eureka
I am using the Equal-i-zer hitch. Just by eye I assumed it wouldn't open. But after seeing the pic of the Yukon, maybe I jumped to conclusions. I didn't want to have the gate get banged up hitting the jack post. Maybe this am when we hitch up to leave, I will give it a try.
12-11-2011, 09:16 AM
Antiquepedaler
2010 25' FB Flying Cloud
Laramie
, Wyoming
One can always have a welding shop fabricate a longer shank.
Antique Pedaler
2021 Caravel 20 FB
12-11-2011, 09:24 AM
La Habra
You could always have the post head turned 45 degrees and have the controls on to the side for more clearance if you need it.
12-11-2011, 11:47 AM
Oswego
If you have the power tailgate, switch it off and experiment by manually opening the hatch. This way you can learn how much of a turn is
ok without skinning things up.
-Rich-
12-11-2011, 05:33 PM
Eureka
It definitely hits the jack motor. Too bad. Another 2" and I would have it.
12-11-2011, 11:14 PM
Eureka
I'm not looking at it right now...but this sounds like a workable idea! THX.
02-14-2019, 01:29 AM
2019 28' Flying Cloud
Saranac Lake
, New York
2016 Suburban Tailgate Clearance
Hi All, I’m picking up a 2019 Flying Cloud 28RBT next week and it just dawned on me that I may have a hatchback clearance issue. Does anyone know if it will open using an Eqalizer hitch with trailer attached? Thanks Condo 1
02-14-2019, 04:58 PM
2018 28' Flying Cloud
Chapin
, South Carolina
Condo1, Chances are your Equalizer hitch shank is the standard 12" length, but they also make an 18" long shank, if you hatch doesn't clear with the 12". You can view pictures and measurements on etrailer.com. If 12" is not enough, but 18" to much, it may be possible to take an 18" shank, slide it further into your receiver and have an additional hitch pin hole drilled to get you somewhere in between.
02-14-2019, 05:29 PM
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez
Keep in mind lengthening the hitch does not help towing characteristics.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
