Old 03-05-2005, 11:26 AM   #1
Foiled Again's Avatar
Virginia Beach , Virginia
Smile Suburban as Tow Vehicle
Grrrh! Used Car salesmen. OK, I've got a 22 ft CCD and I've pretty well decided I want to tow it with a Suburban. I know I need a 4.1 rear end as well as extra cooling on the brake and transmission fluids and extendable towing mirrors. I'm sure I'll have to add the brake controller myself.
I'd far rather buy a used one than a new one and I'm aware of the piston slap issue so I'll be very careful. Trouble? Not one sales guy I've talked to has any idea HOW to tell what rear end is in any given vehicle. Knowing this forum is the source for ALL useful knowledge, please tell me so I can check for myself. Is there something in the VIN number or on the manufacturing plate that I can check?
I'm about ready to try E-Bay (yuck) and traderonline.com.
Thanks, Tin Lizzie
Old 03-05-2005, 11:52 AM   #2
Stefrobrts's Avatar
Profile:  1968 17' Caravel
Battle Ground , Washington
Airstream Registry
On my Ford van you can decode it off the door sticker. The manual has instructions on decoding.
Never trust used car dealers. They know NOTHING! I once spent twenty minutes watching a Chevy salesman try to figure out how to open the trunk on a 68 vette. Here's a hint - 68 vettes don't have trunks! He just kept saying, 'hold on, I've almost got it'....
Good luck finding your perfect tow vehicle!
Stephanie
Old 03-05-2005, 12:05 PM   #3
Cool What's a man good for?
20 minutes if you're very, very lucky.
T. L.
Old 03-05-2005, 12:07 PM   #4
Profile:  2006 30' Classic
Farmington , New Mexico
Images: 14
There used to be a sticker in the glove box on GM trucks. It would have a code that I would take to a GM parts dept. to have decipher. -----Pieman
Mike Lewis is offline   Reply With Quote
Old 03-05-2005, 01:09 PM   #5
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 156
Airstream Registry
Greetings Tin Lizzie!
Thanks, Tin Lizzie
It is my understanding that the codes below would be of most interest for trailer towing on post-2000 Suburbans (there would be differences in the 1999 and before as they were of the older body style):
Z85 Suspension Package, Handling/Trailering, heavy-duty
GT4 Rear axle, 3.73 ratio
GU5 Rear axle, 3.23 ratio
GT5 Rear axle, 4.10 ratio
LQ4 Engine, Vortec 6000 V8 SFI, (335 HP @ 5200 rpm,
375 lb.-ft. @ 4000 rpm)
L18 Engine, Vortec 8100 V8 SFI, (320 HP @ 4200 rpm,
440 lb.-ft. @ 3200 rpm)
KG3 Alternator, 145 amps
C6P GVWR, 8600 lbs.
G80 Differential, locking, heavy-duty, rear
Z82 Trailering equipment, heavy-duty, includes trailering hitch
platform, 7-lead wiring connector, auxiliary transmission oil
cooler, trailer brake pre-wire harness and 7-way to 4-way
adapter
MT1 Transmission, 4-speed automatic, heavy-duty,
electronically controlled with overdrive, tow/haul mode and
(KNP) Cooling, external transmission oil cooler
KNP Cooling, auxiliary transmission oil cooler, heavy-duty
air-to-oil
K47 Air cleaner, high-capacity
Both of my GM SUVs have the optional equipment coding sheets on the inside of the glove box door ('99 GMC K2500 Suburban and '94 S-10 Blazer).
My '99 is the first Suburban that I have owned, but it is my second large SUV (the first was an '84 Jeep Grand Wagoneer -- full-size prior to downsizing). I find the station wagon style body to be so much more useful than the two pickups that I owned - - I doubt that I will ever purchase another pickup.
Good luck with your search!
Kevin
Kevin D. Allen
AIR #827
Old 03-05-2005, 01:41 PM   #6
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
T. L.
Hmmm,
Let's see, original post made at 12:26 p.m. and good answer made at 1:07 p.m. Not bad at all.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 03-05-2005, 03:50 PM   #7
Profile:
Suburban as a tow vehicle
The codes mentioned in the one of the other posts are RPO (regular published option) codes. There is typically a sticker in the glovebox with these codes.
You don't need the 4.10 rear to pull your 22 ft trailer if you can find a 3/4 ton. I have a 03 Suburban with the 6.0 and 3.73 rear, pulling a 25 ft. Sovereign and it works fine (well within the tow rating). Fuel economy runs 11.5 - 12 mpg towing.
I never imagined that I would end up with a burb. I test drove the pickups as well as the full-size van, and the burb came out on top.
1985 25' Sovereign
Corner Bed
2003 3/4 ton Suburban
6.0, 3.73
Bellingham, WA
alan is offline   Reply With Quote
Old 03-05-2005, 04:26 PM   #8
Post Overlander64
Thank you, thank you, thank you. I'm gonna go out and make some salesman's life hell now!
Tin Lizzie
Old 03-05-2005, 05:19 PM   #9
Over59's Avatar
Profile:  1959 26' Overlander
Putnam , Connecticut
Images: 37
They have some great deals on new ones. $3500 back on a 2500 Crewcab pickup. Thats the seats of a burb and a place to put dirt.
TAC & SOFI Member Rock On
Over59 is offline   Reply With Quote
Old 03-05-2005, 05:25 PM   #10
Arrow Sniff... boo hoo...
Well I just talked to a nice man in Kitty Hawk North Carolina who has an '04 DuraMax Crew Cab with 31,000 miles on it for $33,848. That's probably a pretty good deal, but is more than I really want to pay for a tow vehicle.
Says he can't find a Suburban with a tow package anywhere and he's hooked into the Chevy network.
Not gonna give up though, I'll just expand my search area.
sigh, Tin Lizzie
Old 03-05-2005, 05:48 PM   #11
Profile:
Burb
That's approximately what I paid for my burb new. The markup on trade ins is substantial. Use online guides such as Kelly or Edmunds to help set a value.
1985 25' Sovereign
Corner Bed
6.0, 3.73
Bellingham, WA
Old 03-05-2005, 06:49 PM   #12
norbert's Avatar
Profile:  1993 30' Excella
chicagoland , state of confusion+north of cheddar curtain
Images: 24
I'd far rather buy a used one than a new one Tin Lizzie
in the interest of propitiation....i will not comment.
norby:-)
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 03-05-2005, 06:56 PM   #13
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Frozen Tundra , Illinois
2wd or 4wd?
If you're ok w/2wd then:
http://www.cars.com/go/search/fs_sea...l&aff=national
It's 115 miles away and has the 6.0L engine. It's a 3/4 ton (not that you need that much for a 22') at Witmore Chevy Olds
Old 03-05-2005, 06:58 PM   #14
Anna , Illinois
Images: 156
Airstream Registry
sigh, Tin Lizzie
If you haven't already discovered the GM Certified Used search tool, you can access the GM Certified Used vehicle inventory of every GM dealer via:
http://www.gmbuypower.com/cuvHome.cv...=001&year=2004
Kevin
Kevin D. Allen
AIR #827
F250 tow vehicle or flatbed? Cheryl Tow Vehicles 19 08-23-2007 01:58 PM
Tow Vehicle Options wlanford Tow Vehicles 10 05-23-2005 12:18 PM
Which is best tow vehicle Van or Sedan? Mr Jody Hudson Tow Vehicles 9 09-30-2004 11:05 PM
1975 Cadillac Eldorado as Tow Vehicle overlander64 Tow Vehicles 9 11-04-2002 07:04 AM
4x4 tow vehicle... or not? Cheryl Tow Vehicles 11 08-22-2002 11:00 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
