Old 05-31-2008, 09:07 PM   #15
Airstream25's Avatar
1995 25' Excella
1982 34' Limited
Albuquerque , New Mexico
Images: 21
Send a message via Skype™ to Airstream25
considering a Suburban to pull our 25'
I pull our 95 25' with an 05 Yukon XL 2500 8.1L 3.73 4WD.
It does very well with pulling, stability and braking over the Colorado and NM mtn. passes. The lift gate will open while hitched unless the TV is at a sharp angle to the AS. I plan to keep this TV a long time as the 8.1L is no longer being made.
Originally Posted by Goin camping
Here's a question for current and former Suburbaners.
We are considering going to a Suburban to pull our '07 25 FB. We'll need to pull/haul about 8,000 lbs.
We usually boondock so 4X4 is mandatory.
We a surrounded by and travel over big mountains all the time. Also much time on raggedy dirt roads in the desert.
We will buy used so we're looking for the best year/model for strong pulling, durability and longevity and the ability to go freeway speeds.
We are only looking at 2500's. MPG is not a core concern as this will be a dedicated TV.
Does anyone know if you can open a tailgate or barndoor model while hooked up?
O.K. folks don't hold back on your experience and Suburban opinions.
Airstream25
KE5CKG on 2 meters
AIR #10274
Airstream25 is offline   Reply With Quote
Old 05-31-2008, 11:11 PM   #16
eikel1we's Avatar
1975 25' Tradewind
, Michigan
Send a message via AIM to eikel1we
Rivet
We have a '04 2500 GMC Yukon XL 4x4 to tow our '75 - 25' Tradewind. The 1/2 ton it replaced did a good job but there was a noticable difference and a smoother ride moving up to the 2500. Ike says, "if that won't get us where we're going we don't need to go there".
We've had mostly cargo doors and some tailgates. I like the current lift gate, our first, the best. If you haul something it may be easier to fasten the gait down (or rest it on the top of the gait with the window open) than the cargo doors. As it's been said, opening isn't a problem if not sharply angled.
I have been the principle driver of our Suburbans, this one being number 10 since about 1984, and they are my vehicle of choice. Except at the gas pump these days ..... but that may be an advantage for a buyer at this time.
Good luck with your search,
sue
sue and ike
'75 Tradewind - 25'
"Cupcake" air-912
2004 GMC Yukon XL 2500
Michigan - "middle of the mitt"
eikel1we is offline   Reply With Quote
Old 06-01-2008, 08:09 AM   #17
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I have the 4.10s and have not noticed any MPG hit vs the 3.73s. The 4.10s make the tranny happier, and allows a bit higher tow rating (at least pre new sheet metal models). I found my 2004 sales data (which may be vaild up through the 2006 model year):
3/4 ton 2wd 6.0L 3.73 7900lbs (quadrasteer will reduce rating by 300lbs)
3/4 ton 2wd 6.0L 4.10 9900lbs (quadrasteer will reduce rating by 300lbs)
3/4 ton 4wd 6.0L 3.73 7600lbs (quadrasteer will reduce rating by 300lbs)
3/4 ton 4wd 6.0L 4.10 9600lbs (quadrasteer will reduce rating by 300lbs)
3/4 ton 2wd 8.1L 3.73 10,500lbs (quadrasteer not avail with 8.1L)
3/4 ton 2wd 8.1L 4.10 12,000lbs (quadrasteer not avail with 8.1L)
3/4 ton 4wd 8.1L 3.73 10,200lbs (quadrasteer not avail with 8.1L)
3/4 ton 4wd 8.1L 4.10 12,000lbs (quadrasteer not avail with 8.1L)
Max payload, regardless of engine in a 3/4 ton is 2737lbs 2wd or 2431lbs 4wd.
GVWR for the 3/4 ton is 8600lbs regardless of engine config or 2wd or 4wd.
What is interesting is that the 1/2 tons have a GVWR of 7000lbs 2wd or 7200lbs 4wd. Must be a few more toys in the 3/4 ton to add such significant GVWR...
Old 06-01-2008, 08:58 AM   #18
1976 Argosy 24
Ligonier , Pennsylvania
3/4 Ton vehicles have much heavier frames, axles.
Don't force it! Use a bigger hammer!!!
ls99 is offline   Reply With Quote
Old 06-01-2008, 09:22 AM   #19
starflyte1's Avatar
2007 25' Safari FB SE
Lady Lake , Florida
We had an '05 Suburban 4x4 2500 with the 8.1. 3.73. We decided we wanted a pick-up type bed for a generator, so we bought the same vehicle, only in an Avalanche.
We made two trips to the west coast last year, one to Seattle, and the Avalance had no problems with any mountain. We are very happy with everything about it.
Pat
AIR# 16756
WBCCI# 6167
starflyte1 is offline   Reply With Quote
Lost the ability to see attached photos pienjim Forum Admin, News and Member Account Info 23 12-08-2009 10:48 AM
Newbie question about suburban furnace rec Furnaces, Heaters, Fireplaces & Air Conditioning 5 10-25-2007 07:05 PM
Old Suburban Furnace Question Jeffrey Stoecker Furnaces, Heaters, Fireplaces & Air Conditioning 12 03-07-2006 03:11 PM
Tow vehicle question re: Suburban bdogz Tow Vehicles 7 07-28-2005 02:05 PM
Trailer wgt, tow ability for next TV Tin Hut Tow Vehicles 62 12-16-2004 11:42 AM
