Old 04-19-2007, 03:18 PM   #1
chaimemet
chaimemet's Avatar
Profile:  2008 31' Classic
Ft. Lauderdale , Florida
Suburban 05 3/4 ton 6L 4.1 axle
Looking at an 08 Classic 30 s/o. Can my vehicle tow this trailer? It has a towing package plus Quadrmaster 4x4 and AWD with 4.1 rear axle 3/4 ton.
chaimemet is offline   Reply With Quote
Old 04-19-2007, 03:42 PM   #2
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
JCanavera tows a 30' slide with a 3/4 ton GMC van with the same engine, trans and I believe gears. He's pleased with that combo from what I understand. He did however have to swap out his factory hitch for a more stout hitch due to the massive hitch weight of the slide out. Back in his model year, the factory hitch was not rated for such hitch weights. Not sure if the new trucks and vans have upgraded hitches.
That said, if you fully load the 30' side out, you will exceed the stated tow rating for the Suburban. I would feel more comfortable with an 8.1L engine, but that is not an option 2006 Burbs on up, but it was for the '05s! Rumors are everywhere that a diesel Suburban may grace our presence in about 12-16 months from now. That would be great for the 30' slide out and then some.......
Take the slide out of the equation and sure, the standard 30' would be fine....provided you don't load it to it's max NCC. A 28' hands down would fit, even fully loaded going by the numbers alone.
Old 04-20-2007, 07:24 AM   #3
chaimemet
chaimemet's Avatar
manual lists trailer weight of 9700 lbs and GCWR of 16,000 lbs.
Old 04-20-2007, 07:39 AM   #4
Silvertwinkie
Aluminut
Looking at the Airstream site, the 30' Classic slide has a current GVWR of 10,300lbs fully loaded and a hitch weight of 1,050 lbs:
Airstream :: Classic
Anything less and it is most likely an early 2005 manual/data sheet you're looking at as Airstream raised the NCC by adding more robust axles in mid 2005, along with disc brakes and taller stainless steel front rock guards.
Old 04-20-2007, 07:46 AM   #5
wheel interested
wheel interested's Avatar
Profile:  2007 27' Classic FB
Lapeer , Michigan
Images: 117
We have the 07 Suburban with 6.0 and 4.10 to pull our 27' Classic and it is great. Before that we used the 1/2 ton Expedition and while we barely squeaked by with the 25' Classic, larger and heavier Airstreams require larger and heavier tow vehicles. It also rides much better and pulls more effortlessly. Cool that you have the opportunity to get quadrasteer(?)
Carol #17241
wheel interested is offline   Reply With Quote
Old 04-20-2007, 09:39 AM   #6
Mike Lewis
Profile:  2006 30' Classic
Farmington , New Mexico
Images: 14
I don't think Quadmaster and Quadrasteer are the same thing----pieman
Mike Lewis is offline   Reply With Quote
Old 04-20-2007, 09:53 AM   #7
wheel interested
Lapeer , Michigan
Images: 117
Oops sorry about that. My slip is showing.
Carol #17241
Old 04-20-2007, 10:01 AM   #8
moosetags
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
GM discontinued Quadrasteer (4 wheel steering) after the 2005 model year. What a mistake on the part of GM.
I am not familiar with "Quadmaster"; what is it?
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
moosetags is online now   Reply With Quote
Old 04-20-2007, 01:13 PM   #9
Silvertwinkie
Aluminut
I agree...it is useful and I heard that the foreign owned automakers are quickly looking to adopt it......
Add that to the long list of GM dumb decisions:
Corvair
Fiero
Impala SS
EV1
Just for a few to mention....
Old 04-21-2007, 08:59 PM   #10
chaimemet
chaimemet's Avatar
Change order
We are in the final negotiations with Colonial. We think the 31 layout model suits our needs. The head is closed off by a sliding door rather than exposed as a suite, less carpet, and almost 900lbs less in weight compared to the 30 SO. The one we want has also a second AC in the master better for florida. We will also get a hensley hitch and podigy brake controller threough them. I think I will be alright with my TV. When the lease runs out next May I hope the burb diesel version is on the market.
Tag axle shock rdm Mechanics Corner - Engines, Transmission & More... 8 07-10-2008 08:15 PM
Who made my axle? Pahaska Axles 44 07-25-2007 11:08 AM
Chevy Express vs Suburban alan Tow Vehicles 8 07-27-2003 04:38 PM
one or two axle? vallan1980 Airstream Trailer Forums 5 09-17-2002 06:47 PM
Axle Offset Question DanLyle Axles 11 08-28-2002 10:35 AM
