Turbos,,, if one allows them to have a cool down moment after a hard pull,, will last almost 2 engine life's.. That is to say to just pull off the road after a hard pull and not let them idle a few minutes to cool down will bake the oil inside and apply too much heat to the oil seals..
From the photos,, like they said above,, check out the trans condition and if the price is right I would jump all over it..
The best trick on any auto trans,, if they are constantly searching for a gear to run in,, just pull it back a notch and let them run in that gear till the hills settle down or conditions change.. That gear hunting between direct and overdrive is hard on them..
Sodbust
2012 Ram 1500 Tradesman Hemi, 4x4, 6 speed
20mpg empty, 14 mpg with 27' Overlander.
Today is the first day of the rest of your life!
