Old 07-18-2014, 11:28 AM   #15
Air-Texas's Avatar
2004 34' Classic S/O
Waldorf , Maryland
Hi Phil,
I am dealing with the same questions. Let me know if you get any good answers!.
Mike
Mike, Miho &
Dallas the Bourbon Boxer
S/OS#069
TAC # TX-33
WBCCI #5702
AIR #60387
"Eva" 2004 Classic Limited 34' S/O
"Wall-E" 2012 Ford F250 King Ranch
Air-Texas is offline   Reply With Quote
Old 07-18-2014, 11:53 AM   #16
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
When weighing get the towing hitch weight by pulling the truck onto the scale with the Airstream attached and weight distribution set, but behind the scale. Then disconnect the hitch and weigh the truck alone. The difference is the amount of payload the Airstream adds to the truck so you can see if the truck is rated high enough to carry your Airstream's weight, as well as the weight on each truck axle.
The pull the while rig onto the scale and see what you have as a combination and the trailer itself.
The expert on Airstream towing combinations is Andrew Thomson at Can Am Airstream in London, Ontario. Call them for good advice.
Doug and Cheryl
Old 07-19-2014, 12:49 PM   #17
2002 34' Classic S/O
Irvine , California
Images: 11
Thanks for all your advice. Today we weighed the whole rig: Tell me what this means to you:
Disconnected:
Yukon front 3720, rear 3600, total 7320
Airstream wheels 8820, tongue 1720, total 10540 (Includes Hensley hitch)
Connected without weight distribution:
Yukon front 2840, rear 5440, total 8280
Airstream wheels 9180
Connected with weight distribution:
Yukon front 3160, rear 5160, total 8320
Yukon front is lighter by 560 lb than solo; rear is 1560 lb heavier than solo
Yukon front is heavier by 320 lb than without WD; rear is 280 lb lighter than w/o WD
Airstream wheels 9140
My conclusions: Tongue weight is WAY above what Airstream advertises, weight distribution is working, but inadequate - we still need 800 lb or more thrown forward from the rear.
Your thoughts?
Phil
Phil in Irvine
WBCCI # 9759
2002 34 Slide Out Lounge
2005 Yukon XL, 3/4 ton, 4WD, 8.1 engine
pjtaia is offline   Reply With Quote
Old 07-19-2014, 01:01 PM   #18
dkottum's Avatar
It appears the airstream hitch weight is too heavy for the weight distribution system and the truck and it's receiver. Again call Andrew Thomson at Can Am, he's most probably seen this many times.
Doug and Cheryl
Old 07-19-2014, 07:10 PM   #19
N/A , N/A
With 1720# on the jack, you are probably exceeding the hitch rating as well.
rostam is offline   Reply With Quote
Old 07-22-2014, 05:41 PM   #20
JFScheck's Avatar
Rockville , Maryland
Images: 33
But on the bright side, better to be informed than in the dark...
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 11-05-2014, 09:26 AM   #21
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
As this thread has to do with OP's later thread on best WD hitch:
Yukon front 3160,
rear 5160
TT 9140
Yukon front 2840
rear 5440
TT 9180
Disconnected:
Yukon front 3720,
rear 3600
[Ron Gratz Chart]
Weighing #1 -- TT attached and Weight Distribution Activated
Let Front Axle Load be "FA1" 3160
Let Rear Axle Load be "RA1" 5160
Let TT Axles Load be "TT1" 9140
Then, while in same position on scales, take
Weighing #2 -- TT attached and Weight Distribution Not Activated (WD bars unloaded, but hanging in place)
Let Front Axle Load be "FA2" 2840
Let Rear Axle Load be "RA2" 5440
Let TT Axles Load be "TT2" 9180
Then, drive off scales and drop TT. Return to scales and take
Weighing #3 -- TV only -- TT Not Attached
Let Front Axle Load be "FA3" 3720
Let Rear Axle Load be "RA3" 3600
From the above values, you can calculate:
TV weight = FA3 + RA3 7320
Gross Combined Weight = (FA1 + RA1 + TT1)
{should also be equal to (FA2 + RA2 + TT2) if scale weights are correct}
17,460 & 17,460
TT Weight = Gross Combined Weight - TV Weight
10,140
Tongue Weight = (FA2 + RA2) - (FA3 + RA3)
8280 - 7320 = 960
Load Transferred to TT Axles
when WD System is Activated = TT1 - TT2 40
Something is off somewhere (TW, mainly. 12% of 10,140 is 1215-lbs as example). Were the readings all done at the same time?
Old 11-05-2014, 06:08 PM   #22
Irvine , California
Images: 11
Slowmover: I don't get your calculation of Tongue Weight equaling TV without Weight Distribution minus TV alone. I get 9,180-7,320=1,860; When I weighed just the trailer sitting on the tongue jack I got 1,720; either one is way different than the 960 you calculated...
I did make all these weights at the same time. I went back again at a later date to verify and several of the first few measurements were the same, so I didn't continue to do them all.
I have since determined that my OEM hitch receiver from GMC is rated at only 1,500 lbs, so I am in the process of purchasing and installing a Curt hitch receiver with 2,400 lb rating. We'll see if it makes any difference...
Phil in Irvine
WBCCI # 9759
Old 11-05-2014, 06:11 PM   #23
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Stiffer suspension?
Read through the way the chart is arranged. Cross checks. Did I accidentally change the scale numbers? If not then the TW is as shown.
Is your TW really 19%? 9% doesn't seem right either.
Rear suspension questions Sebastian DeWitt Airstream Motorhome Forums 0 06-30-2003 02:16 PM
Suspension question Sebastian DeWitt Airstream Motorhome Forums 9 06-21-2003 07:02 PM
front suspension, tires, shocks... mwendell Airstream Motorhome Forums 9 03-12-2003 05:26 PM
Replacement air bags on the rear suspension? TRAPEZE Airstream Motorhome Forums 1 03-09-2003 08:42 AM
2002 Classic 25' suspension? Kistler 2001 - 2005 Classic 7 11-12-2002 01:01 PM
