Old 01-05-2014, 07:32 AM   #1
2014 25' FB Eddie Bauer
Okemos , Michigan
Standard Mirrors on a 2011 F150 enough?
I will take delivery of a Eddie Bauer 25 in April and am wondering if i will need to install the factory towing mirrors in place of the standard mirrors. The standard ones seem fairly wide, but I was wondering what the experience of others has been with an AS and F150 mirrors.
Wanna EB is offline   Reply With Quote
Old 01-05-2014, 07:41 AM   #2
dkrug's Avatar
2012 30' International
Bad Axe , Michigan
We have an F250 with mirrors that extend for towing. Two friends tow with smaller trucks. They added towing mirrors. They got the kind that add on to the mirrors.
2012 30' International Serenity
1947 Spartan Manor
2005 28' Safari LS - traded
1977 31' International Sovereign - sold
2012 Ford F250 Superduty Crewcab
WBCCI# 1007 Air#2158
dkrug is offline   Reply With Quote
Old 01-05-2014, 07:53 AM   #3
aftermath's Avatar
Spokane , Washington
Sorry but I do not tow with an F150 so I can't say much about their mirrors. I can tell you though that I did tow with add on mirrors and it was a problem for me. When we bought the Tundra I made sure it came with factory tow mirrors. It makes all the difference in the world for me.
I had Cippa mirrors and they were always in need of adjustment and or tightening. They vibrated while moving down the road so the view out the back wasn't what I expected. There are other brands out there but you will be looking at clamps, straps and putting them on and taking them off. Get the factory mirrors, I think you will be glad you did.
aftermath is offline   Reply With Quote
Old 01-05-2014, 08:07 AM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Actual experience with 2012 Ford F150: the standard mirrors do not extend enough to properly see around even a small trailer. I went thru several different mirrors before settling on these.
CIPA 11800 Ford F-150 Custom Towing Mirror - Pair
Best price I was able to find was at Amazon. They are perfectly fitted to the original mirrors, no vibration and easy to adjust. They stay adjusted once set and can easily be removed and reinstalled without having to readjust the mirrors.
MICHAEL
Old 01-05-2014, 08:16 AM   #5
Okemos , Michigan
Very helpful…thank you.
Old 01-05-2014, 11:18 AM   #6
ShinyPete
ShinyPete's Avatar
2014 27' Flying Cloud
Bushnell , Florida
I second AWCHIEF on the Cipa mirrors. We have a '13 F150 XLT with "regular" mirrors, and the Cipa's work well. I wish they had a little larger lenses in the extension, but for the price and functionality they are great.
ShinyPete is offline   Reply With Quote
Old 01-05-2014, 11:32 AM   #7
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Since your trailer is a Airstream wide body at 8' 5.5" wide, you legally will need extended mirrors as you are supposed to be able to see behind the trailer when towing. Standard mirrors are set in too narrow for that to happen.
Old 01-05-2014, 01:04 PM   #8
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
Originally Posted by Wanna EB View Post
...I was wondering what the experience of others has been with an AS and F150 mirrors.
we used the CIPAs on our 2008 F150 for two+ seasons pulling a 2002 Safari 25C and found them reasonably effective. I too wished they were bigger, but they are about as big as you might find for a slip-on.
we have the factory towing mirrors on the 2011 and love them.
iirc, the material cost from Ford for these (turn signal, heated, manual extension) when purchased after is $400 to 500. you might find a better offer on eBay??
ymmv.
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 01-05-2014, 01:04 PM   #9
911Patriot's Avatar
1991 29' Excella
Marco Island , Florida
Images: 42
F-150 mirror extensions
(CIPA 11800 Ford F-150 Custom Towing Mirror - Pair
Best price I was able to find was at Amazon. They are perfectly fitted to the original mirrors, no vibration and easy to adjust. They stay adjusted once set and can easily be removed and reinstalled without having to readjust the mirrors.)
Thank you for doing the investigating on this and leading us to the source for purchase. I just purchased them!
Name:	Mirror extensions.jpg
911Patriot is offline   Reply With Quote
Old 01-05-2014, 01:22 PM   #10
AWCHIEF's Avatar
Images: 33
Glad I could help. Now I have to start my quest for the perfect mirrors for my new Grand Cherokee. Unfortunately Cipa does not make those mirrors for it.
MICHAEL
Old 01-05-2014, 01:46 PM   #11
JDS
2014 Bowlus Road Chief
JDS's Avatar
Cumming , Iowa
Consider Milenco Aero2, I've had great experience with them.
Milenco Aero 2 Mirror | Milenco Limited | Caravan Products | Caravan Security | UK
John S.
JDS is offline   Reply With Quote
Old 01-05-2014, 04:05 PM   #12
AWCHIEF's Avatar
Images: 33
John, thank you, I will keep those on mind. They look interesting and seem to have overall good recommendations. I have a couple of others brands on hand that I am going to try out first.
MICHAEL
Old 01-05-2014, 04:40 PM   #13
Okemos , Michigan
Thanks again. The direct comparison of the slide on to the factory mirrors is helpful. I will get a quote from my Ford dealer and see what they say. I understand that I will loose the power folding which has been handy to have.
Old 01-05-2014, 05:25 PM   #14
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
If you get your Ford dealer to install the "tow mirrors" from the current Max Tow package, they are power folding. I'm not sure if they're power extending or not, but it looks that way from the description for the 2014 truck. "Side Mirrors, power folding and telescoping trailer tow mirrors with power glass." I'm not sure if that's the same feature set that was available for 2011, but someone should be able to retrofit those. I don't think the door shell has changed between 2011 and now...
— David
