Will silverado 1500 classic have any issues pulling a 2008 Airstream International?
Can you post more information about the truck? year, engine size, rear differential ratio, tow package (yes, no), body configuration (crew cab, etc..). With that information we should be able to figure out an answer, I think.
The RPO codes for your truck are usually on a label on the inside of the glove box door. Payload capacity is usually on a sticker on the drivers door edge or door frame.
The RPO codes will tell you all of the details of how your truck was originally built. You just need to find the website that lists all of the GM RPO codes and match your RPO codes with the GM RPO list.
