01-16-2014, 06:31 PM
#161
2016 30' Classic
Hinckley
, Ohio
Seriously check out the new Jeep Cherokee It claims 31 MPG and will tow 4500lbs. They also start at 22K.
2014 Jeep Cherokee - Efficient All-Weather Capability SUV
My budget won't stop me from buying something online that I don't need, but the threat of getting promotional
emails every day for the rest of my life just might!
01-17-2014, 06:32 AM
#162
Mantua
, Ohio
Very interesting comments. Jim
01-17-2014, 08:56 AM
#163
Tom and Phyllis
2018 30' Flying Cloud
Tuscaloosa
, Alabama
AlanSD, your trailer weighs about as much as mine, so this is why I was giving you the numbers. I had just returned from the scales at the nearby truck stop and had those weights in front of me. If you downsize, be sure you are not exceeding your axle weight limits, axle to axle. If you notice the numbers, I am only a few hundred pounds below the axle limits. Steering axle weighs 2200 lb and my max allowed is 2646 lb. That is only 400 lbs to play with. The rear axle of TV weighs 3060 lb and my max allowed is 3792 lb. Only 700 lb available for stuff. Again, this is without the stuff you need on your trip. I had unloaded all but the fresh water holding tank which was full. And remember those mpg figures drop drastically when towing is close to the limit. If this info is of no use to you, perhaps it will be of use to others reading it with similar thoughts.
01-17-2014, 09:38 AM
#164
Tom and Phyllis
Tuscaloosa
, Alabama
By the way, Alan, you need congratulated on the restoration of your Vintage Airstream. I just read your blog. Well done with both the restoration and the sharing of info some of us may need at some point in time. Thanks.
01-17-2014, 10:33 AM
#165
1966 26' Overlander
Woodstock
, Georgia
Thanks much appreciated. I love that old girl, rescued it from too many years out in a field unused.
01-17-2014, 10:39 AM
#166
1966 26' Overlander
Woodstock
, Georgia
Originally Posted by Bigventure
I might be able to lease one of those if I wait until after Summer. My wife's lease is up and we could get a Cherokee then. That is a consideration.
01-17-2014, 11:30 AM
#167
Tom and Phyllis
Tuscaloosa
, Alabama
A guy was using one of those at the recent Canopener rally. His Airforum name is AWCHIEF.
01-17-2014, 11:55 AM
#168
2013 30' Classic
Greenwood
, Mississippi
AWChief had the Grand Cherokee-
Jeep has re-introduced the Cherokee- a little smaller and less expensive-
AWChief's Grand Cherokee was awesome- fully hard loaded with every available option-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
01-17-2014, 12:38 PM
#169
Common Sense
I had though that the 2012 Subaru Outback was a great tow. Untill the trailer got away and totaled the new Outback and 2010 16' Bambi. I'm lucky to be alive.
I then switched to a 2012 Jeep Grand Cherokee V6 and it pulled my 2011 20 Safari very well. Towing it got 12-14 MPG. Not towing 18-22 with regular gas.
I just traded the Jeep for a 2014 Grand Cherokee Diesel. On the way home from the dealer I got 28.6 MPG. I can't wait to tow.
FYI Jeep has a new Cherokee that may fit the bill for a small tow.
A lot to think about here, and a lot of questions unanswered, but the fact remains 16' Bambi behind a Subaru Outback "got away" from the driver, and totaled the entire rig.
2012 Subaru Outback, Max Towing Capacity, 2700lbs., "When adequately equipped, which may require engine and/or other drivetrain upgrades."
2010 Airstream 16' Sport, GVWR 3500, UBW 2897.
Happy that no one was seriously injured.
Regards,
Steve
01-17-2014, 01:42 PM
#170
1984 34' International
Toronto
, Ontario
The very same car in the UK is rated to tow 1700 kg or 3770lbs.
Without knowing all the details it is hard to have a qualified opinion, but it sounds more like a brake failure, or an incorrect setup, than a vehicle issue to me.
I don't think I'd choose to tow much with a Subaru myself, but it should be more than car enough to handle a Bambi.
01-17-2014, 02:10 PM
#171
1960 18' Traveler
lafayette
, Oregon
small tow
real small tow vehicle
01-17-2014, 02:22 PM
#172
N/A
, N/A
I believe the V4 has 31 MPG and the V6 has the 4500# towing capacity, so you won't get both at the same time.
01-17-2014, 02:34 PM
#173
Toronto
, Ontario
This thread make me look up the new GC. I am liking that car more and more, especially with the diesel engine. Shame it doesn't come as a seven seater.
01-17-2014, 02:37 PM
#174
Common Sense
Like I said, lots of questions unanswered. But one question comes to my mind, and that is would a more capable tow vehicle come out with the same results in the exact same situation? We'll probably never know, but just maybe this is why I've read so, so many times on these forums not to tow more than 80% of the manufacturers rating?
Regards,
Steve
01-17-2014, 02:43 PM
#175
1966 26' Overlander
Woodstock
, Georgia
its the Cherokee that looks interesting, smaller than the Grand and tows 4500 lbs, with sway control built in, an mid 20s fuel mileage.
As for the subaru, its not on my list. But if the brakes were hooked up and working it might have been a different story.
01-17-2014, 02:44 PM
#176
1966 26' Overlander
Woodstock
, Georgia
I love it! Great post.
01-17-2014, 03:02 PM
#177
Toronto
, Ontario
And what ratings would that be? The US ratings? Canadian ratings? UK ratings? They appear to fluctuate wildly, even for identical vehicles.
01-17-2014, 03:18 PM
#178
2013 30' Classic
Greenwood
, Mississippi
Is that for real?
TAC #MS-10
Airforums #70955
01-17-2014, 03:25 PM
#179
Common Sense
I sure everyone will do what they want, but I will consider American ratings with American trailers on American roads.
So far, it has worked well for me since 1971 when I started towing travel trailers.
Regards,
Steve
01-17-2014, 03:29 PM
#180
1972 25' Tradewind
North Vancouver
, British Columbia
Can we not turn this thread into another argument about tow vehicle size, please? That's a discussion for another thread. Let's see actual setups, as requested by the OP.
North Vancouver, BC
