Old 04-17-2014, 09:21 PM   #561
'06 75th Winick Prototype
2006 19' International CCD
1968 22' Safari
The Swamps of Hell , Lousy-Anna
Originally Posted by Andrew T View Post
Hi Burfeild
You really should have some weight distribution on your combo. It will give substantially more control should you need to make any evasive maneuver. It will ride much better as well.
Andy's right...the front of that Sport looks soooo funny being so high up in the air; it makes the lil Sport absolutely dwarf the Toyota. Some serious hitch adjustment and weight distribution is definitely in order.
ggoat!!! is offline   Reply With Quote
Old 04-17-2014, 09:27 PM   #562
Jim Lee's Avatar
1978 31' Sovereign
1984 31' Excella
Springfield , Missouri
Images: 125
I would be afraid to tow a trailer with a front wheel drive vehicle, especially going into curves.
Back in the day before adjustable hitches, my father in law had a cheat sheet. He believe that the trailer frame should be 16" off of the ground to ride level.
He believed that to achieve that height, the top of the hitch ball, unhooked, should be 19" off the ground.
Our first trailer, a 16' single axle Utopia, we towed with a 1973 Chevelle hardtop, using his measurements.
That guy forgot more than I will ever know.
Jim Lee is offline   Reply With Quote
Old 04-17-2014, 09:40 PM   #563
1968 22' Safari
I don't think the FJ is front wheel drive. I towed my Scamp thousands upon thousands of miles with a Dodge Neon and a Dodge Caravan with no problems regarding stability; discounting the lack of power of the Caravan with the Scamp, the stability of that particular combo was amazing with simple air shocks and a level trailer/van (no weight distribution or sway control on the 13ft). It's all in the loading; a level trailer and tow vehicle with or without weight distribution is a must.
Old 04-17-2014, 09:55 PM   #564
andreasduess's Avatar
1984 34' International
Toronto , Ontario
There is zero reason not to tow with a front wheel drive vehicle these days.
andreasduess is offline   Reply With Quote
Old 04-18-2014, 05:43 AM   #565
Road Ruler's Avatar
Images: 38
I have towed our 23 with both FWD and RWD doing 100's of curves in the process. No problem with either.
Old 04-18-2014, 09:56 AM   #566
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
Why?
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 04-18-2014, 10:46 AM   #567
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Originally Posted by m.hony View Post
Lift the truck and trailer higher...
Should almost go on with just hand pressure- no cheater needed-
Lift it as high as the jack will go if necessary...
Duh...I tried all that, gotta get longer chains.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 04-18-2014, 12:00 PM   #568
K.C. , Missouri
If you are jacking it all the way up, and still at that point, have considerable tension on the chains, that would sound to me like you have quite a lot of tension when it's lowered back down. Sounds like it's time for a trip to the scales to find out just exactly how much is being transferred to the steer axles. Perhaps too much ??
gmw photos is offline   Reply With Quote
Old 04-18-2014, 12:08 PM   #569
Jim Lee's Avatar
1978 31' Sovereign
1984 31' Excella
Images: 125
I suppose with a little trailer like a scamp or a Bambi, but I'm a 3/4 ton pick up or suburban tow vehicle. Aren't most fwd vehicles unibody?
I've pulled house trailers and concession trailers since 1973, we tow our 31' airstream with a 3/4 ton suburban.
I'm suspecting it depends on your frame of reference.... We've always used trucks to pull our trailers.
My wife's mother dang nor pear ruined her Buick wildcat pulling a 29' travel trailer. It was a Tudor and I think she tweaked the frame. And we never towed with a convertible!
Old 04-18-2014, 12:36 PM   #570
Toronto , Ontario
Which is also not a problem. Depending on where you choose to apply force, unibody vehicles can be stronger than body on frame vehicles.
Old 04-18-2014, 12:55 PM   #571
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
The only problem I have towing with a unibody vehicle is more noise is transferred from the trailer into the passenger compartment.
That is certainly not a reason to not tow with a unibody.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 04-18-2014, 02:41 PM   #572
MrUKToad's Avatar
Chatham , Ontario
I thought we'd buried the myths that unibody and front wheel drive vehicles couldn't tow an Airstream *sigh*
Old 04-18-2014, 05:05 PM   #573
m.hony's Avatar
2013 30' Classic
I might one day tow with a Honda Odyssey. That is what we want for our next vehicle.
TAC #MS-10
Airforums #70955
Old 04-18-2014, 10:14 PM   #574
64Lincoln's Avatar
1964 22' Safari
Sacramento , California
Towing with a big old convertible is just fine. I've been pulling boats, car trailers, and now an Airstream with convertibles all my life. There's nothing like cruising with the top down.
64Lincoln is offline   Reply With Quote
