Old 04-10-2014, 12:34 PM   #547
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
Originally Posted by BMG View Post
Quite right. Can-Am RV did not set it up as we did not have the trailer yet, though we were in the process of making the purchase so they knew what we would be towing.
I took a link out of the chain and that has leveled things out as anticipated. Though I am still about 2/16ths of an inch different between the front and the back of the Sienna. So I'll add a bolt to the chain and see if I can level it out more before I take it out next time.
Here are some fresh pics:
Very nice!
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 04-11-2014, 10:15 PM   #548
1975 Argosy 26
Cantley , Quebec
fj cruiser + 26 ft argosy
We tow our 26 ft argosy with our 2008 fj cruiser. It tow fine.
Manrique is offline   Reply With Quote
Old 04-13-2014, 03:20 PM   #549
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
My Trailblazer towed a lot better this trip with the hitch and added sway bar.
I thought the whole set up could be raised so I went up a hole on the adjustment, angling the ball back some more. Wouldn't you know it, the chains would not reach the hangers no matter how high we cranked trailer and truck. Guess I will now buy the longer chains mentioned awhile back. Drove 125 miles home from camping, with no wd bars ...kinda crappy.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 04-13-2014, 05:59 PM   #550
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
Hi Alan
You were able to connect the bars for the trip out but not for the return?
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 04-13-2014, 06:14 PM   #551
Mineral Bluff , Georgia
On the way to SpringStream Friday I found I took things a little too far.
As a reminder, on my Flex I had lowered the ball, tilted it back a little and shortened the shank about 3" and things looked great with 2 links hanging.
But...
...as soon as we hit the road, things did not feel right. Everything was too stiff and "jouncy", and some expansion joints south of Blairsville, GA got the whole rig bouncing in a coupled fashion - quite uncomfortable.
So today, hooking up for the drive home, I left only one link hanging, assuming that the chains being too tight was the problem.
WOW! What a difference! I think I found the sweet spot!!! Much more compliant over the bumps, while not feeling loose or swaying at all.
As many advised, there's certainly some trial and error involved, but I sure like how it felt today.
FastEddieB is offline   Reply With Quote
Old 04-13-2014, 06:34 PM   #552
Gainesville , Florida
Good job, sometimes it just takes awhile. Enjoyed meeting you two, the trailer looked great. Peace, jim
Old 04-14-2014, 09:27 AM   #553
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Glad to hear that Eddie, your trailer was very nice even if it wasn't an Airstream. LOL
I still am working on my hitch, think once I add a few links of chain, and maybe raise it up a bit more it will be better.
AIR #005
retired!
Old 04-14-2014, 09:29 AM   #554
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Originally Posted by Andrew T View Post
Hi Alan
Yes, I raised the hitch one more notch up and then angled the head back a but more, and could not get the chains on the hangers. I need about two or three more links. The bars seem too low and might need another raise.
AIR #005
retired!
Old 04-16-2014, 09:46 PM   #555
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Use the tongue jack to lift the tow vehicle and trailer. The chain links will go on easily.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 04-17-2014, 10:08 AM   #556
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
they don't
AIR #005
retired!
Old 04-17-2014, 11:23 AM   #557
m.hony's Avatar
2013 30' Classic
Lift the truck and trailer higher...
Should almost go on with just hand pressure- no cheater needed-
Lift it as high as the jack will go if necessary...
TAC #MS-10
Airforums #70955
Old 04-17-2014, 12:03 PM   #558
Selby
Burfield's Avatar
2014 16' Sport
Bexley , Ohio
Send a message via AIM to Burfield
Bambi and FJ
Have 6000 miles so far and no problems with towing or AS. Have rock-tamer guards on Fj and had no damage even after many miles on unpaved roads in AZ
Name:	Last 12 Months - 213.jpg
ID:	209838   Click image for larger version
Name:	Last 12 Months - 022.jpg
Burfield is offline   Reply With Quote
Old 04-17-2014, 01:09 PM   #559
Selby
Burfield's Avatar
2014 16' Sport
Bexley , Ohio
Small Fj and small AS Bambi
Attachment 209840quick rest stop in the middle of nowhere...
There was an error processing this video...
Old 04-17-2014, 09:36 PM   #560
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
Hi Burfeild
You really should have some weight distribution on your combo. It will give substantially more control should you need to make any evasive maneuver. It will ride much better as well.
Andrew Thomson
London, Ontario
