Old 02-16-2014, 09:03 AM   #407
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Do I need to get this?
Here is a possible solution..what do you think?
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 02-16-2014, 09:24 AM   #408
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
no, not strong enough. You need a drop-shank with an adjustable head so you can dial that in to the correct height. (and tilt the head back for proper WD).
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 02-16-2014, 09:27 AM   #409
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I see...will be looking now.....
AIR #005
retired!
Old 02-16-2014, 09:31 AM   #410
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
how does this work? Not sure if I get the set up
found this..?
AIR #005
retired!
Old 02-16-2014, 11:54 AM   #411
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
yeah, that's it (there are various types/sizes, but that's the thing).
Then you attach an adjustable hitch head to it--it bolts to the shank through 2 of those holes, so there are multiple possible positions, allowing you to set it at the best height.
here's a Reese head:
Reese Towpower 58167 Adjustable Ball Mount Trunnion Hitch : Amazon.com : Automotive
You should be able to find one that matches your WD make/model.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 02-16-2014, 07:30 PM   #412
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
Alan,
Look at the previously mentioned links (or do some additional searches) and find shanks that have the correct "drop"
I was at PECO recently and they have new and used shanks. Country Boy Trailers in Cumming also sells shanks. Both places were very helpful.
I bought a Curt shank - they were one of the few mfrs. that make the 9" drop that I needed. Both PECO and Country Boy will likely have what you need.
Amazon has very good prices on Curt shanks but you need to know exactly what you need in inches of drop.
Good Luck!
Lucius and Danielle
1992 29' Excella Classic
1996 GMC Suburban C2500 7.4L
2005 Chevrolet Suburban K2500 8.1L
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 02-17-2014, 06:42 AM   #413
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Yes now that I understand what is needed I have been looking. There is a hitch store on US 41 near me.
AIR #005
retired!
Old 02-17-2014, 12:55 PM   #414
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I found a Reese set up, but wondering what weight bars to get.. my tailer is 800lb tongue weight. 4200 trailer weight
AIR #005
retired!
Old 02-17-2014, 01:08 PM   #415
K.C. , Missouri
Alan,
Of course, do this however you see fit, and try to figure it any way you like, but if it were me, I would take the new tow vehicle and the trailer to the CAT scale, and get the initial numbers ( truck by itself, and the trailer just "on the ball" ) and proceed from there in choosing appropriate weight distribution bars.
EDIT: 800 pound tongue on a 4200 pound trailer is 19%. Not saying you are wrong, but that sounds like an abnormally high percentage.
gmw photos is offline   Reply With Quote
Old 02-17-2014, 01:13 PM   #416
K.C. , Missouri
And not trying to divert attention away from Alan's current questions, but what have you all with Mark and his Chysler 300C ? He has not been back since Feb 5th. Has he hit the road with the A/S in tow behind the 300, and having so much fun that he can't even stop long enough to check in ..... ? ?
Old 02-17-2014, 05:20 PM   #417
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
on the road again!! as Willie would say.
AIR #005
retired!
Old 02-17-2014, 05:22 PM   #418
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Originally Posted by gmw photos View Post
Alan,
you are right sir! I went on another site ( AIRSTREAM.com) and the correct tongue weight is 400.
So a 1000 pound tw hitch is overkill I guess. Funny but less expensive than a 750 or 550
AIR #005
retired!
Old 02-17-2014, 05:39 PM   #419
K.C. , Missouri
Not to put too fine a point on it Alan, but the "correct" tongue weight is.....( drum roll please...)...... what ever the scales say it is for "your" trailer loaded as "you" would do for a trip.
EDIT: a 4000 pound travel trailer might reasonably be expected to have about a 600 pound tongue weight.
Old 02-19-2014, 07:57 AM   #420
StreaminGuy's Avatar
1967 17' Caravel
Cumming , Georgia
Hitch ball height of 20.5" very important
Alan,
GMW is exactly right... load, how full the propane tanks are, fresh water tank filled, etc., all contribute to varying tonque weight for your particular rig. What is VERY important is hitch ball height. Your loaded, ready to travel, on level ground, measured from the "ground to the top of ball" HITCH BALL HEIGHT should be 20.5". I use a measuring stick to measure mine. Slightly less would be better than slightly higher if you can't get it dead on. It will make the difference between feeling like you are towing the trailer or "dragging" the trailer. When you have too low of a hitch height, it makes the trailer feel much heavier. The type of adjustable hitch that you aquired is just what you need. I've owned 97 vehicles in my life and have towed our Caravel with nine vehicles that i can think of. Even with the two duallies I've had, I could tell a big difference towing when hitch ball height was off or when weight bars were not used. If you want to see this for yourself, set it up and tow at 20.5" then drop it down to about 17" and go back out...you'll be checking to see if your parking brake is on.
Thanks, G
StreaminGuy is offline   Reply With Quote
