Old 01-28-2014, 05:36 PM   #281
TahoeStream'n
subfan1's Avatar
2012 20' Flying Cloud
La Habra , California
Originally Posted by Mcdenny View Post
Update-I just looked at the temps after driving (not towing) for an hour, 75F ambient temp. Trans 201, engine oil 199.
Are you sure you're not confusing oil temp and coolant temp? My gauge for the oil is in pressure and it does not show oil temperature. What vehicle do you have?
subfan1 is offline   Reply With Quote
Old 01-29-2014, 08:21 AM   #282
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I got a nice note from the member towing a 31 with a Volvo... She says it's been great for them
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 01-29-2014, 08:28 AM   #283
Marine city , Michigan
Nope, it shows oil temp, oil pressure, trans temp, oil life, tire air pressure, alternator voltage, all on a driver selectable digital readout. It has a permanent analog coolant temp gage, like the gas gage, too.
I have a 2014 jeep but this has been standard on lots of Chrysler products for many years.
Denny Wolfe
www.wanderingourway.wordpress.com
Mcdenny is offline   Reply With Quote
Old 02-02-2014, 12:51 PM   #284
mstephens's Avatar
2013 25' Flying Cloud
Cat City , California
My Chrysler 300 has hit a snag. I just can't get enough WD.
We went to the scales yesterday and out of 820# of tongue, only 140# got transferred to the front axle. Leaving 680 on the back. I test drove it briefly on the freeway and it felt light on the front and the wind was moving us around.
Today I tried adjusting the WD. First I tried getting up to the third link in the chains. Impossible. First, no way to jack the car that high. Second, I put a scissor jack under the bars and tried getting them up to the third link. Impossible, and worse yet, we created a dangerous situation with heavy parts flying. Extra links out of question. I then tilted the head back more. Ok, that again requires a higher lift of the car. We got it on the first link and I went back to the scales. That added a whoopping 60# to the front, 60# to the trailer axle, and took 120# off the back. Not nearly enough. That makes a total of 200# to the front.
How on earth can people be getting 300# or 400# of WD? By what conceivable method can the bars be lifted that high? Jacks? Winches? Cranes? Muscles? I don't get it. As it was, I nearly had the back wheels off the ground. Certainly my tongue jack is going to burn out lifting the car that high. I could almost smell the motor.
Driving home I was ready to just chuck the whole thing in, trailer and all.
mstephens is offline   Reply With Quote
Old 02-02-2014, 01:22 PM   #285
SteveH's Avatar
Common Sense , Texas
As I remember your new setup is using an Easy lift hitch? What weight bars are you using?
Regards,
Steve
Old 02-02-2014, 01:58 PM   #286
mstephens's Avatar
1000# bars.
My TW is 820# or slightly more as measured.
Old 02-02-2014, 02:01 PM   #287
SteveH's Avatar
Originally Posted by mstephens View Post
1000# bars.
Sounds like it should work with those bars. How much weight are you trying to distribute to the front?
Maybe you should call Andy and let him help you.
Regards,
Steve
Old 02-02-2014, 02:16 PM   #288
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, don't give up yet; I'm sure there is a way to get proper WD. My tongue jack has raised my Lincoln Navigator's wheels completely off of the ground a few times. Didn't hurt a thing. I'm sure your "300" is a lot lighter.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 02-02-2014, 02:19 PM   #289
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
For what it's worth, I have to jack the back of the Sienna up to the point at which the car's wheels are about to leave the ground. It hasn't harmed the jack over the past three seasons (yet) and my good friends at Can Am tell me it's all perfectly normal. The fuse went once, early on, but hasn't since.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 02-02-2014, 02:20 PM   #290
Road Ruler's Avatar
Images: 38
I can't believe there is an issue here that is a problem. We have a similar setup and it easily transfers weight and it's no big deal to attach the bars. Mr. T. is the man to talk to.
Old 02-02-2014, 02:40 PM   #291
mstephens's Avatar
I'd like to get 300# to the front as a minimum. That means 100 more. Yes, I'll call Andy on Monday. I hate to be such a pest on the poor guy. He's been very helpful already.
There's not that many variables that I can see. More WD required more force applied on the chains - no choice.
Old 02-02-2014, 02:43 PM   #292
SteveH's Avatar
Yep that's about right, but why have you decided on needing 300#'s of transfer to the front axle, I believe you have installed air shocks?
Regards,
Steve
Old 02-02-2014, 02:43 PM   #293
mstephens's Avatar
Ahhh, so you are in the same boat it sounds like? Do you know how much WD you are getting on your Sienna?
Dumb Question: What would happen if the rear wheels lost touch with the pavement? Does the parking brake work on the front wheels too? We've been wickedly nervous about such a high lift of the back of the car.
So maybe it "ain't no big deal?" Really? REALLY? LOL
Old 02-02-2014, 02:47 PM   #294
mstephens's Avatar
Good question Steve.
First, I just assumed we want to get our f/r weight distribution close to what the car is without a trailer. 51% front. Second, when I test drove the first condition (140# on front) the steering felt too light. There was a bit of wander, and the steering felt a bit vague. This was at 55 MPH on the freeway.
My intuition says that when hooked up, I will get the best handling when the f/r weight ratio is as close as I can get to 51%.
