Old 09-12-2019, 11:09 AM   #1
airdreamer
Airdreamstx's Avatar
2019 27' Flying Cloud
1961 16' Bambi
1953 17' Clipper
Del Rio , Texas
Short girl. Tall truck.
I recently traded in my 2019 Ram 1500 for a 2019 Ram 2500. I am a solo traveler and 53. 😁 I am loving the 2500 and how much better it pulls, but it is SO TALL!?! I have a 2019 28FC with the anti sway system that my Airstream dealer Installed. I have to put the orange squares or something under the jack to get it tall enough to hook up. I feel like the front gets too high and its kinda freakin me out! I am at a state park now and my space has a slight downward slope to it. Im backed in and there is a slight drop off at end. When I was raising the jack to get the trailer unhitched, I had visions of my AS tipping back and going off the ledge! I have everything in place like Im supposed to and my trailer is sitting in the actual space. Now down the hill! But I think Im going to have a mild panic attack every time I have to hitch/unhitch! Those of you with a tall truck, is this normal or what do you do? Please advise
Airdreamstx is offline   Reply With Quote
Old 09-12-2019, 11:19 AM   #2
kpm
2018 25' International
Mound , Minnesota
We have an Equalizer hitch with a Ford F350, which is a pretty tall truck. We always extend the foot by five holes when unhitching just to make sure the tongue jack will be able to lift the tongue high enough. It can get pretty high, as you have seen, but by extending the foot we haven't had to use any blocks.
You didn't say how your hitch was set up, but one of the main things when setting up a new truck is to make sure the trailer frame is level when the weight distribution hitch is engaged. If not, adjusting the hitch is necessary. Depending on the brand of the hitch, a longer shank may also be needed for a taller truck.
kpm is offline   Reply With Quote
Old 09-12-2019, 11:29 AM   #3
Alumaholic's Avatar
Albuquerque , New Mexico
Images: 36
Wrong Shank Maybe?
Sounds like whoever set up your weight distribution hitch didn't replace your old shank with a new shank with a longer drop appropriate for your tall truck.
Please send us some pictures, and we can help.
Ken L
2019 Flying Cloud 27FB
2018 GMC Yukon Denali XL
Four Corners Unit WBCCI #5783
Alumaholic is offline   Reply With Quote
Old 09-12-2019, 11:38 AM   #4
2019 30' International
Pennsylvania , Pennsylvania
Sounds like you need to adjust your hitch on the truck, the ball needs to be lowered using a drop hitch.
When the trailer is level and you back up to it, the top of the ball should be about the same height the top of the receiver on the trailer hitch.
https://www.etrailer.com/faq-ballmount.aspx
If you ain't havin' fun you ain't doin' it right
2017 Ford CCSB F250 XLT 6.2L Gas 4x4 Ruby
2019 International Serenity 30 Rear Twin
majorairhead is offline   Reply With Quote
Old 09-12-2019, 11:46 AM   #5
airdreamer
1961 16' Bambi
1953 17' Clipper
Del Rio , Texas
Here ya go
ID:	351995   Click image for larger version
Old 09-12-2019, 11:55 AM   #6
airdreamer
1961 16' Bambi
1953 17' Clipper
Del Rio , Texas
Current situation
Old 09-12-2019, 12:01 PM   #7
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
You are going to have to replace the shank, i.e. the part that goes into the receiver on the truck that the hitch ball is bolted to. If the trailer is level as shown, the ball should be at or just above (to allow for some sag, but your 3/4T may not sag much) the height of the coupler on the trailer. Your Airstream dealer should be able to order the proper shank and install it for you.
I should add that towing as you are set up puts extra stress on the rear axle, and reduces tongue weight which may contribute to instability. It is important to tow with the trailer level.
Quote: "...When I was raising the jack to get the trailer unhitched, I had visions of my AS tipping back and going off the ledge! ..."
You do have the wheels chocked when unhitching, right?
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
Old 09-12-2019, 12:02 PM   #8
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Have the same truck - agree with other posters
I agree with the two previous posts and would bet the dealer did not replace your 1500s shank. We also replaced a 2019 Ram 1500 with a 19 2500 and found it was about 3 higher. Our old Blue Ox shank ran out of adjustment before the trailer was level.
I took the opportunity to I get a 2.5 shank that eliminates the need to use the reducer sleeve (came with your 2500). Im using a Curt 12 rise, 8 drop from eTrailer: https://www.etrailer.com/Accessories...rt/C17132.html
Your trailer should be level at the hitch when connected to your truck. By installing a drop shank, youre effectively making the ball height the same as your old truck. No more feeling like youll tip over your trailer on its back side!
Good luck!
ID:	351999   Click image for larger version
2019 27 Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB (traded)
2019 Ram 2500 Laramie Blue Ox 1500#
WBCCI# 10258
2020 Retirement Plan
jeffmc306 is offline   Reply With Quote
Old 09-12-2019, 12:03 PM   #9
Indeed, you can see how your ball height is higher than the hitch on your trailer. You need to drop your ball height. Go to an rv dealer that sells the equalizer hitch and have them set it up properly for you.
Old 09-12-2019, 12:06 PM   #10
airdreamer
1961 16' Bambi
1953 17' Clipper
Del Rio , Texas
Thank you all very much for the info and guidance. Not sure why my Airstream dealer wasnt the one to figure this out but now I know. Im on Dallas area so I will probably try to find someone local. But that means another panic attack to get the hitched up and fixed. 😬
Thx again!
Wendy
Just a girl with an AirDream.
Gig Em 👍🏻
WHOOP!
[url]www.AirDreamsEntertainment.com[/url
Old 09-12-2019, 12:08 PM   #11
Also, for future reference, that pin on your trailer jack stand, in the last picture, right above the orange blocks you're using, that pin pulls out and the jack stand can slide/extend up and down.
Just make sure you have it all the way up, or close to all the way up, and pinned in before you travel.
Old 09-12-2019, 12:10 PM   #12
Just an fyi, you can't remove that pin in the position you're in now, you can only move that jack foot up and down when the trailer is hooked up to your truck.
Also, if you take out that pin, hold on to the foot end of the jack stand so it doesn't come the whole way out.....it can be tough some times to slide it back in.
Old 09-12-2019, 12:13 PM   #13
airdreamer
1961 16' Bambi
1953 17' Clipper
Del Rio , Texas
Got it! Thanks again!
Wendy
Gig Em 👍🏻
WHOOP!
Old 09-12-2019, 12:26 PM   #14
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Airstreamstx,
Looks like the hitch is going to be reset with a longer shank as others pointed out, good advice.
Can I suggest a few points to check while setting up the hitch again?
Ball shank length. Just flip the head assy over or look under the head and see of the shank length is interferring with the WD bar socket movement. It will be obvious it leaves big divots on the underside of the shank and on the WD sockets.
Ball nut, check to see if its tight. This requires a big wrench and socket.
Apply grease to ball. It looks like this ball has been run dry and that can scratch things up. Grease light film on ball regularly reapplied and wiping down inside of hitch ball socket once in a while makes stuff wear less.
Best of luck with new truck.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Biker Girl is Back she ran off Match.com Girl Jim Clark Off Topic Forum 8 09-13-2012 03:43 PM
Short -Short Ramp Lights - Interior & Exterior 0 09-12-2007 04:34 PM
The Short, Short Trailer - Spamboree flamingo-kid1 On The Road... 2 04-14-2005 01:41 PM
Tall Ships Rally Halifax, NS - All Welcome Richard Vroom WBCCI Forum 3 06-06-2004 05:44 PM
My trailer's too tall! Windspill Axles 17 08-31-2003 05:01 PM
