Old 06-29-2005, 08:55 AM   #15
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
Airstream666,
Rancho shocks are not air shocks. These are gas shocks with controlable valving.
crispyboy is offline   Reply With Quote
Old 06-29-2005, 11:10 AM   #16
Crispyboy and others.
Air shocks, inflated to anything except "MINIMUM" air pressure, progressively defeats the purpose of a load equalizing hitch.
The same is true for air bags.
If your "not" towing then use whatever pressure you need.
If you "are" towing a travel trailer with a load equalizing hitch, you must use "minimum" pressure, in air shocks or air bags.
Research by Caravanner insurance company, the old insurance division of Airstream, proved those facts in 1970.
It also proved that improperly inflated air shocks or air bags, accounted for "TWO THIRDS" of all Airstream trailer loss of control accidents.
Old 06-29-2005, 12:23 PM   #17
Troubs Roady Emeritas
airstream6666's Avatar
1979 31' Excella 500
1974 27' Overlander
1974 27' Overlander
Livingston , Texas
Send a message via MSN to airstream6666 Send a message via Yahoo to airstream6666
Originally Posted by crispyboy
Airstream666,
Hiya crispyboy,
I'm very sorry.
I reviewed my post to see how I got there. I had even viewed the Rancho website (and, in particular, the write-up on the 9000), before I wrote my post. I don't have any idea now what may have been in my head beyond responding to your ability to dial in adjustments from the dash and an old preconception.
I didn't mean to offend, and I appreciate your taking the time to correct me.
Y'know, you may even convince me to change over if the 9000 does what I need it to do. In addition to dragging Airstreams around, I also have to load a buncha heavy dive gear quite often, really changing the expedition's character as I load as much as 1,000 lbs. of dive gear. It's hard to believe how six steel 100 cubic foot tanks, plus two dive scooters (over 100 pounds each), plus other miscellaney can add to two divers' gear.
This added weight, and the switch from several Overlanders to the heavier 31, sure makes the switch from suburbans to the expedition seem foolish.
To make my foolishness worse, I even go offroad periodically (but never to the stage 5+ level the TR writer seems so fond of) in search of trout, abalone, lobster, or different/better camping.
Thanks, again.
Johnny
airstream6666 is offline   Reply With Quote
Old 02-10-2015, 07:09 AM   #18
r carl's Avatar
Lin , Ne
What do you think about the auto leveling systems they have now?
traveling with worn axles funkill On The Road... 5 10-27-2008 05:52 PM
Worn torsion bars woodnhair Axles 12 01-13-2006 09:55 PM
magnets worn remcolent Brakes & Brake Controllers 15 03-19-2004 08:49 PM
Dye worn cushions? Rog0525 Upholstery, Blinds, Walls & Interior Finishes 18 03-09-2004 01:31 PM
Are my axles really worn out???? till Axles 5 02-21-2004 05:23 PM
