Old 08-31-2010, 09:28 PM   #1
gaylejoe's Avatar
2007 25' Safari FB SE
St. Hedwig , Texas
Shock Recomendation
My 06 Dodge 3/4 ton Cummings will be needing shock sometime in the future. I really don't want to stiffen the ride to the point of popping rivets on the inside.
gaylejoe is offline   Reply With Quote
Old 09-01-2010, 06:24 PM   #2
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Consensus is on BILSTEIN. shockwarehouse.com and others.
Old 09-10-2010, 05:26 PM   #3
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
I'm running Rancho adjustable shocks so far I'm using the same setting empty as loaded, no control or ride issues to report. Most likely 60K on shocks or so but only 600 towing miles, no plans to change. The factory shocks did not do the job on my 2003 Ram 1500 either.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 09-13-2010, 01:46 PM   #4
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
I just installed a set of Monroe Magnums on my 2003 Dodge/Cummins. I've only pulled the AS Excella about 1,500 miles since installing them, but they seem to be doing the job very well.
I ran the originals for around 70K, which was about 20K more than I should have...the Monroes give a decent ride, plus a lot better ride...
For whatever it's worth
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Airstream Shock! mmario Electrical - Systems, Generators, Batteries & Solar 4 09-24-2009 07:49 AM
shock mounts tebone Land Yacht/Legacy Motorhomes 4 12-20-2008 03:19 AM
Shock clearance toastie Shocks 14 10-08-2008 03:20 PM
Winter Trip recomendation: Eagle viewing Boondocker On The Road... 36 12-06-2007 04:07 PM
63 TW shock Moonshot Shocks 5 08-26-2002 09:24 AM
