Old 02-04-2010, 07:55 AM   #1
boutdoors's Avatar
2010 16' Sport
Madison , Wisconsin
Setting Up Tow Vehicle
I will be setting up my tow vehicle soon from scratch. Need some advice. I have a 2002 Tacoma 4x4 with a Manual Trans.
Do I need to upgrade the battery, is there a special battery I should get that is beefier? Should I consider replacing shocks? Should I use Higher Octane gas?
Thanks in advance for any advice.
boutdoors is offline   Reply With Quote
Old 02-04-2010, 08:02 AM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
You don't need to upgrade the battery unless it is old and weak.
What shocks do you have on the truck?
You will damage the engine if you use a higher rated octane than the engine is designed for.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 02-04-2010, 08:15 AM   #3
Road Ruler's Avatar
Images: 38
A key ingredient would be a.... Hensley Arrow cub... Trailer Sway Elimination Guaranteed - Hensley® the ONLY trailer hitch guaranteed to totally eliminate trailer sway.
Old 02-04-2010, 08:18 AM   #4
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Lee,
What makes you say that? I always thought that putting higher than needed octane in is just wasting money, not a source of actual damage.
Chris
Old 02-04-2010, 08:38 AM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
No, No, and No,
More important is what rear ratio does the truck have, how many gears, and what weight will you be towing?
2004 Excursion 4x4
Old 02-04-2010, 08:58 AM   #6
boutdoors's Avatar
2010 16' Sport
Madison , Wisconsin
Transmission Type
2.7L with 5-speed manual
Gear Ratios (:1) (4WD) 1st 3.954 2nd 2.141 3rd 1.384 4th 1.000 5th 0.810 Reverse 4.091 Differential Ratio 2.7L 3.909
Old 02-04-2010, 08:58 AM   #7
boutdoors's Avatar
2010 16' Sport
Madison , Wisconsin
Not sure if that last post answered the question? Will be pulling 2800#
Old 02-04-2010, 09:25 AM   #8
HowieE's Avatar
Images: 12
That should work.
I assume the trailer has brakes.
get a good coolant temperature gage and drive with it, for gear selection, when in the hills
2004 Excursion 4x4
Old 02-04-2010, 09:31 AM   #9
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
boutdoors, in another thread there was a long discussion with you about the difficulty of pulling an Airstream Sport 17 at 3500#. What will you be pulling at 2800# ?
The more information you can provide, the better help you will get, in a much shorter thread.
Old 02-04-2010, 09:31 AM   #10
boutdoors's Avatar
2010 16' Sport
Madison , Wisconsin
Trailer does have breaks and will be using weight dist. hitch etc.
Not too many hills where I live and plan on upgrading tv in the next couple of years.
Old 02-04-2010, 09:56 AM   #11
boutdoors's Avatar
2010 16' Sport
Madison , Wisconsin
Sorry, just quoting dry weight. Will plan on pulling 3300# total.
Old 02-05-2010, 07:16 PM   #12
boutdoors's Avatar
2010 16' Sport
Madison , Wisconsin
Would there be a reason for me to upgrade my alternator?
Old 02-05-2010, 07:25 PM   #13
Road Ruler's Avatar
Images: 38
Probably not, it should be fine. Be sure your battery is in good shape.
Old 02-05-2010, 07:30 PM   #14
boutdoors's Avatar
2010 16' Sport
Madison , Wisconsin
Thanks Ruler
I posted this on the electrical threads, but one more question.
Does anyone know the proper wiring I should get for my tow vehicle? Are the new trailers 7 pin round? Does this include the charge line for the trailer battery?
Sorry for the newbie questions.
tacoma, tow vehicles
Need new tow vehicle Barry Parkof Tow Vehicles 26 10-17-2009 04:11 PM
My new GM Tow Vehicle RangerJay Tow Vehicles 6 08-13-2009 08:13 PM
my new tow vehicle wayne.yl Tow Vehicles 25 01-22-2007 08:43 PM
My new tow vehicle juel Tow Vehicles 50 02-22-2006 06:26 PM
Help with Tow Vehicle Craftsman Tow Vehicles 11 07-24-2004 05:43 PM
