Old 10-06-2007, 09:12 AM   #15
genearnold's Avatar
1992 34' Limited
Grand Island , Nebraska
What you are describing may be this (if I get the pictures sent). This truck is on E-bay and will sell today (E-bay # is 290165895807). If my pictures donít post you can check it out on E-bay. I tried to find the company but they apparently are no longer producing the product. The product is called Hide-N-Side Storage.
The pictures wouldn't post, sorry.
Gene
'92 Limited 34ft (now sold); '96 Dodge Cummins 4X2, 5speed
genearnold is offline   Reply With Quote
Old 10-06-2007, 10:42 AM   #16
gunnyusmc
Gunnyusmc's Avatar
Livingston , Texas
Images: 69
Bed
IFW Bed Slide
I have this and it is great. It will support 1200 lbs on the end when fully extended.
Gunny
Gunnyusmc is offline   Reply With Quote
Old 10-08-2007, 07:45 PM   #17
2007 25' Safari FB SE
Suburbia , Sunny So Cal
Clancy, Unfortunately Royal does not show it on their webpage. I'll give them a call.
The drawers and bed slides don't cover my needs.
The search continues...
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 10-14-2007, 07:46 PM   #18
Doorgunner,
Is your plumber back from vacation yet?
I still have not found a manufacterer for the bed yet.
WBCCI 6731 FCU
AIR# 13896
CA 4
Old 10-15-2007, 09:58 AM   #19
starflyte1's Avatar
Lady Lake , Florida
Bed Slide
We have the Bed Slide that Gunny linked to. We would not be without it.
Pat
AIR# 16756
WBCCI# 6167
starflyte1 is offline   Reply With Quote
Old 10-15-2007, 10:16 AM   #20
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Care to share what those go for?
I'm going to bid $2500 Bob....
All kidding aside, that would be nice for long trips. Plus a guy could bolt down his genset to the thing and just pull the tray out when it is time to charge up!
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 10-15-2007, 10:50 AM   #21
starflyte1's Avatar
Lady Lake , Florida
We paid about $800 installed. That was about $500 less than the other place we called.
Pat
AIR# 16756
WBCCI# 6167
Old 10-29-2007, 09:02 PM   #22
Phoenix , Arizona
Service Bed
Originally Posted by Goin camping
A few weeks ago I was passed by an F 250 and it took a moment to register that it had a service bed on it.
The exterior sheet metal had the same body lines as a stock bed and it was the same width and hieght. It had access doors on the outside. The inner bed was narrower.
I have not been able to find that bed on the internet. Anybody have any ideas or knowledge?
I think this may be what you are looking for. The Royal Summit/Sport Utility Truck Body
DesertDog is offline   Reply With Quote
Old 10-29-2007, 09:18 PM   #23
Thats it! Thank you very much.
WBCCI 6731 FCU
AIR# 13896
CA 4
Old 10-29-2007, 10:07 PM   #24
_
didn't see the o.p. till now.
i've been considering the royal/summit sport/utility bed for more than a year.
http://www.airforums.com/forums/441866-post28.html
it is a cali product so purchase and install should be relatively easier for u.
i met a camper with one last year and fiddled with it up close, also a ford.
then a few months later met someone with the ge'em version.
there IS adequate space for a genset and aux fuel and compressor in the forward doors...
the compartments aren't as deep as the typical flat side models...
and it is NOT as well made as the other 3 top/common brands.
but it looks GREAT upclose and ON the truck.
the royal is just a few inches taller than the stock bed as i recall.
it does weigh significantly more than a stock bed even with a shell...
and the load is further away from the truck center, which is bad for handling
so IF you are anywhere close to rear axle/payload limits already, that becomes an issue...
not so much on the 350 but on the 250s.
i couldn't reduce my payload enough to make it work.
and didn't want to loose the dollar value of my current bed and shell.
also,at the time i corresponded with royal, they did NOT have a good solution for covering the center section (like a little shell) where bikes can fit
and they weren't sure how much longer they would produce this model, they were waiting for info the 2008 trucks...
on the ford side the 2008s use exactly the same side contours as the last model...
so royal would NOT have to change much with this unit for new the new superduty (exhaust heat would be a big issue)
so g-c, if you follow up with them please let me know...
i still really really like this utility bed...so much so that i've considered ordering a new 350 truck sans bed.
and doing the royal addition up front.
cheers
2air'
Old 10-29-2007, 10:29 PM   #25
2Air,
I'll be checking the quality, price, requirements for installation, wieght and whether I can purchase from the Manufacturer.
A cap is not an option for my usage. Thus my interest in this truck bed.
WBCCI 6731 FCU
AIR# 13896
CA 4
Old 10-30-2007, 06:47 AM   #26
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
2Air,
I can only speak for the one Royal replacement bed I saw and the quality was poor.
All the door latches were plastic and thus had been replaced with pad lock hasps from a hardware store. Not my idea of quality. It was rusting badly, the metal was not treated on the underside and from what I saw was only primered (a guess as I had to look past the surface rust to spots that still had paint and it was grey) The right side lower compartments had holes the size of some tools and were not useable - my pest control guy used them for large bottles.
I do like the design and functionality of the bed - just quality is a concern with it being aftermarket. I would keep the original bed as a resale value item - tough to store but so is an Airstream..........
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 10-31-2007, 10:07 AM   #27
I called Royal and spoke to a nice person in sales. I was prepared with my list of questions and never got past the first one. They stopped making the bed several years ago. Oh well.
WBCCI 6731 FCU
AIR# 13896
CA 4
Old 10-31-2007, 11:33 AM   #28
_
thanks for the update g-c
there are others that have contoured sides, the grand challenger (gcx) is one example...
Stahl :: Grand Challenger
go to the pdf document "build your own truck body" it has a ford version on the cover....
not exactly the ford profile but less boxy than the typical flat sided models...
the kss from knapheide is similar...
Knapheide - Products
many of the 5ers use a steel with fiberglass model produced in the pacific n.w.
very well made and plenty of room.
reading, stahl, and knapheide are some of the widely available brands....
and jomac makes some with SHINY ALUMINUM sides, cool!
keep up the hunt...
2air'
Getting Bed Down pizzlerot 2006 - 2010 International 6 06-08-2007 01:48 PM
Bed vs. Sofa Bed ardenrj General Interior Topics 4 03-20-2007 08:56 PM
Bed Change rainman General Interior Topics 19 10-23-2006 10:15 AM
long bed vs short bed towing 8400 lbs. longears Tow Vehicles 24 08-09-2004 03:32 PM
What's under the bed? DaveJ Airstream Motorhome Forums 4 10-29-2003 06:35 PM
