09-29-2010, 06:58 AM
#21
1 Rivet Short
1989 25' Excella
By The Bay
, Rhode Island
You have quickly discovered the limiting factor of ½ ton vehicles; payload. Adding springs, air bags, etc does NOT change payload capacity.
A WD hitch does not decrease the amount of tongue weight either.
As you also commented; just because you can do something does not mean you should. Some Folks don’t mind loading to the max (or over) and may have got away with it for a trip or two.
But who wants to count every pound you place in the truck or AS every time you load up?
No one ever complains they have too much truck.
We load all kinds of crap on many of our trips; Mt bikes, kayaks, porta-bote w/outboard motor, fire wood. Heck I have 1000# in the truck before we hitch up or sit down. This would bury a ½ ton.
You can travel light (no water, no waste, only 5 beers, etc) and worry about your load the entire drive.
Or you can buy the right vehicle, load up, and go.
This is no 16’ Bambi your talking about towing…get the right truck.
Take a look at an old thread from a while back; http://www.airforums.com/forums/f463...hip-39826.html
Good luck, be safe.
Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
09-29-2010, 08:01 AM
#22
St. Catharines
, South Western Ontario
It dosen't change the static tongue weight but when you go to the weigh scale with the WDH installed you will see that the WDH does reduce the weight the trailer tongue has on the vehicle.
By moving a portion on the weight to the trailer axles you can pick up roughly 100 to 250 lbs of payload as it relates to the static tongue weight.
Actually many forks do complain about having too much truck! There are many many threads and reports of heavy duty trucks messing with the airstream structure. They also compain about the rough ride, noise and cost of operation in many cases.
Yada Yada Yada... For ten years we have been towing with everything we need plus water and waste and have "0" worries with load or drive.
Yikes!!!! . In "your case" need a big truck. Agree 100%.
[/QUOTE]
09-29-2010, 02:12 PM
#23
2012 25' Flying Cloud
Battle Lake
We travel for months a a time with two bicycles and a small generator in the bed of our 2006 Tundra crew-cab pickup. The Airstream is loaded lightly with everything we need. (There are grocery stores, even beer stores, along the way.)
Unless you need "all kinds of crap" to travel, payload is a non-issue.
Doug K
09-29-2010, 02:30 PM
#24
1 Rivet Short
1989 25' Excella
By The Bay
, Rhode Island
Doug K
When you violate payload...it is an issue...no matter how you do it...with "crap" or with tongue weight; Overweight is overweight...whether you are towing a 16' or a 30' slide, you still need the proper TV.
09-29-2010, 03:41 PM
#25
Master of Universe
2008 25' Safari FB SE
Grand Junction
Carl, I am unsure whether the Tundra can tow a 27 or 28 because the specs keep changing. The tongue weight for a 25' FB is now on the website: 837 lbs.; 27' FB, 791; 28, 976. The website does not say whether that is 2010 or 2011. For the 2008 models, the brochure gave tongue weights for the 25' FB, 720; 27 FB, 790; 28, 830. Both are without options and may or may not include propane in the tanks or the spare.
The differences mystify me. You could ask Airstream about this. The models are essentially the same, but they may have changed the options to include an anvil collection.
The only way you can be sure of tongue weight is to weigh it. To ask the dealer to do that may not go well with them as they would rather tell you something less than it is. Three years ago your local dealer tried to convince me I could tow any of these trailers with the 2002 Tundra I had then. We left shortly thereafter—the salesman went to answer the phone and after he didn't come back for 15 or 20 minutes, we left. I recommend looking at dealers in other states.
The weights of the trailer itself loaded (GVWR) haven't changed even though the tongue wt. has. The 25' FB and the 28' are the same—7,300 lbs. The 27' FB is 7,600. The Tundra would have no problem towing any of them as far as GVWR is concerned. It can scream up mountain roads and if you want to use enormous amounts of gas, you can go really, really fast.
Payload is the limiting factor for 1/2 ton trucks. The various Tundra models vary a lot. The Crewmax, because of the bigger cab, with 4WD and 5.7 L has less payload than my DoubleCab, but only by about 65 lbs. I believe Toyota specs on payload include a full gas tank.
It is often said that you should keep loads to 80% of stated specs. This is conventional wisdom and seems to be untested. It is also said (I should know, I said it) the Tundra is a 5/8 ton truck. Much of the truck appears to be built as a 3/4 ton but for the 3 leaf rear suspension. Is it possible Toyota planned to come out with a 3/4 ton Tundra and wanted to keep the parts as similar as possible to keep costs down, only adding one leaf? When the truck market collapsed, there was no reason to bring out a 3/4 ton.
Adjusting the WD hitch (an Equalizer) properly I brought the truck level within recommendations by the hitch manufacturer—the front axle maybe 1/2" higher than perfectly level. The headlights do not light the sky.
I weighed what was going in the truck plus the options on the truck to figure out how close I was to maxing out payload. It looked reasonable to me, but everyone has to make their own decisions.
The gas tank is too small. At 26.3 gallons, range is 240-270 miles more or less. I carry one or two 5 gallon gas cans. I'd rather have a bigger tank, and having to buy gas more often is a pain. But it gets us out of the truck and walking around and that's good for us.
A problem in figuring this out as I see it is that Airstream keeps changing the specs without changing the trailer. I have seen different sources from them give different specs for the same year. I don't know whether your nearest dealer in Colo. Sprgs. would weigh tongues for you—and would the water tanks have the usual amounts in them and is the propane filled?
You are doing the right things. I figured the payload wts. over and over as you appear to be doing—given less payload on the Crewmax and the differences in tongue wt, your numbers are fairly close to what I figured. You may want to weigh everything again and again. Have you included gas cans, generator, hitch weight? We figured we were at around 90% of payload. The truck handles it well and the leaves aren't pressed flat. We've towed more than 33,000 miles in 3 years. Of course, past performance is no guarantee of future results and your results may vary, but you can try it at home.
Gene
09-29-2010, 04:02 PM
#26
1973 31' Excella 500
Marysville
What would Wally do?
And to think, Wally Baym towed with car/station wagon...
09-29-2010, 04:31 PM
#27
Vintage Kin
Fort Worth
my weight on the truck scale is 6380 lbs with most everything in my truck, not including the hitch load. (I dont own trailer yet so those numbers are a guestimate). This weight was with me, a full tank of gas, the leer cap, bedrug, step boards, moonroof, computer, a pile of books and maps, 60 lbs of tools, and a few small items. I wouldnt add much unless it was people.
Look forward to seeing the scale ticket breakdown between FF axle and RR axle. Plus, what is GAWR for each; and, what is truck GVWR? What does TOYOTA recommend per WDH? Restore FF axle to unloaded weight/height? Or can one "add" a few hundred with a WDH to the FF axle?
And to think, Wally Byam towed with car/station wagon...
So did we all through the 1970's. Not so many trailers weighed over 7k-lbs however. Plenty of "big" trailers were in the 6's. His trailers were puny in size and weight. But with the demise of big block equipped cars by 1978, the Suburban became the default choice. They not only still had the big motors but had greater than the 2.9-3.2 big car gearsets; from 3.54 upwards as I recall. Suddenly it was easy to make trailers porky (and the advent of rolling condo 5'ers). Easy credit didn't hurt either.
09-29-2010, 04:48 PM
#28
2010 30' Flying Cloud
langley
I tow a 2010 30' Flying Cloud with a 2010 Tundra Platinum 5.7 4WD Use a Propride hitch and P3 brake control. The rig is just what I want. Tows fine and the truck can be driven and parked with no problems. I upgraded to a 46 gallon tank
Toyota Tundra Replacement Fuel Tank
and Toyota tow mirrors.
I was overloaded going into Burningman with two Yamaha 2400 generators, 30 gallons of gas for them, full water in the trailer and 50 gallons of water in the back of the truck, plus the usual gear for the Burn. Cranked an extra inch into the Propride, there was no discernible change in handling. If you talk to the folks who actually pull with the Tundra I doubt you will find many who have had problems.
Cheers
Unsui
09-29-2010, 05:20 PM
#29
Master of Universe
Grand Junction
That fuel tank is a solution, but costs $1,184 and adds about 125 lbs. in gas and something more in extra tank weight. I might have considered that when I bought the truck 3 years ago if I had known about it, and Carl has a new truck, but his issue is payload, not gas capacity. It doesn't make sense for me now.
Unsui, you certainly did overload the Tundra, maybe by 500 or more lbs. I hope you didn't substantially wear the drive train or suspension.
Gene
09-29-2010, 06:52 PM
#30
2007 25' Safari FB SE
Eureka Springs
, Arkansas
"No one ever complains they have too much truck."
I don't want to wade in too deep here, but;
there was an Airstream on Ebay this summer (2X's or more) that was being sold by a traveling preacher. His desc. said he towed it with a heavy duty truck and pics showed the damage it caused (which he pointed out).
Pulled rivets in the front windows and buckled panels with resulting structural and water damage.
Andy has preached about a heavy-duty TV. I tried to post the pics, but couldn't figure out how to do it.
Don't know if the AS sold, but until I saw those pics, I figured Andy was anal about these things. I'm thinking he's right.
Maybe a little more truck would be OK!
PS:
I'd love your Tundra!!
09-29-2010, 07:00 PM
#31
1969 21' Globetrotter
Seattle & Olympic Peninsula
Not sure I'd want a 1 ton dually to pull a Bambi with out some kind of shock absorber but generally speaking I couldn't agree with you more.
09-29-2010, 08:30 PM
#32
Colorado Springs
ALL - thanks for all your comments.....
I have attached some pdfs of my spreadsheets. My actual weighed numbers at the scales are: total gross with fuel but without me was 6180 lbs, front axle 3320, rear axle 2820. As you can see from my charts I am already over my guesses
GENE - your comments mirror where I am headed, its not that it wont go down the road, its whether I can feel some comfort in being a little under rather than over the specified numbers, and whether my personal loaded weight is anywhere near what I think it will be. The mystery remains if these toyota or airstream manf numbers have some kink in them related to unknown variable such as the stock tires.
UNSUI - If you ever weigh your vehicle, I would like to know what it is. If you have heavy propride hitch, full 46 gallon upgraded fuel tank, 30 gallons of additional fuel, generators, and the hitch load of a 30 ft trailer, - that number would be something to see, and a photo of your leaf springs...
I am thinking an airsafe to take up some of the suspension, a bigger truck, and more engine, and a bigger gas tank is starting to sound not so bad. The newer trucks maybe have a little better suspension than the older 3/4 tons of a few years ago - does anyone have a comment about airsafe and the newer 3/4 ton suspensions???
09-30-2010, 08:46 AM
#33
Battle Lake
Carl, in your first post on this thread you indicated one person with a lighter payload and the plan to travel to remote places.
Are you sure you're heading in the right direction? Would scaling things down, rather than up, meet your goals better?
Doug K
09-30-2010, 09:05 AM
#34
Master of Universe
Grand Junction
Carl, I looked through your spreadsheet quickly and not thoroughly, but I am impressed with your thoroughness. We bring dumbbells too (and ankle weights), but not as heavy—the problem is actually using them. 200 lbs. of books seems like a lot—we are readers and bring a lot of travel books and other reading, but 200 lbs. seems like 3 to 5 boxes of books—that's more like a starter library. Maybe you are overestimating to make sure you catch it all.
My sloppy weight calculations aren't so different. The numbers from manufacturers differ making it more difficult. I think no matter how careful you are, another 100 lbs. will creep into the truck and maybe more into the trailer.
When you are close to the limit, the numbers from the manufacturers matter a lot and when you find they disagree, frustration starts to set in. Some post on the Forum that manufacturers lie and maximum weights aren't true. I think such a blanket statement is incorrect. Does Toyota lie? When I and others look at the way the Tundra is built, it appears to be overbuilt and perhaps they have a large margin of error. In the absence of our own multimillion dollar testing facility and qualified engineers, we are ultimately left to guessing.
Several years ago I took the Tundra to a scale—the only one in the county—and with gas and my wife and I, but no other cargo, the total weight was around the same as yours. It may have been a little less or more, but it's a while ago. We have a tonneau and running board, so those total a bit less than your options. I didn't have each axle weighed. Subsequently this scale closed and there's nowhere to go unless I drive 75 miles.
We also weighed the things we put in the trailer. Clothes aren't all that much, but food is. Because we eat healthy foods and they are not easy to find on the road, we bring a lot. And if there's a Trader Joe's in a town we go through, we stop and load up on even more. Pots, pans, plates—all that stuff also adds up. Tools, cleaning supplies, keep increasing and adding more. Assume a full fresh water tank and water heater (total 45 gal.), anywhere from 5 to 20 gallons in the black tank and some in grey water—that's maybe 600 lbs. It seemed like when we added it up it was tough to max out the trailer, but I haven't weighed it, possibly because when I can, I'm 75 miles from home and what am I going to do about it? We could go to the hospital there and have some amputations to reduce weight, but I don't think an arm and a leg each would be enough.
The increase in stated tongue weights by Airstream is disconcerting. I think in the end you guestimate and hope for the best. Buy the trailer you want and see how the Tundra does. Selling a new truck and getting a 3/4 ton is a mighty expensive trade.
Gene
09-30-2010, 09:48 AM
#35
Spokane
I am detecting a subtle message that you might actually want to trade in your Tundra. I am with the others when they suggest that you give your setup a try before doing anything rash. Get the trailer, load it up and load up your truck with what you expect to haul and go to the scales. After driving it around a bit you can make your decision and it will be the right one for you. Regardless of which direction you move make sure you get a GOOD weight distributing/anti sway hitch and set it up properly. It will make a big difference. I am a fan of the Equalizer.
All I know is that I am pulling my 25 FB with my '08 Tundra Double Cab without issue. Just did a 2500 mile trip through Northern California and another loop through Central Washington where we traveled over the two highest mountain passes in the state. The Tundra pulled like a dream, rode nicely and got just at 12mpg. This truck can pull your 28 footer and I would question that you could find a better truck in this regard.
If you are all worked up over the payload then go out and get a 3/4 ton and be done with it. Try your Tundra first. I doubt that you will be disappointed.
Good Luck.
09-30-2010, 09:53 AM
#36
St. Catharines
Airstream weights
Airstream should take an extra 5 minutes at the end of the assembly line and weigh every unit. That number should be part of that trailers documentation so at least there is an accurate number to start with.
There is no excuse for Airstream to have numbers that are out by 10% or more.
09-30-2010, 10:02 AM
#37
2008 23' International CCD
Reno
, Nevada
add a leaf option
Carl,
An add a leaf is not a bad idea and the brand Old Man Emu makes one that is full length (i.e. rides smoother than short add a leafs), fits in the stock leaf pack, and are only about $50.00 for the pair. They add a good amount of firmness without feeling harsh.
ernie
09-30-2010, 10:19 AM
#38
1968 28' Ambassador
Cedaredge
Ok, folks you can overanalyze things way to much and you do. Most people who tow trailers don't do half the things I read here and never ever have a problem. Sure sh*t can happen but not only to the person that is towing more than they should it can happen to the annal guy who follows the silly 20% rule to a "T" Still haven't figure out where that came from. the thread I started on it didn't help much.. Though it is a good rule of thumb.
Bottom line here: that Tundra will work fine. I tow with a Sequoia I even prefer to tow my tractor and trailer with it verses my older 3/4 ton dodge. It does a better job.
I put Air bags in the rear coil springs to help with the rear end sag, This way I don't have to crank the WD so much. You have more power than you will ever need. A great transmission. and brakes that can't be beat. I don't even have to brake that much going down hill here in Colorado because the transmission downshifts and does most of the work.
The only thing a 3/4 ton will do is give you a stiffer and a little beefed up frame, and suspension, and to go over the 10,000 # plus with the Tundra would be a very big load.
I say poo poo on the doom sayers . To many retired engineers with nothing to do but crunch numbers and worry about them.
Plus my air bags made the suv ride better than just the coils in the back. Plus you can put 5-35 psi in them to change the ride unlike an add a leaf.
You will be just fine, a 3/4 ton is overkill. Unless you want a diesel.
And stay away from the scales. It will just make you paranoid of your load.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
09-30-2010, 11:08 AM
#39
Alamo Heights
200 lb of books? A Kindle and a bunch of $9.99 e-books from Amazon would be WAY cheaper than taking a kick in the crotch on trading off a perfectly good Tundra... I suspect other weight savings can be had more cheaply than the depreciation hit on a new 3/4-ton TV as well.
09-30-2010, 11:31 AM
#40
Colorado Springs
thanks again everyone -
PURMAN - If we are over-analyzing thats possible - but I’m learning a lot and better able to start defining some comfort zone for myself - that is really the point anyway isnt it? Gather info and make a reasonably informed decision. Where its headed now I am nowhere near 20% under, but will be over on several of the numbers (see next post).
DKOTUM - you are right it doesnt really make sense in a way for a 28 FC for one person. Its sort of separate issue - I want to do some upgrades and not trade the airstream anytime soon.......
GENE - thanks for looking over my charts! I always bring too many books. I am an architect, and I do specs for buildings and have worked with a lot of structural and mechanical engineers, hence the “thoroughness”. Engineers absolutely put in safety factors for things, and sometimes they really overdo it, and sometimes architects really overdo it. It is the way of business sometimes. (But thank God for america and infrastructure and standards, which are sorely lacking in much of the world). But without these manf numbers there is no where to start from, and cars are different from buildings depending on how you look at it, they are very heavily super-optimized.
AFTERMATH - you are a quick one - yes - I started to (suprised myself) like the sound of throwing in whatever toys and tools I want, and having a huge gas tank. I got frustrated as I like "stuff". But I hardly want to give up toyota quality, the ride, the brakes, etc. I am not sure I could actually trade it and drive away - thats a tough one. I have no problem with tundra up to 25s.
