Old 09-13-2007, 08:04 AM   #15
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
In any case this is a LOT of expensive capability to just have for six trips a year. Plan more trips.
Yea, but it's sure nice to have peace of mind and being able to use your AC while going up hill in most cases
Of course though, it all boils down to $$. Get what you can afford and can safely tow your TT.
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 09-13-2007, 08:28 AM   #16
flitzwhopper's Avatar
1976 Argosy 24
Tempe , Arizona
It's a Hemi dude
No doubt about it... get the 3/4 ton. In the Dodges the rear end is fully floating (the axel is not a bearing surface). With the increased tongue weights having a heavy duty rear end is a good idea. If you aren't using it as a daily driver, although my wife prefers the tv for a daily driver, the ride won't matter. We have a Hemi but if I were going to add 1500lbs to the towing weight, I'd seriously consider a diesel. Anything past 6000lbs needs the torque of a diesel if you want to press the speed limit. We have a rally associate that pulls a 25FB with a Dorango and does fine but I don't think that he cares about being at 35 or 40 on 6% grades.
Donna & Mike
Cowboy up! or go sit in the truck
Charter Member Four Corners Unit
WBCCI #2417
flitzwhopper is offline   Reply With Quote
Old 09-13-2007, 08:38 AM   #17
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I guess a lot depends upon how long you are going to keep the vehicle, how often you are going to use it and the terrain. I use my 3/4 ton gas engine van for towing and we only do around 7,000 miles a year with it. I'm no expert on the diesal topic but there seems to be some consensus that lack of use on a diesal vehicle may add some fuel induced risk to the ownership equation.
Other issues I'm curious about is the servicing end. I hear that diesal's may be more expensive to service. Can anyone fill in that side of the equation?
For the type of usage I'm doing, I don't think the premium that a diesal demands in initial cost justifies itself.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 09-13-2007, 08:49 AM   #18
cammur's Avatar
Roseville , California
I have a diesel towing a 25' Safari, and I agree, you are unlikely to earn back in mileage and engine life the premium you pay for the diesel, diesel fuel, diesel oil changes (a lot of oil there!), diesel service and repairs. But there is a comfort factor to the diesel, a sense of knowing my Dodge can do the job, and with a healthy margin. I don't regret having got the diesel - I only regret not having got 4WD. Another factor: if you are soon tempted to replace your 25' with a longer model, as unlikely as that seems now, you will not have to worry about the adequacy of your truck.
Good luck with your decision!
Cam
2005 25' Safari SS
2005 Dodge Ram 2500 Turbodiesel
WBCCI #3580 - Region 12 NorCal
AIR #8752
Roseville, CA
cammur is offline   Reply With Quote
Old 09-13-2007, 09:02 AM   #19
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Not sure diesel is real important. More important that you get the ĺ ton. Gas/diesel is personal preference. Having said that, after 2 seasons with the DA I am now a diesel convert. We use the truck as mainly for tow duty and other adventure trips (skiing, kayaking, etc) but not as a daily commuter. The economy of the diesel has proven itself to me; 15mpg towing with a mess of boats up on the roof, firewood, bikes, etc in the bed (in other words; a lot of stuff). Last winter, with about 10k on the odo we were averaging 21 mpg lightly loaded for ski trips (not towing). I did not get anywhere near this with Ĺ ton/small block gassers. Of course a big block would be even worse as far as mpg. We had a couple of Suburbans, that are GREAT vehicles, but truth is I find the crew cab truck more useful, Still seats five comfortably, but I can throw all kinds of crap in the back (had to be a little more careful with the SUV). I also use the truck for firewood, landscape duty etc. The SUV was fine when I had my business and always had a truck I could use. We scaled back a couple of years ago, and having to choose between a truck and large SUV, Iíll take a truck. Another thing to consider; the new diesels are much easier to live with than a few years ago, no smell, low maintenance, no smoke, no soot on the AS. Really no different than gas as far as day to day issues. I was a little intimidated about diesel as I had never owned one before, my fears were unfounded.
Good luck with your choice.
Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 09-13-2007, 09:03 AM   #20
ghatfield's Avatar
2006 19' Safari SE
Anacortes , Washington
Diesel on hills.... down hills
We have a 25' Classic and pull it with a 2003 Chev Silverado 2500 with a Duramax diesel. I have no experience with other tow vehicles, but this one has served us well. We are about to finish a 12-week tour of the west and we've pulled on some pretty steep hills at high temperatures (e.g., 6% and 113 degrees coming out of Laughlin, NV) and although the speed was down to 35-40mph at times, it has not overheated.
But the biggest advantage of the Duramax combined with the six speed Allison trans (at least in my mind) is going down hills. Even 6% grades require very little braking. It just holds between 55 and 60 on most hills. I don't think you would get this compression breaking with a gas engine.
I've talked to a lot of Duramax owners and all have been very happy with their truck. We have seen a lot of them on our trip. A used truck would be in your price range.
George
ghatfield is offline   Reply With Quote
Old 09-13-2007, 12:34 PM   #21
CanoeStream's Avatar
St. Cloud , Minnesota
George -- that's called Allison Grade Braking. BillTex gave a name to it on Forums first that I recall. Search on those words if interested.
Jack -- My receipts aren't right in front of me. But figure something just under a $100 for oil and filter and almost the same price for a fuel filter change. Of course the electronic monitor doesn't have you do those at the same time... always gonna be two trips.
5 meter Langford Nahanni
Old 09-13-2007, 12:51 PM   #22
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Servicing of an F250 7.3 Diesel
Air Filter - FRAM $14-$15 every 20,000 miles
Fuel Filter - Motocraft (cartridge replacement) $21 every 15,000 miles (a must with a diesel)
Oil Filter - Motocraft $9 every 5000 miles (Oh, go squeal about how wrong this is and how often you change yours somewhere else)
Oil - Rotella T with filter change 15qts X $2.89 = $43.35 (in bulk can be slightly less)
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 09-13-2007, 02:29 PM   #23
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up In A N.y. Minute
Originally Posted by moosetags
We have a 2005 25' Safari that we have pulled about 20,000 miles in all conditions and terrain with a 2005 Suburban 2500 4x4x4 with the 6.0 liter gas engine. We have found this to be a very good TT/TV combination. That being said, we with probably replace the Sub with a Duramax puck-up unless GM sees fit to put the Duramax in the Suburban. It is rumored that this will happen.
Although my 95, 3/4,7.4, 3:73,BURB has been an outstanding TV, I would replace it in a NYM if G.M. would offer the same with the Dura-max, Allison combo. Isn't dreaming FUN
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 09-13-2007, 02:50 PM   #24
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Are you planning on upgrading? I would get at least a 3/4 ton vehicle with capacity to pull at least 10,000 lbs. Your trailer has a maximum weight 7300. You need a TV that has a rated tow capacity of 8800 lbs.
Michelle TAC MT-0
Sarah, Snowball
Old 09-13-2007, 03:09 PM   #25
Don't pay attention to inflated tow capacity numbers -- I was the original Nissan Titan owner on these boards. I got my 25' FB SE and the Titan was history. 1/2-tonners easily have that much tow capacity but they lack in payload capacity to bear driver/passenger weights, fuel weight, tongue weight, and other options (truck cap, gear in the box or back of SUV). At least look at some of the GM/Chev 1500 HD load capacity specs -- you're as good as you get with 1/2-tonners at that level -- whichever of the Big 3 can match it at least.
A dealer told a Mopar Diesel friend that the Tundra is going to have a diesel next year... ('09 models?). Believe it when you see it.
Old 09-13-2007, 06:10 PM   #26
Central , Mississippi
cool and calm
My TV is a '06 3/4 ton crew cab Ram with the Cummins TD and the two things I notice over a gasser are the milage and the torque. Everyone has commented on the better milage but to crawl up a big grade passing all of the trucks and never drop out of top gear really keeps the stress level low. One downshift and Mrs. HiHo starts grabbing the dash and fussing about my aggressive driving.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 09-13-2007, 06:15 PM   #27
Vancouver , BC
renting?
Just a thought, if you only use a Tow Vehicle 6 times a year then why not rent one? That seems to me like a lot of money to put into something you won't use too much and will have to insure and maintain all year.
betsy2 is offline   Reply With Quote
Old 09-13-2007, 06:40 PM   #28
I seem to recall threads about renting and it is generally tough to find -- or companies outright prohibit towing. I can't imagine they'd be available for unlimited use with a Class III/IV hitch. Our 289 cid Falcon Ford (Mustangs were nothing but Falcons with a different body) blew up towing a small trailer once in Muskogee, OK. We could rented a full size U-Haul to pull that small trailer the rest of the way to Temple, Texas. Those companies aren't as tow friendly nowadays. And I'm sure even a U-Haul couldn't take a 2 5/16" ball. The most common RV rental these days is a Class C moho.
By the way -- note that the OEM ST tires on an Airstream usually have a top speed limit of 65mph. I will go just that fast on an interstate. 62mph is okay. Even 58mph. But 55mph is to-o-oo darn slow! Mrs. HiHo knows something!
Hide and Seek PeterH-Airstreamer Airstream Motorhome Forums 6 06-10-2007 08:53 PM
advice on inspection 1983 310 diesel sailhighc Classic Motorhomes 4 11-16-2006 08:44 PM
new members seek bambi.... Dave and Pat Member Introductions 6 04-11-2006 03:06 PM
What's important to you? yukionna Our Community 8 10-27-2003 04:08 PM
