Old 07-15-2011, 07:43 AM   #1
Islander
kingfisher24's Avatar
2005 28' International CCD
Deer Harbor , ORCAS ISLAND WA
Sealed wheel bearing hub assemblies?
Gmc.....anyone had any experience in replacing these...cost.....?????
Kingfisher24
and the Four P's(Paula, Phoenix and Peabody II and Pearl)…Peabody is here…..
2013 GMC sierra denali
WBCCI 2541
4CU
kingfisher24 is offline   Reply With Quote
Old 07-15-2011, 07:46 AM   #2
dznf0g's Avatar
Oswego , Illinois
The good news...They never need servicing, so you save money and time there.
The bad news....they cost much more than old repackable wheel bearings.
Memory is not good on this one, but I think about $175 per.
EDIT: I think, on second thought, this vehicle must replace the hub with the bearing in order to get the speed sensor reluctor ring fitted with the bearing. About $500 per side (front). You didn't say if you needed front or rear)
Rears appear to be the same price range.
Old 07-15-2011, 09:04 AM   #3
Islander
oh but they do
GM sealed wheel bearing hub assemblies do wear out it seems...if one does it himself , it is not that costly....on the road, however, it is quite costly it seems.....$500.00 or so at a GM dealer
Kingfisher24
WBCCI 2541
4CU
Old 07-15-2011, 09:13 AM   #4
dznf0g's Avatar
Oswego , Illinois
You misunderstand me...they do not need repacking every 15,000 miles, at about $75 - $100 each time (depending on labor rate) like the old ones. Yes all bearings have a life expectency, which depends a lot on load and operating conditions.
Old 07-15-2011, 09:38 AM   #5
Islander
GM bugs
it seem , like hitches on gm trucks, which are inadequate....mine just twisted off......these hub assemblies are prone to abnormal wear....and expensive....oh well.....cost of doin business
Kingfisher24
WBCCI 2541
4CU
Old 07-15-2011, 09:52 AM   #6
dznf0g's Avatar
Oswego , Illinois
How many miles on the truck? First replacement(s) per corner?
QS has four of the sealed bearings, non-QS have only fronts.
Old 07-16-2011, 06:59 AM   #7
Islander
done
137,000 miles....left front.....411.00 for the part....142.00 for the labor....
something new learned and cataloged
Kingfisher24
WBCCI 2541
4CU
Old 07-16-2011, 09:09 AM   #8
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
RockAuto.com... $95 - $208?
I've changed a few 'sealed' Chevy bearings - easier than I though it would be, just need the 3-foot persuader handle on the rust-welded bolts...
EDIT: Oops. missed the 'done' part, my condolences Sir...
Old 07-17-2011, 06:40 AM   #9
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Next time out, these were $120 for the pair (both front):
2004 GMC Sierra Denali Wheel Bearing & Hub Assembly at 1AAuto.com.
NEW: 5th Wheel Airstream Airtrekker Boondocking 38 06-25-2016 09:52 PM
Wheel Hub greatlakes Tires 5 08-15-2011 07:13 PM
Need wheel, and wheel cover oldcar29 Wheels, Hubs & Bearings 4 07-05-2011 02:09 PM
wheel bearing lube 1989 excella murphy Wheels, Hubs & Bearings 1 06-21-2011 07:25 AM
Wheel Bearing Help Needed mile2885 Wheels, Hubs & Bearings 31 06-16-2011 10:22 AM
