Old 09-29-2014, 07:24 PM   #113
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
If the leverage bars are basically loose, then there is little improvement over just a plain ball. The receiver on the truck is not level, it is pointing skyward, thus all the leverage is used trying to get the arms level.
Get under the truck and determine why the truck receiver is NOT level with the road. You might have a serious frame issue there.
Old 09-29-2014, 07:34 PM   #114
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
You mentioned the bars aren't carrying any significant weight. That's an indicator of a problem. If you already have washers in the hitch and still not loading the bars the either (1) the brackets are too low or the hitch is (2) pointing up. You really want those bars to be carrying a good load. That's how sway control works, friction between bars and brackets. I still think something's funny with the truck mounted receiver, doesn't look right.. I'd first try adding as many washers that will fit.
kscherzi is offline   Reply With Quote
Old 09-29-2014, 07:39 PM   #115
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
It is sitting in my angled driveway-
The driveway is on a slant up to the rear wheels of the truck then levels off where the trailer is-
The receiver shank does come out of the truck straight and is parallel to the road when on a level road. It my go up a little because the truck has a "rake" to it- the front is lower than the back/
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-29-2014, 07:41 PM   #116
m.hony's Avatar
2013 30' Classic
The way I have it now it does have weight distribution, but the bars are not parallel to the tongue as Equal-i-zer says they should be. When I set it up the way Equal-i-zer says it has no weight distribution.
TAC #MS-10
Airforums #70955
Old 09-29-2014, 07:45 PM   #117
m.hony's Avatar
2013 30' Classic
The brackets are as high as they will go.
I have weight distribution and sway control. It drives, rides, handles good. It's just that the trailer is nose down. Go higher on the ball the trailer is nose up and handles bad. There has got to be a way to get the trailer level and have weight distribution. There has to be an in the middle- good handling AND a level trailer-
TAC #MS-10
Airforums #70955
Old 09-30-2014, 05:06 AM   #118
m.hony's Avatar
2013 30' Classic
There is a tremendous amount of slop/play between the Equal-I-zer shank and the Toyota receiver. I have not figured out exactly how to address this. I have thought about a bead of weld on the bottom and one side of the shank to make it fit snugly. This might affect the hitch adjustments.
TAC #MS-10
Airforums #70955
Old 09-30-2014, 05:23 AM   #119
Gainesville , Florida
Camping world and other rv supplies sell a u shaped bracket the eliminates the slop. It's a bolt on thing. If your rig handles okay, maybe leave well enough alone? Unless you are parked on a level area no one will knows if it is perfectly level or not. If you have sway control now, be happy. AS, in their old owners manuals, said a little down is okay. Jim
Old 09-30-2014, 06:00 PM   #120
m.hony's Avatar
2013 30' Classic
Yep. Someone messaged me that info. I responded that I would be getting on Amazon.
I stopped by an RV store today snd forgot to ask about that thing-a-ma-jig.
TAC #MS-10
Airforums #70955
Old 10-01-2014, 07:49 AM   #121
m.hony's Avatar
2013 30' Classic
In the end, it may be a little nose down. I am just trying everything first before I decide that. Heck, even getting slop/play out of the hitch shank/receiver might raise the trailer 1/8-1/4".
TAC #MS-10
Airforums #70955
Old 10-01-2014, 07:52 AM   #122
m.hony's Avatar
2013 30' Classic
I think that thing-a-ma-jig is called a hitch anti-rattle device.
TAC #MS-10
Airforums #70955
Old 10-01-2014, 07:54 AM   #123
switz's Avatar
2014 31' Classic
Images: 8
I think we are between ⅛" and " nose down depending on the load in the trailer and where she puts it. I could mess with the level ride air suspension but will leave that as an option if things change.
Old 10-01-2014, 07:54 AM   #124
SteveH's Avatar
Common Sense , Texas
Looking at the pictures you posted previously in this thread, I think your truck's receiver hitch is not strong enough and is twisting under the load of trying to distribute the tongue weight of your 30 footer.
Regards,
Steve
Old 10-01-2014, 08:17 AM   #125
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We used an Equal-I-Zer hitch for some time before I realized how little flexibility is available in the ridged square w.d. bars. Inland Andy warns about them and Andrew T. at Can-Am cautioned us to keep an eye on our A-frame when going through steep approaches where the rear of the trailer and the front of the truck are both raised. I had to balance that advice against the long, good history of Equal-I-Zer, but ended up replacing it.
SteveH suggests bending of the receiver causing m.honey's inconsistent w.d. settings. m.honey referred to a rising grade of his driveway. Having no idea how how driveway relates to the street, the factors mentioned here may be something to look at. That is, could the truck receiver or trailer A-frame be flexing from the steepness of the driveway entrance and the inflexibility of the w.d. bars?
Doug and Cheryl
Old 10-01-2014, 08:22 AM   #126
The anti rattle thing can be installed to either raise or lower the hitch a little. Bolts on top or on the bottom. Jim
sagging kitchen counter tandemfish General Motorhome Topics 6 10-17-2006 07:39 PM
Fresh Water Tank is Sagging Hunter_1 Fresh Water Systems 5 04-27-2006 08:32 AM
Sagging rear bumper igenerally Bumpers & Bumper Storage 1 05-08-2005 07:42 PM
Sagging Door in '92 300LE fangthorpe Airstream Motorhome Forums 3 12-30-2003 02:02 PM
Sagging Shower w9det 2001 Safari 1 09-12-2003 01:28 PM
