Old 09-14-2014, 06:50 AM   #29
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Originally Posted by m.hony View Post
Bikes and firewood are in the bed of the truck.
I like the convenience of having the firewood at the back, but firewood at the front is better for weight distribution.
Firewood is available in most places and not legal to haul around in some states to prevent spread of tree disease. While at Jackson Center (I think I saw you were headed there?) have them put on a bicycle rack so two of your bikes can subtract from hitch weight rather than adding to it.
Doug and Cheryl
Old 09-14-2014, 08:17 AM   #30
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
That is true. After I burn what I have I will do without or buy at the campground. I still have 2 piles at home, though.
I can buy wood for $7 at George Payne Cossar State Park. For $7 they bring you a Ford Ranger truck bed full of wood- very economical-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 09-14-2014, 08:21 AM   #31
m.hony's Avatar
2013 30' Classic
I honestly don't have the cash for the bike rack. Maybe next time. We will go to Jackson Center every 2-4 years for service/maintenance/repair because it is a better option/more convenient for me than service from a dealer 4-5 hours away who requires an appointment, requires me to leave the trailer 2 weeks- making 2 8-10 hour road trips- and doesn't have parts on hand.
TAC #MS-10
Airforums #70955
Old 09-14-2014, 08:28 AM   #32
m.hony's Avatar
2013 30' Classic
Forest Service parks will not allow wood brought from elsewhere.
The only Forest Service park we stay in is Choctaw Lake at Ackerman, MS.
TAC #MS-10
Airforums #70955
Old 09-14-2014, 10:43 AM   #33
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
The "bummer" factor there is firewood is pretty heavy. It doesn't take much to equal a 100 pounds or more.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 09-14-2014, 11:49 AM   #34
m.hony's Avatar
2013 30' Classic
Someone messaged me that scrap lumber from a lumber yard was not technically firewood. I get scrap lumber for free from a factory in my town that makes pallets.
TAC #MS-10
Airforums #70955
Old 09-14-2014, 12:51 PM   #35
dkottum's Avatar
Maybe no bugs but still heavy.
Doug and Cheryl
Old 09-20-2014, 03:27 PM   #36
m.hony's Avatar
2013 30' Classic
I simply don't have enough truck or hitch for my trailer. The trailer is still a little nose down with 6 washers and the L-brackets as high as they will go. My hitch and my truck are maxed out or overloaded. The Tundra has the horsepower and torque, but is lacking in the payload department.
TAC #MS-10
Airforums #70955
Old 09-20-2014, 04:11 PM   #37
TahoeStream'n
subfan1's Avatar
2012 20' Flying Cloud
La Habra , California
You have a heavy trailer M
Did you invert the shank yet, per your previous post. I think it has to look better? Did you take a picture yet?
subfan1 is offline   Reply With Quote
Old 09-20-2014, 04:40 PM   #38
dkottum's Avatar
If your Airstream is nose down it's not because you are maxed out, you just need the hitch moved higher on the receiver drop bar.
Airstream says the hitch weight should NEVER exceed 1,000 lbs in your Owners Manual, that would be 10% of their heaviest current model. If it does, you should try to redistribute your trailer load.
With weight distribution on a 1/2 ton truck it should support 1,000 lbs, it's namesake, 1/2 ton. As usual, there are most likely exceptions, but I doubt your Tundra is one of them.
Doug and Cheryl
Old 09-20-2014, 04:45 PM   #39
m.hony's Avatar
2013 30' Classic
Bob, hitch installer for 40 years at Jackson Center, said not to raise the ball, but to lower it.
We did get the truck at its original ride height and the trailer dead level at Jackson Center, but it is drooping again. I think my suspension is wearing out as we speak- er, type-
The way I had it, there was no sway control- no friction, no pressure-
No, it works well, but after a turn it takes a while to straighten out. Bob was telling me the merits of a Reese Dual Cam in that regard- it is designed (cam and crook in weight bar) to always want to return to center/straighten. The Equal-i-zer straight bars have nothing to make them return to center/straight. I have to hold the steering whelk against the pressure after a turn till it eventually straightens.
TAC #MS-10
Airforums #70955
Old 09-20-2014, 04:50 PM   #40
m.hony's Avatar
2013 30' Classic
I thought that, too, but Bob at Jackson Center said opposite. He lowered the hitch 2 holes, added 2 washers (I have 6 now), and raised the L-brackets- which to me is maybe like moving up a chain link on an Eazlift or similar style hitch. Maybe I should raise the ball one or two holes and see what happens. After 2 more holes inverting the shank is the only thing left to try.
Apparently you can't just adjust one thing without adjusting everything else.
TAC #MS-10
Airforums #70955
Old 09-20-2014, 05:01 PM   #41
dkottum's Avatar
If it isn't level with weight distribution applied (similar drop front and rear of truck, maybe an inch or so more on back) the next thing is to raise the hitch on the drop bar. If you're out of holes, invert it.
Sounds like Bob want to get more weight distribution to the front of the truck, and it probably needed it as he saw it.
Doug and Cheryl
Old 09-20-2014, 05:05 PM   #42
m.hony's Avatar
2013 30' Classic
I still have 2 holes to go before inverting-
It started at the top.
If I would have thought of that I would have gotten Bob to raise the ball back up-
As it is that hitch adjustment took half a day and caused me to stay another night.
Why was the trailer dead level there, but nose down again now?
TAC #MS-10
Airforums #70955
sagging kitchen counter tandemfish General Motorhome Topics 6 10-17-2006 07:39 PM
Fresh Water Tank is Sagging Hunter_1 Fresh Water Systems 5 04-27-2006 08:32 AM
Sagging rear bumper igenerally Bumpers & Bumper Storage 1 05-08-2005 07:42 PM
Sagging Door in '92 300LE fangthorpe Airstream Motorhome Forums 3 12-30-2003 02:02 PM
Sagging Shower w9det 2001 Safari 1 09-12-2003 01:28 PM
