Old 10-03-2014, 08:20 PM   #183
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I already tried raising the hitch head one notch. Then the trailer is nose up!
I have slightly tilted the L-brackets back to match the angle of the bars.
Equal-i-zer is sending me a couple of washers.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 10-03-2014, 08:38 PM   #184
Tuco's Avatar
1988 32' Excella
Ojai , California
Why can't you buy the 1" ball and take it to a machine shop and have it turned down to the 1/2" you want? Buy 2 and do one at 3/8" and the other at 1/2"? My head hurts after reading this thread! I can't imagine how yours feels m.hony.
Dave & MJ
1988 32' Excella 1000 (Beauty)
1999 White Dodge SLT Laramie 3500 Dually, 4x4, 5spd, 5.9 CTD 260k+ (The Beast)
Tuco is offline   Reply With Quote
Old 10-03-2014, 08:58 PM   #185
m.hony's Avatar
2013 30' Classic
I couldn't find a 1" ball- only 2"-
I thought about shimming it with a washer.
Waiting on washers from Equal-i-zer-
Might be a while till I'm able to tinker with it. We're in a state park with un-level pads now.
TAC #MS-10
Airforums #70955
Old 10-04-2014, 05:58 AM   #186
Gainesville , Florida
Maybe sit back and regroup. Go back to the slightly nose down setup and go camping. Overthinking. Jim
Old 10-04-2014, 06:12 AM   #187
m.hony's Avatar
2013 30' Classic
We are back to the nose down setup.
We are camping.
Name:	ImageUploadedByAirstream Forums1412424499.426073.jpg
Name:	ImageUploadedByAirstream Forums1412424543.583575.jpg
Name:	ImageUploadedByAirstream Forums1412424565.626187.jpg
Name:	ImageUploadedByAirstream Forums1412424605.420329.jpg
The only thing left to try is another washer in the hitch head.
If that don't work, it's nose down permanently.
TAC #MS-10
Airforums #70955
Old 10-04-2014, 06:13 AM   #188
m.hony's Avatar
2013 30' Classic
Have re-grouped about a half dozen times...
TAC #MS-10
Airforums #70955
Old 10-04-2014, 10:46 AM   #189
SteveH's Avatar
Common Sense , Texas
m.hony,
Take a look at this thread I started about my solution to a similar problem as yours:
http://www.airforums.com/forums/f464...ml#post1520179
Regards,
Steve
Old 10-20-2014, 08:19 AM   #190
Creggster
casandel's Avatar
2013 28' International
Livingston , Texas
I agree. I put air bags on my Silverado and solved the sagging problem.
casandel is offline   Reply With Quote
Old 10-20-2014, 06:44 PM   #191
m.hony's Avatar
2013 30' Classic
I added a washer for a total of 7.
The trailer is now barely nose down- 1/4" difference from front to rear.
It's good enough. I'm gonna leave it alone. Just towed 900 miles just fine.
TAC #MS-10
Airforums #70955
Old 10-21-2014, 09:02 AM   #192
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Our trailer varies from ⅛" to " nose low. Not an issue.
Old 10-21-2014, 09:43 AM   #193
Tuco's Avatar
1988 32' Excella
Ojai , California
I almost had a heart attack, you need to warn us before using such words...
Dave & MJ
Old 10-21-2014, 10:52 AM   #194
mefly2's Avatar
2015 25' FB Eddie Bauer
Wow; finally you got it!
Old 10-21-2014, 12:50 PM   #195
m.hony's Avatar
2013 30' Classic
1/4" nose down is not even detected by the eye- I only know because I put a tape measure on it.
I was gonna put my new back link plates on, but I couldn't get the bolts undone. I'll need air to get the L-brackets apart. I tightened them by hand- I guess that's what nylon nuts and lock washers do-
TAC #MS-10
Airforums #70955
Old 10-21-2014, 12:51 PM   #196
m.hony's Avatar
2013 30' Classic
It wasn't good enough prior to that adjustment-
I'm just real hard headed and simply refused to accept that the way it was was good enough-
Was was-
TAC #MS-10
Airforums #70955
sagging kitchen counter tandemfish General Motorhome Topics 6 10-17-2006 07:39 PM
Fresh Water Tank is Sagging Hunter_1 Fresh Water Systems 5 04-27-2006 08:32 AM
Sagging rear bumper igenerally Bumpers & Bumper Storage 1 05-08-2005 07:42 PM
Sagging Door in '92 300LE fangthorpe Airstream Motorhome Forums 3 12-30-2003 02:02 PM
Sagging Shower w9det 2001 Safari 1 09-12-2003 01:28 PM
