10-03-2014, 07:57 PM
#181
2012 25' Flying Cloud
Battle Lake
You asked if someone had used something similar. We had two different 1/2 ton trucks an Equal-I-Zer hitch and our 25' Airstream with nearly same factory hitch weight as yours.
With the weight distribution set right with camp-ready loading in truck and trailer, then I would tweak the level of the trailer with raising or lowering the hitch head on the drop bar. If I recall that's about 1 1/2" per hole, so should raise or lower the front of the trailer about an inch without disturbing the weight distribution settings.
Going down the road with all its bumps and dips may settle things a bit so you might be seeing a slight change there, and most likely there is a little vertical twisting of the half-ton truck receiver which I'm guessing is fairly normal when weight distribution is applied, returning to original when w.d. is released.
Doug and Cheryl
10-03-2014, 08:15 PM
#182
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
My suggestion as well ... raise the hitch head on the drop bar / stinger one hole. That should raise the front of your trailer. However, it will affect your weight distribution. To get that distribution back, you will need to either raise the L-brackets or add one washer to the downward tilt. As I said before, adding a washer to the downward tilt has an effect similar to raising the L-brackets. However, the distance from the ball to the L-brackets varies by the installer; so, it is not always a tit-for tat exact amount.
The reason that you try to get the load bars parallel to the ground or to the trailer frame is because they ride on the L-brackets. If the bottom of the bar is parallel with the bottom of the L-bracket, it minimizes the wear and maximizes the contact surface area. We have used the same hitch on three different AS trailers and two different TVs. I have helped many get their set ups right; if you are in the area, feel free to send me a PM for a meet up...or call if you want to talk it through. I can feel your frustration in your posts.
10-03-2014, 08:20 PM
#183
2013 30' Classic
Greenwood
, Mississippi
I already tried raising the hitch head one notch. Then the trailer is nose up!
I have slightly tilted the L-brackets back to match the angle of the bars.
Equal-i-zer is sending me a couple of washers.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
10-03-2014, 08:38 PM
#184
1988 32' Excella
Ojai
Why can't you buy the 1" ball and take it to a machine shop and have it turned down to the 1/2" you want? Buy 2 and do one at 3/8" and the other at 1/2"? My head hurts after reading this thread! I can't imagine how yours feels m.hony.
Dave & MJ
1988 32' Excella 1000 (Beauty)
1999 White Dodge SLT Laramie 3500 Dually, 4x4, 5spd, 5.9 CTD 300k+ (The Beast)
10-03-2014, 08:58 PM
#185
2013 30' Classic
Greenwood
, Mississippi
I couldn't find a 1" ball- only 2"-
I thought about shimming it with a washer.
Waiting on washers from Equal-i-zer-
Might be a while till I'm able to tinker with it. We're in a state park with un-level pads now.
TAC #MS-10
Airforums #70955
10-04-2014, 05:58 AM
#186
Mantua
, Ohio
Maybe sit back and regroup. Go back to the slightly nose down setup and go camping. Overthinking. Jim
10-04-2014, 06:12 AM
#187
2013 30' Classic
Greenwood
, Mississippi
We are back to the nose down setup.
We are camping.
The only thing left to try is another washer in the hitch head.
If that don't work, it's nose down permanently.
TAC #MS-10
Airforums #70955
10-04-2014, 06:13 AM
#188
2013 30' Classic
Greenwood
, Mississippi
Have re-grouped about a half dozen times...
TAC #MS-10
Airforums #70955
10-04-2014, 10:46 AM
#189
Common Sense
m.hony,
Take a look at this thread I started about my solution to a similar problem as yours:
http://www.airforums.com/forums/f464...ml#post1520179
Regards,
Steve
10-20-2014, 08:19 AM
#190
Creggster
2013 28' International
Livingston
I agree. I put air bags on my Silverado and solved the sagging problem.
10-20-2014, 06:44 PM
#191
2013 30' Classic
Greenwood
, Mississippi
I added a washer for a total of 7.
The trailer is now barely nose down- 1/4" difference from front to rear.
It's good enough. I'm gonna leave it alone. Just towed 900 miles just fine.
TAC #MS-10
Airforums #70955
10-21-2014, 09:02 AM
#192
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Our trailer varies from ⅛" to ¼" nose low. Not an issue.
10-21-2014, 09:43 AM
#193
1988 32' Excella
Ojai
I almost had a heart attack, you need to warn us before using such words...
Dave & MJ
10-21-2014, 10:52 AM
#194
Small Town
Wow; finally you got it!
10-21-2014, 12:50 PM
#195
2013 30' Classic
Greenwood
, Mississippi
1/4" nose down is not even detected by the eye- I only know because I put a tape measure on it.
I was gonna put my new back link plates on, but I couldn't get the bolts undone. I'll need air to get the L-brackets apart. I tightened them by hand- I guess that's what nylon nuts and lock washers do-
TAC #MS-10
Airforums #70955
10-21-2014, 12:51 PM
#196
2013 30' Classic
Greenwood
, Mississippi
It wasn't good enough prior to that adjustment-
I'm just real hard headed and simply refused to accept that the way it was was good enough-
Was was-
TAC #MS-10
Airforums #70955
10-21-2014, 01:32 PM
#197
Vintage Kin
Fort Worth
If you're into territory Switz has nailed down then that hardheadedness has paid off. Do it once and do it right (ain't always easy to accomplish).
