Old 07-09-2019, 09:21 AM   #1
CWSWine's Avatar
2019 33' Classic
Manhattan , Kansas
Rock Tamers Storage/Removal/Installation
I searched and didn't come up with an answer.
1. With the Rock Tamers installed is hard to remove and install the WD hitch? Seems like it would really difficult to manage the tamers and hitch for removal and installation of the hitch.
2. We normally remove our hitch and put in the bed of the pickup to secure it. What do with the Tamers installed? We thought we just put them under the AS hitch and run cable thought the hitch and secure to the AS.
Dennis & Ellie
2019 Ram 2500 Longhorn 6.4 Hemi w/2868 payload on the Yellow Tag.
2019 Airstream Classic 33FB Dry Weight 8595 Tongue 1230
CWSWine is offline   Reply With Quote
Old 07-09-2019, 10:18 AM   #2
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
We usually leave the Rock Tamers (RTs) attached to the shank and place them both behind the trailer once we have unhooked. Given the weight of the 2 together it is very unlikely they will just "walk off". When I say "we" I mean the GW and myself, as this is one of those times both are required for the job of removing and carrying the combo to the back of the trailer.
There are other times that I have separated the RTs from the shank and placed them both in the truck box. I loosen the RTs hub from the shank before I remove it from the receiver. I then pull the shank from the receiver, allowing it to tip away from me and the RTs just slip off on to the ground.
thewarden is offline   Reply With Quote
Rock Tamers - not a cure for stupid Tin Diesel Rock Guards, Segment & Window Protectors 16 08-13-2017 10:30 PM
Rock Tamers from Cabela's markdoane Hitches, Couplers & Balls 33 05-13-2013 08:50 PM
Hensley and Enkay Rock Tamers Roadtoaster Hitches, Couplers & Balls 5 03-06-2007 09:07 PM
Enkay Rock Tamers: Trim Length Tin Diesel Rock Guards, Segment & Window Protectors 6 05-20-2006 03:45 PM
Rock Tamers vs Protect-A-Tow vs Towtector ITowSilver Rock Guards, Segment & Window Protectors 17 03-29-2006 04:46 AM
