Old 08-07-2013, 07:57 AM   #1
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Right tow mirrors?
My 2010 Ram2500 I bought recently has these towing mirrors.
Will they do the job pulling my AS once it arrives? Or will I need something wider?
PharmGeek is offline   Reply With Quote
Old 08-07-2013, 08:12 AM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
What is the measurement from the outside of one mirror to the outside of the other and what is the width of your new Airstream?
Bill
ps: those mirrors should do fine.
Just my personal opinion
Old 08-07-2013, 08:13 AM   #3
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
Looks like they should be fine. You just want to be sure that you can see clearly behind the trailer, and the convex bottom mirror should eliminate any blind spots. The biggest problem with extensions is vibration, but these look pretty securely mounted. Give them a try.
DryFly is offline   Reply With Quote
Old 08-07-2013, 08:23 AM   #4
aftermath's Avatar
Spokane , Washington
I doubt they can handle the tongue weight.
Give them a try and see. Getting something wider might be a challenge. Does Dodge have an OEM mirror you can add? OEM would be my first choice before I looked at strap ons. I used some Cippa mirrors that worked but were always vibrating and needing constant attention.
aftermath is offline   Reply With Quote
Old 08-07-2013, 11:00 AM   #5
bganso's Avatar
1994 30' Excella
Truckee , California
Our friend has the same mirrors on his Ram 1500 and they do the job when he's pulling a 2012 FC.
bganso is offline   Reply With Quote
Old 08-07-2013, 11:16 AM   #6
adonh's Avatar
1976 31' Sovereign
Missouri City , Texas
The right mirror looks good, do you also have the left one, if so you are in business.
Don Hardman
1976 31' Sovereign
adonh is offline   Reply With Quote
Old 08-07-2013, 12:27 PM   #7
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
lol, as best I recall, I think I am covered on the driver's side as well
Ill measure up these when I get home....extended in this way, they look to be adequately wide...but I will obviously examine more so once hooked up....and if needed, will get some alternative...
I am not at all sure...I did some googling about OEM options for towing mirrors....my initial searching came up dry, but did not look that hard yet.
These seem quite wide...ill provide measurement tonight.
Old 08-07-2013, 12:50 PM   #8
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
You already have the right mirrors.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-07-2013, 12:52 PM   #9
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Our son's 2013 RAM has those exact mirrors, and they tow a Jayco. They are wide enough to see around that big box trailer. We were impressed enough, that I bought an aftermarket set for our 2009 RAM 1500. Best towing mirrors we ever had.
Chris
Old 08-07-2013, 02:57 PM   #10
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I have a 2014 Ram 2500 Laramie (w/Cummins diesel) on order. I checked out these mirrors on the dealer's lot and I think they'll work. Won't know until I hitch up and see if they stick out far enough. It looks like the convex (or are they concave?) section at the bottom makes them workable. I have a set of Aero mirrors I'm using now, and if needed, their clamping system will work on ANY mirror, including these.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 08-07-2013, 03:05 PM   #11
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
yeah, they look nice and think they will hold up with very little vibration in tow since they are fairly solidly attached...all the other "attachment" type mirror all seem to have their issues...
Man I'm glad this is one less thing for me to have to replace...
Old 08-07-2013, 05:15 PM   #12
m.hony's Avatar
2013 30' Classic
Quit worrying. You have the best of everthing now. Nobody can argue that.
Enjoy it.
TAC #MS-10
Airforums #70955
Old 08-07-2013, 06:18 PM   #13
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
hey no dare m-hony - stop trippin yo
Old 08-07-2013, 07:39 PM   #14
m.hony's Avatar
2013 30' Classic
Word. Bet.
TAC #MS-10
Airforums #70955
Tow Mirrors wlynn Towing, Tow Vehicles & Hitches 11 03-15-2012 04:56 PM
Van Conversion/Small Motorhome as tow vehicle? TG2500 Tow Vehicles 0 10-16-2011 06:07 PM
1/2 Ton Tow Vehicles brianw Tow Vehicles 39 09-08-2011 06:44 PM
Tow mirrors... AirheadOK Towing, Tow Vehicles & Hitches 11 05-28-2011 10:56 AM
